05-25-2015, 03:56 PM
#331 (permalink)
I searched for Honda VX's in my neighborhood, and this is one of them. I have no idea if this is a good deal or not, let me know what you folks think?
Hondsa VX for sale
05-25-2015, 04:05 PM
#332 (permalink)
It looks like the magical VX lean burn engine has been swapped out.
05-26-2015, 10:31 PM
#333 (permalink)
5 Gears of Fury
Yup that's just a VX shell with a swapped motor. It may have the VX trans still, but that's the same as a CX so no big deal. The 7 extra "White" wheels it comes with might be factory VX alloys which are kinda neat, maybe ask is he'll sell those separate if they are. Though the spare brass shift knob sounds like a real dealmaker haha. Brass? Seriously?
You could always ask if he has the factory lean burn 1.5L and ECU sitting in his back yard. I wouldn't buy the car but he'd probably sell the original motor for scrap if he didn't know what it was. Just my 2 cents.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
05-27-2015, 01:44 AM
#334 (permalink)
Cyborg ECU
Agreed. And if he went to the lengths to swap an 1992-1995 EX or Si engine into it (D16z6) then he probably also got rid of the VX/CX tall geared 3.25 final drive tranny too. I'll bet it has the 4.25 final drive EX/Si transmission instead. Unfortunately those ain't the VX wheels either.
Also, the frame is damaged in front of where the AC radiator should be. It's pretty badly bent there... why?
05-27-2015, 01:55 PM
#335 (permalink)
Not bad, sounds like he's own it for more than a month
Geo Prizm 97 - $1400
It just passed the Smog check
110K Mileage
AC
CD player
New tires
Stick Shift
asking for 1400 or best offer, feel free to call me with any questions
car is in great condition
05-28-2015, 12:46 AM
#336 (permalink)
Too many cars
1993 civic vx unmodified - $1500 (Homer ny)
this is a decent 93 civic vx. it runs and drives. starts up and idles properly every time. recent tune up including new distributor, wires, plugs, injectors, etc to make it run smooth and get 60mpg. brakes work, lights work, should pass inspection without issue. new rear brakes, extra set of wheels. (oem vx wheels and steelies with moon caps)
cons; ebrake is not adjusted properly, needs a new clutch soon, rust of course.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
05-28-2015, 12:48 AM
#337 (permalink)
Too many cars
2001 Honda insight...Needs a (CVT) transmission...$950 OBO
2001 Honda Insight
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
05-28-2015, 01:52 AM
#338 (permalink)
Furry Furfag
Originally Posted by Gasoline Fumes
A trans is minimum 750 for a used one. Plus labor (350-400).
Doubt it has proper spark plugs. (60$).
Probably needs valve adjustment. (150$).
Needs oil change(20$).
Interior needs cleaning (swear equity).
Probably has no under engine panels (65$ for aluminum one from Scott, 200 for stock ones).
Needs steering wheel (70$).
Tires(450).
Battery condition? (2,000).
No license plate, tags expired? Could be a possible 374$ registration back fees if it's expired. That 950$ quickly turned into a 3,000$ one.
The Following User Says Thank You to Baltothewolf For This Useful Post:
05-28-2015, 10:48 AM
#339 (permalink)
VX: "should pass inspection without issue"
Says the guy whose VX is shown prevented from rolling out of his driveway by a wheel chock. A couple of parking brake cables should fix that.
Gotta love the moon eye wheel discs though! Ecomodder at heart.
06-11-2015, 11:03 AM
#340 (permalink)
2001 Swift 1.3L, 5-speed, $1250
This one has caught my eye:
EPA: 31 city / 38 hwy / 34 combined
http://www.fueleconomy.gov/feg/Find....n=sbs&id=15724
- 138,000 km / 86k miles
- has had annual oil treatments (anti-rust spray)
- almost new winter tires on rims
- 2 other sets of wheels/summer tires ("mags")
I've been in touch with the seller, who's retired. He says the underneath is perfect (rust-wise) and it's mechanically A-1. I'm going to go look at it tomorrow or Sat if it's still available.
He says he's selling because he's got too many cars and he doesn't use it much. Sounds like a vaguely familiar problem.
It's over an hour away, which violates my beater radius rule, but this one might be slightly better than the average $1200 beater if everything he says is true.
This would become the Firefly's permanent winter beater stunt double. Plus I could use its body parts to do more radical (ie. non-reversible) mods that could be moved back and forth between the cars, like: modding the front & rear bumper shape, welding on the hatchback for a more robust Kammback, etc.
