08-17-2011, 11:40 AM
#11 (permalink)
in tents
Mudflaps
Side mirrors (added internal)
Power Steering Pump
Mechanical fan (added electric with manual switch)
08-17-2011, 12:30 PM
#12 (permalink)
Cyborg ECU
May delete lead acid battery and replace it 2 or 3 parrelled lithium packs used in motorcycles and ATVs, replacing a 35-40lb lead battery with 2 or 3 minipacks that weigh about 5lb each.
I like this idea. I have seen some small deep cycle batteries that are still fairly light... I wonder.
Originally Posted by 320touring
I'm thinking of trying to come up with a way to remove 100kg from the 318iS and the 320i that DOESNT affect the look, fit or finish of the car.. anyone any ideas?
I would look to the sound system (for substitutions that are lighter) and to the engine (also for lighter substitutions). Body substitutions, such as using existing body parts as a plug for a mold for fiberglass fabrication of identical, paintable parts that are lighter (trunk, fenders, hood would probably be easiest). Lightweight aluminum pulleys of the same sizes, like wheels, would reduce effectively twice as much "weight" by reducing twice their weight in rotational mass. These are ideas I have. My car is like an ancient Buddhist temple that monks are gradually completely rebuilding in replica as the parts rot or break.
08-17-2011, 03:59 PM
#13 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
With the back seat and passanger seat delete also deleted belts and passanger airbag. (Electrical tape over the Airbag light on the dash so I don't see that it is on all the time.
Ground off the rear tow hook, removed front tow hooks via bolts.
Moved battery to back seat floor and got the smallest/lightest Lead acid car battery.
Removed passanger wiper and added two inches to drivers wiper.
Currently grinding on the passagner rear door want to remove reinforments and replace glass with plastic.
All the other ones discussed above. All total 225lbs so far.
08-17-2011, 09:04 PM
#14 (permalink)
Intermediate EcoDriver
Deleted:
3.6 miles from my morning commute.
1.6-3.6 miles (depending on whether I need to do anything in town after work) from my afternoon commute.
Saved miles and got better FE due to lower speeds.
And I deleted 40# of "spare tire" from the "nut behind the steering wheel". mostly for health reasons) That's transferable between my vehicles. It helped my FE a bit, and it helped my skiing ability a LOT. It also increased my tolerance for hot weather, so I use the AC less.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
08-18-2011, 06:29 AM
#15 (permalink)
See: http://ecomodder.com/forum/showthrea...ies-18547.html
08-18-2011, 07:14 AM
#16 (permalink)
Cheers for the suggestions folks- I'll give it some more thought!
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
08-18-2011, 08:58 AM
#17 (permalink)
Originally Posted by busypaws
With the back seat and passanger seat delete also deleted belts and passanger airbag. (Electrical tape over the Airbag light on the dash so I don't see that it is on all the time..
You can usually plug a resistor into the connector to fool the airbag ECU into thinking the removed airbag is still there.
On some cars, it's worth knowing that none of the remaining airbags will function if there's a fault detected ie airbag light on.
The Following User Says Thank You to markweatherill For This Useful Post:
08-18-2011, 10:53 AM
#18 (permalink)
Hypermiler
I've deleted nothing. When school starts next week, the back seat will see daily use again. The radio antenna is retracted but not deleted.
I've added a Scangauge, grille block, overnight battery charger and air in the tires.
08-18-2011, 11:30 AM
#19 (permalink)
The weight of the driver matters. :-)
Been riding my bike, I've dropped almost 12 lbs. Almost down to my ideal weight of 150.
I also dropped 400 lbs of passenger weight of my carpool members since I changed jobs. Mixed emotions here as they were paying all of my fuel for a while.
Deleted- passenger mirror, A/C belt.
08-18-2011, 12:16 PM
#20 (permalink)
Deleted
- Passenger mirror
- Rear seats
- Rear seatbelts
- A/C compressor, condenser, piping, etc.
- Used to keep the front passenger seat out, but it's convenient to keep it in.
- Belly pan (not intentionally, drove through some deep water which tore it off)
The AC needed to be charged, but I never used it anyway, so cut it all out. Taking out the rear seats made a lot more cargo space.
