Old 09-11-2013, 12:40 AM   #591 (permalink)
Now we're talkin'.
Having re-read the last page I'll just say Thee Template is a wingtip, on a wing of negligible span.
Old 09-11-2013, 03:54 PM   #592 (permalink)
wingtip
Now we're talkin'.
That's a good way to think about it.
Not too long back,Frank Lee posted a 20% thickness airfoil section that was delicious.
Anything with an aft-body contour like this will be well received by the boundary layer.
Old 09-12-2013, 08:51 AM   #593 (permalink)
Maybach - Paul Jaray e a aerodinâmica - Um olhar sobre as corridas
"The ideal way Jaray applied to a body close to the ground" in 1920
ETH Library, History of Science Collection, Zurich, Switzerland
FIRST POSTED IN ANOTHER THREAD HERE:
http://ecomodder.com/forum/showthrea...d-26678-2.html
http://heinkelscooter.blogspot.com/2...oples-car.html
An Idea Crystallises
The concept of the Volkswagen as we know it begins in 1920 with the patents of a Hungarian aeronautical engineer named Paul Jaray. Born in 1899 in Vienna, Paul Jaray studied aeronautics in Prague and wrote extensively on wing design and aeronautical theory. In 1914 he joined the Zeppelin Company and rose through the ranks to become their chief designer.
Jaray recognised the importance of aerodynamic streamlining, and although he couldn't put these ideas into practice during the war, he experimented extensively in Zeppelin's wind tunnels on a range of design concepts. After the Treaty of Versailles put an end to Germany's aircraft and airship industry, Jaray turned his interest to cars. In 1922 he lodged a patent for a car design concept featuring a "half stream-lined body shell" that would "reduce the resistance of air to the highest degree attainable" by "deflecting the air chiefly upwards, as well as rearwards over its top and then down to the bottom with the least disturbance as possible."
Another key design feature was the rear mounting of the engine, which maximised the use of interior space. The design concept was so radical and exciting that it attracted immediate interest from a range of companies. Jaray consulted for companies such as Hanomag, Adler, Mercedes-Benz, Maybach, Auto-Union, Tatra, Steyer-Puch and even Chrysler in the United States, before moving to Switzerland in the late 1920s and establishing his own consulting company called Stromlinen Karosserie (streamlined bodywork).
One of Jaray's wind tunnel maquettes. This shape would form the basis of his car design patents.
aerohead (09-12-2013), BamZipPow (09-14-2013)
Old 09-12-2013, 06:09 PM   #594 (permalink)
jaray
The infamous pumpkin seed! Cd 0.13 with wheels and on the ground.
With a bit longer body she goes to Cd 0.12.
Great 'template' material!
Old 09-23-2013, 06:47 AM   #595 (permalink)
The Truck - '02 Nissan GU Patrol ST
Thanks for posting that info, I made up my own spreadsheet and charts at bottom:
Originally Posted by 3-Wheeler View Post
After digging around for a mathematical solution to the posted equation by Mathematica, I came across a description of what is meant by "sin^m" listed above.
The math form below shows another way of handing the "sin^m", which is not solvable by normal means.
So now we had a way of properly solving the shape of a Tear Drop, and an excerpt is shown below. Here are the equations for X and Y:
X=COS(A10)
Y=SIN(A10)*SIN((A10/2)^$F$8)/$C$7
Where:
Increment = 0.1 (number of desired steps in shape)
A10 = cell A10
$C$7 = 1.925 (constant) used to create a shape with a 2.5:1 length/width ratio
$F$8 = M (constant)
And here is what the spreadsheet data looks like....
To solve for a shape where Y is positive, vary T from 0 to PI. To solve for a shape where Y is negative, vary T from PI to 2PI. In this case I am only interested in solving for Y in the positive state, so T is varied from 0 to PI.
Here is the original graph presented by SGT.
I'm not sure about the Y-axis units for this graph, as they do not give output of 2.5:1 for length/width.
The graph below however does indeed maintain AeroHead's 2.5:1 length/width ratio however. We have "two units" in the X-axis (-1 to +1) and one-half of the 0.8 units of width (0.4 units) shown. 2.0/0.8 = 2.5:1
SGT, thanks for posting your original graph of this shape, as it gave me the incentive to dig deeper for those who are math challenged, like myself.
Hope this helps, Jim.
I did the chart with mirror image to see how uniform shape is, I think it looks pretty good, be good if someone can overlay the templates to compare, don't have the knack of doing overlays.
The shape is more aggressive at the start, bit like new template, then it tapers back and angle begins to reduce somewhere around 75% and ultimately goes back to 0 at 100%.
Although this is not in line with template theory, I actually thinks it makes more sense.
If an object is moving through free air and ultimate aero principles is to allow air to fall back in behind it, then it is better to have a trailing edge with minimum angle rather than one where two airstreams are meeting at 44°, ie 22 above and 22 below, either way it doesn't matter much as most will not go beyond 80% and you can see at 98% it is still at 13°.
The Following 2 Users Say Thank You to Tesla For This Useful Post:
aerohead (09-30-2013), KamperBob (09-25-2013)
Old 09-23-2013, 01:00 PM   #596 (permalink)
The Following 2 Users Say Thank You to Xist For This Useful Post:
Old 09-23-2013, 01:49 PM   #597 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Originally Posted by Tesla View Post
Thanks for posting that info, I made up my own spreadsheet and charts at bottom: ......
What value of "M" did you use for the calculated shape?
It looks like the value was different than 1.0, since there is a "tail" present.
I suspect that if the tail was not there, the shape would match the "template" a little better.
Jim.
Old 09-23-2013, 04:52 PM   #598 (permalink)
Xist, thanks for overlay, the curve is definately more agressive then original template, I was thinking it is much closer to the new version below with the steeper angles at the start.
3 Wheeler, I manipulated both constants until I got exactly 2.5 aspect ratio and 1.78 tail ratio, to get this M = 1.4754408 and l/w = 1.9130000020752, the original values for the constants of 1 & 1.925 gave a tail ratio of 1.67 and yes is still increasing angle at end of tail, but does not fit template that well either.
I like this equation and will fiddle a bit more and try out different combinations, I can get a closer version with less kink in tail, but the aspect ratio is around 2.54 with a 1.78 tail ratio, so there are plenty of options to choose, later tonight I will try put up a version where the tail reaches max curvature without changing direction.
Originally Posted by betasniper View Post
Yeah, It was about a 15° angle at the end for that one because the thickness was only 35% (Eppler 863). I posted that airfoil because that was the largest symmetric airfoil I found in that database. There is a very slightly unsymmetric airfoil which is a 38.8% thickness (Eppler 864), but even that one only goes to an 18° angle.
I put the AST-2 Template into Solidworks and tried as best as I could to make a simple spline fit the Template but These are the angles I got:
Largest deviation (angle wise) was the very first angle with a 1.3° discrepancy. Everything else is within .4°. The grey dimensions are driven and Σ's are equations. Only the black Numbers without Σ can be altered (The 500 and the 23°). The blue lines above the spline represent the curvature. Bigger lines means more curve, Smaller lines means flatter.
Edit: Even though the angle discrepancy is large, the spline I drew was slightly slower curve than the template. Very slight.
Code:
Percentage
0%
10%
20%
30%
40%
50%
60%
70%
80%
90%
100%
X
0
172
344
516
688
860
1032
1204
1376
1548
1720
Y
500.00
488.92
461.69
423.61
377.54
325.23
267.81
206.09
140.62
71.81
0
Angle
6.8°
10.9°
13.9°
16.0°
17.7°
19.1°
20.3°
21.3°
22.2°
23.0°
The Following 4 Users Say Thank You to Tesla For This Useful Post:
3-Wheeler (09-24-2013), aerohead (09-30-2013), BamZipPow (10-01-2013), KamperBob (09-25-2013)
Old 09-30-2013, 05:46 PM   #599 (permalink)
overlay
It's very close.
The emphasis with the 'Template' is the aft-body contour,ignoring the front for the most part.
Once past the max. camber position,the boundary layer has no reason to remain attached unless it sees a very stringent deceleration/ pressure-rise
gradient.
As long as the contours are 'close' to the 2.5:1 streamline half-body we should be pretty safe.But it's the back we're most interested in.
Nice work!
Tesla (10-01-2013)
Old 10-01-2013, 08:20 AM   #600 (permalink)
Thanks for that, I still need to play with this equation a bit more.
I've been reading a variety of things from Semi-Truck aero through to Belbouth design for engine air intakes, but one thing that struck a chord was rocket nozzle theory.
A perfect rocket nozzle will have maximum efficiency when gass departing is at the same pressure as the surrounding atmosphere, if it is higher it is wasted energy, when it is lower pressure it creates drag.
From this, in an abstract way I started to look at template theory as an inverted rocket nozzle, the ultimate goal is to leave the air behind the vehicle completely stationary, as if the vehicle had never been there.
Maximum angle for boat tail? abcdpeterson Aerodynamics 80 11-03-2021 12:55 PM
Aerodynamic Streamlining Template Part-B aerohead Aerodynamics 8 05-31-2013 12:23 PM
LED Headlight captainslug DIY / How-to 82 11-15-2011 01:32 AM
Aerodynamic Streamlining Template: Part-A aerohead Aerodynamics 0 07-18-2009 02:37 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
