10-22-2016, 07:24 PM
#141 (permalink)
that's a ton of work Phil. I can't believe I am contemplating similar and larger projects.
Looks Good!
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
10-22-2016, 07:38 PM
#142 (permalink)
Cyborg ECU
Looks Good!
Agreed. Looks impressive. And thanks to BamZipPow too. Question (pretty basic, sorry): the soffit vent is for something aero or mostly a best aero option for heat extraction?
10-22-2016, 10:29 PM
#143 (permalink)
I've made some progress keeping the rain off; I just put up a 4x10ft skylight. Now I just need to heal it into the corrugated metal. Then I can think about kitchen cabinets or making an 8ft teardrop.
How much longer until you feel you'll be ready to reschedule Darko?
BTW, did you know? Just A Car Guy: the world’s largest salt flat is in southwest Bolivia, near the crest of the Andes
the world’s largest salt flat is in southwest Bolivia, near the crest of the Andes. Salar de Uyuni is the world’s largest salt flat at 4,086 sq mi which makes it roughly 100 times the size of the Bonneville Salt Flats.
Salar de Uyuni is at an elevation of 11,995 ft above mean sea level. The area has a relatively stable average temperature with a peak at 70 °F in November to January and a low of 55 °F in June. The nights are cold all through the year, with temperatures between 16 and 41 °F
10-23-2016, 12:13 AM
#144 (permalink)
Are you going to fill in the hole you cut around the hood extractor?
10-24-2016, 11:54 AM
#145 (permalink)
Aero Wannabe
Originally Posted by aerohead
*here is the wheel fairing package roughed in
Phil, will the pontoons be removable for testing? That could provide some interesting data.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
10-25-2016, 11:01 AM
#146 (permalink)
As well as just spats in front of the tires ,to determine how much of an impact the full boathauling the tires is.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
10-25-2016, 12:39 PM
#147 (permalink)
Phil, my only surprise is the "recurve" at the end of the tail:
10-27-2016, 07:11 AM
#148 (permalink)
Why don't rear pontoons cover wheel sides?
Wouldn't it be beneficial to move the front wheels backward to make the front of the pontoon smoother and to push the air disturbance further back?
The Following User Says Thank You to Magajgfha For This Useful Post:
10-27-2016, 08:22 AM
#149 (permalink)
Phil, my only surprise is the "recurve" at the end of the tail: (img)
I believe it will straighten out the downward airflow over the back and inward over the sides, creating a high pressure area that vectors slightly forward - so less drag.
You see a more or less horizontal 'spoiler' plane at the edge of many sloped backs, including the new Prius.
10-29-2016, 12:59 PM
#150 (permalink)
soffit
They're for heat rejection.
On hot summer days I've heard the engine fan churning away,indicating that the thermal coupling is engaged.Not good!
The temp gauge never indicated a heating problem,but if the fan is being driven by the engine,at 40-mph plus,it suggests that I've compromised the cooling.
With these hood vents,that problem goes away.They will require ducting and integration into the new blister extensions.
