01-09-2020, 05:39 PM
#981 (permalink)
The hypothetical Cybertruck needs an hypothetical Cybertrailer, obvs.
01-09-2020, 08:28 PM
#982 (permalink)
Have read about the Avion pontoon before. No, owner made those.
The Following User Says Thank You to slowmover For This Useful Post:
01-11-2020, 02:58 PM
#983 (permalink)
I have already seen bulky objects being hauled on the top of cars, but never a snowmobile (highly unusual to see one in Brazil and the overwhelming majority of the ones I have seen were electric).
07-23-2020, 11:15 AM
#984 (permalink)
I cut up and took away some small-ish branches that came down in a storm.
51 MPG US / 4.6 L/100 km
That's the worst mileage I've seen since I got the car.
The Following 5 Users Say Thank You to MetroMPG For This Useful Post:
07-24-2020, 10:04 AM
#985 (permalink)
Hypermiler
Wow.
I have a bigger trailer (5x10 ft, ~500 lb empty), but when I tow my target is 40 mpg. Sometimes I hit that, sometimes not.
Need to aero-mod the trailer!
The Following User Says Thank You to PaleMelanesian For This Useful Post:
07-24-2020, 10:31 AM
#986 (permalink)
That's quite a bit heavier! My empty trailer is only about 170 lbs. I'd be surprised if all the brush & branches added another 75 lbs.
Ideally, a much shorter tongue would tuck the load into the wake behind the car, but then again I don't think I got much above 40 km/h / 25 mph while towing.
07-26-2020, 08:13 PM
#987 (permalink)
Fusion - '16 Ford Fusion Hybrid SE
Resurrected the old Harbour Freight foldable trailer. 6.2 L/100 km (37.9 mpg) round trip. Couch on trailer for half of it.
The Following User Says Thank You to mechman600 For This Useful Post:
07-26-2020, 09:16 PM
#988 (permalink)
I'm becoming determined to build a tiny house on the two trailer axles I have. I've hatched a plot where I'll assemble the frame under the '58 Baja bug which is currently on jack stands, raise it [the car] up to apply the decking, and then raise the whole thing up off pier blocks to add the wheels and tires.
It will be a post and beam frame (mortised and tenoned) with a rabbeted plywood diaphragm bellypan and a tension cable through the center of both axles and up to the hitch end.
My big constraint is room. I want 16ft length but I only have room for 12ft.
Just throwing down a marker. When I come up with the $300 for [wood] materials I'll start a thread in Saving At Home. Based on the Modern Prairie schooner design, with a 6ft 5in floor width:
When its's done as a flatbed it can have a [fireproof basalt] canvas roll-back top
A gothic arch with the ridge a [telescoping] trolley winch so I can load canoes/kayaks in it. Sleepers on top of the plywood and filled with rigid load-bearing insulation. Probably cedar 2x6 decking but I'd like a radiant floor heat somehow.
07-28-2020, 08:32 PM
#989 (permalink)
So, you're willing to build a miniature of a Quonset hut on wheels. I like it.
07-28-2020, 09:19 PM
#990 (permalink)
Rat Racer
Post and beam is a lot heavier than Quonset.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
