Go Back   EcoModder Forum > AltModding > Saving@Home
Old 06-26-2008, 02:10 AM   #1 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
A/C Compressor Died
Well, as you may know, I installed the Cool-N-Save device a month or so ago.
There was some scale build-up, but mostly the fins were blocked by webs and dust. I usually blast water through them to keep things efficient.
04:49 PM; 92F -- The house begins to struggle to cool down. I think it's the heat wave and the stove heating things up (first 90-Degree day).
10:36 PM; 76F -- Return home from a ballgame. Indoor temp 85F.
The A/C compressor isn't running. I go out to check it out. It makes a buzzing noise every minute or so. I power-cycled the system with the same result.
After disconnecting all power, I took the fan shroud off. The fan motor was blazing hot to the touch. Further, the compressor itself was HOT. I ran cool water over the compressor and it cooled-down. No scale was noted on the internal components.
I put it all back together, gave it a shot, and all I heard was a buzzing noise and the heat builds again. ARGH! Darn thing's toast! Tomorrow will be Service call #4 in 3.5 years. The "experts" that installed the system failed to do so correctly:
  1. Forgot to completely wire the system at move in
  2. Failed to charge the system fully and/or ID a leak
  3. Found the leak and charged the system properly (after the condenser became a block of ice) -- yeah the same night my folks visit from out of town
  4. Now -- some sort of failure.
Hopefully it's a capacitor or relay -- otherwise, I don't what to think of the cost.
RH77 ("It's like a sauna in here!")
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 06-26-2008, 07:32 PM   #2 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Ford Thunderbird
90 day: 27.75 mpg (US)
I had an epiphany along those lines. I realized using an oven was heating up the house I was trying to air condition...It was a real, "duh" moment for me.
It's been around 100 here lately and I've found that I rarely need to use the A/C to remain comfortable. I open all the windows during the night and close them ~10:00am, block the windows the sun shines through, and turn off everything that uses electricity (TV, lights, computer, etc.).
I was amazed at how stable the indoor temperature was, staying ~78F. I think the A/C is a "pamper my ass" type of luxury item, but oh is it nice when it gets 79F inside.
Hopefully your A/C problems are fixed. I'd think with the humidity you guys get, you deserve a little pampering!
- LostCause
Old 06-26-2008, 08:59 PM   #3 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
- LostCause
Yeah, it's not the heat, it's the humidity
The problem is the entire back side of the house faces West. The living room is between the West windows and the Garage. Bake Oven. It got up to 90F around 5-6pm in here. Ya kinda move to a cooler locale around the house.
I got the compressor unit to run today. It's shaking like crazy and the lines are warm. The fan finally worked and the compressor, well, tried to compress -- but nothing but noise. They'll be out between 8 and Noon tomorrow The unit is still under warranty by a year, but labor isn't. I'm curious to know what the deal is. If it lost the freon again... They still use the nasty Ozone Layer depleting stuff. The changeover is supposed to happen soon (2010-ish???)
RH77
_
_
Old 06-26-2008, 09:48 PM   #4 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
So the fan was, or was not running?
I burnt up 2 fan motors last summer. I finally realized that the contact or was corroded and not providing constant voltage.
I don't know about yours but my compressor will keep running no matter how high the pressure gets; I was amazed I didn't burn it up.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 06-26-2008, 10:47 PM   #5 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
I'm not sure what fail-safe triggered the shut down. Last night, nothing was running. It just made a relay type sound every minute or so. The fan motor was hot and the compressor REALLY hot.
This morning, I thought I'd give it another go. The fan and compressor both kicked-on, but it looked an unbalanced washing machine. I saw a bit of condensation on the compressor outlet on the inside -- but it stopped at the collector (or whatever it is -- could be a reverser for the heat pump).
I hear from HVAC forums that capacitors and relays frequently fail -- especially on this cheap-O brand. Hopefully the compressor itself is fine, since that would require more labor ($ out-of-pocket) time. We shall see.
RH77
_
_
Old 06-27-2008, 09:24 AM   #6 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
You can try adding what's called a "hard start capacitor" to your compressor. They're super simple to install, two wires and you're done. If your compressor is not quite up to the task of your system, the hard start might get things going smoothly again.
I'm not sure where you'd get it, though. Johnstone is my supplier but I'm in the trades and they work with me - Johnstone doesn't generally sell to the average Joe. Look in your yellow pages under electric motors and ask around.
Old 06-27-2008, 02:26 PM   #7 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
Yep, it was just a Cheap-O GE capacitor that blew. The tech (and the other company I phoned earlier) reported several blown in our area. Lots of lightning strikes and probable surges.
Odd coincidence, my laptop's mem-stick fried on the same day.
For some reason we get several strikes in our area. The weirdest one -- hit pretty close and knocked out a clock-radio and the circuit that turns on the light for the garage door opener. Just odd, random stuff.
But ahhh -- air. The dew points were in the mid-70's last night before the storms rolled through -- then had to seal-up the house and roast. Now, there's a steady stream of "humidity" going down the drain.
Conclusion: the Cool-N-Save likely didn't have an effect on the failure.
RH77
_
_
Old 06-28-2008, 01:41 AM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
LostCause -
That sounds like Night Flushing :
Using cool night air to cool down the interior mass of a building is called Night flushing. In Hot Dry Climates night temperatures usually fall well inside the comfort range. This is why adobe buildings are so cool in desert environments. In modern buildings in hot dry climates it is essential to provide a great deal of Interior Thermal Mass.
How old is your home? Does it have good insulation?
- LostCause
CarloSW2
American Solar Energy Society
Old 06-28-2008, 01:47 AM   #9 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
RH77 -
RH77
I want to put *externel* "vertical slats" or "Japanese Shoji's" to cover our bedroom window :
It would have to be light enough to easily move, but sturdy enough to be outside 24/7.
CarloSW2
Old 06-28-2008, 01:50 AM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
RH77 -
RH77
I'm bummed about your A/C but I'm happy that you weren't "punished" for giving the Cool-N-Save a try.
Are there any additional ways you can protect your A/C from power surges?
CarloSW2
Insulating cold a/c lines? CHEGAI EcoModding Central 18 06-30-2010 12:34 PM
a/c belt clutch on alternator? thecorrupterx Off-Topic Tech 3 06-20-2008 11:14 AM
windows vs. A/C rocket Hypermiling / EcoDriver's Ed 18 05-08-2008 12:18 PM
It's not just the A/C tasdrouille General Efficiency Discussion 4 04-17-2008 11:57 PM
ATTN: METRO SWIFT OWNERS (with NO A/C) - Rear Canvas 'Flow Thru' Hatch Cover XFi For Sale 0 03-25-2008 06:59 PM
