05-18-2013, 08:01 AM
#71 (permalink)
Originally Posted by AndrzejM
I like the idea of screen saver maybe the logo of EM? ;-)
Maybe
(based on the "duck" code, it's possible to use more than 8 custom chars.)
But my plan is the time and the temp as a screen saver.
I've build in temp measurement code into my MPGuino using OEM engine's temp sensor (that one used for daschboard) because I couldn't find a good way to mount d18b20 within the coolant flow.
I want to display the interior temp, not the engine
Volkov,
Will you post your changes to the code?
Sure, as soon as I'm ready, I'll post the code here!
05-19-2013, 02:30 PM
#72 (permalink)
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
06-02-2013, 12:52 PM
#73 (permalink)
Hello all. My name is Alvin, im from Indonesia.
I just finish putting the my own MPGuino in my 96 Civic (D16Y8 i guess).
Currently I'm putting the +12V line after the ignition. Is it make the MPGuino doesn't save the last value for BIG Curr KM/L ?
I'm quiet curious if i put the +12V line directly to the battery. How did the MPGuino turn it self to off? I'm testing the MPGuino with a 12V power supply. After 7 minutes (420sec / 420000000 uSec), it just turn off the LED but not the display.
Last, im very interested to have some temperature reading in the menu. Can some one help me?
I have the code. It's really simple and just using 2x LM35 and the 1 & 2 analog pin.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
const int inPin = 1;
const int potPin = 2;
byte degree[8] = {
0b01110,
0b01010,
0b01110,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000
void setup()
lcd.createChar(1, degree);
lcd.begin(16, 2);
void loop()
int value = analogRead(inPin);
int hasil = analogRead(potPin);
lcd.setCursor(0, 1);
float millivolts = (value / 1024.0) * 5000;
float millivolt = (hasil / 1024.0) * 5000;
float celsius = millivolts / 10;
float celcius = millivolt / 10;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Intake ");
lcd.print(celsius);
lcd.write(1);
lcd.print("C");
lcd.setCursor(0,1);
lcd.print("Eng.Bay ");
lcd.print(celcius);
lcd.write(1);
lcd.print("C");
delay(500);
Can anyone help me to put this code into the MPGuino 0.81 ?
I'm still confuse with the menu thing in the code.
regards
Alvin
06-02-2013, 03:12 PM
#74 (permalink)
regards
Alvin
MPGuino works constantly that's why it's connected to constant 12V.
And if you want to have another position in menu with temp reading you just need to create another menu entry and then add proper code for that entry.
06-05-2013, 10:43 AM
#75 (permalink)
Okay. Thanks. Still figure it out for the menu.
By the way, can i use the 16x2 LCD without I2C interface for the LCD? I mean, can i just upload the 0.82 to my MPGuino? Mine using the Freeduino schematic (without I2C interface). Cause i saw you use the 0.82 version. But, i'm still unsure for the LCD you use. I'm using 0.81, everytime i'm starting the car, it always start with a zero. It doesnt save the last trip value to the EEPROM.
Tomorrow will be a holiday in here. I'm planning to put the +12V directly to the battery. After that, i want to move the LCD and the switch to the dashboard. Then, it will the time to calibrate the injector. The VSS is running well (with the 5100 for honda civic 96), although at the >100 KM/h, MPGuino showing 3-4 KM slower than my speedometer.
Thanks
06-06-2013, 05:45 AM
#76 (permalink)
I had a similar issue with data not saved to EEPROM. But the problem disappeared one day on it's own. Can't say why.
Anyway i'm using Arduino Uno board with parallel LCD, without I2C interface.
I'll upload new code to my MPGuino and make some changes to it soon, because of some customizations. I'll share the code as soon as I'll test it.
06-07-2013, 02:11 AM
#77 (permalink)
That would be great! I've been trying to put the 0.82 with Arduino IDE 1.0.4, but it tells me that i don't have the wire library or something
Anyway, my MPGuino is connected directly to the battery. After 8 hours of idling, the LM 7805 is quite hot (like 35-43 deg C). Is it normal? I'm using heatsink for the LM. I'm measuring the heatsink temp.
Thanks
06-07-2013, 03:23 AM
#78 (permalink)
Yes it can get hot, but even 50 degrees is not a problem.
If you have problem with IDE104 try to use the code changed by stargazerf3a
You'll find it here MPGuino metric v0.82 IDE 103
The Following User Says Thank You to AndrzejM For This Useful Post:
06-08-2013, 08:18 AM
#79 (permalink)
I didn't saw that
Thanks for the info
Now I'm trying the 0.82 now cause mine got a little problem.
After filling my tank, the MPGuino start to acting weird.
The character are going to ?*# something like that.
I know that i made a mistake when putting the power cause i didn't use a connector. The cable too thick, it's give me a trouble to put it in a 3-pin connector.
So, i'm going to fix it by putting a on/off switch for the -12V. So i can turn it on fast enough without damaging the EEPROM.
Hope this will be okay, cause i have to fill my tank again to calibrate it.
06-16-2013, 08:02 AM
#80 (permalink)
Like a 2CV only newer
Booboo - '06 Renault Clio 2 PH.3 LPG 90 day: 34.69 mpg (US)
I was not active last couple of month and want to say hi! have a nice summer
The Following User Says Thank You to stargazerf3a For This Useful Post:
