Old 05-25-2014, 11:21 PM   #591 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
good luck with the rebuild and getting back on track. want to see it finished.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
NeilBlanchard (05-26-2014)
Old 05-26-2014, 01:25 AM   #592 (permalink)
It's amazing what can be got away with as "additions" in some places VS the excrement one has to go through to build something all new.
Les Schwab Tires in Weiser knocked down their old main tire install building and "added on" to their old alignment shop (about the size of your garage and used for storing old tires and batteries since the newmulti-bay alignment shop was built). They only kept one block wall of the old building and the "addition" is about 5 times the size of the original.
The Following User Says Thank You to Galane For This Useful Post:
Old 05-26-2014, 02:43 AM   #593 (permalink)
I am glad that you have started picking up the pieces and salvaging all of your hard work. Good luck!
Old 05-26-2014, 08:04 PM   #594 (permalink)
It’s good to see that you once again are starting to move forward with the CarBEN project Neil. Good luck with it and I'm looking forward to the day that you’ve moved beyond where you were before the collapse.
Cheers,
Dave Bowles
The Following User Says Thank You to DFBVT For This Useful Post:
Old 05-26-2014, 08:19 PM   #595 (permalink)
It was a good day in the end - I got most of the repair gluing done. That is despite two extended rain showers, I managed to get the hatch door and the roof and sides of the chassis put back together. Only 6 small pieces remain to be glued in the floor. It is a bit scarred up, on the edges that collapsed, and where the wood framing hit.
Another big piece of the hatch:
Two pieces on the left side:
Three pieces on the right and center of the roof:
A couple more pieces on the hatch:
Last big piece in the roof:
The six pieces yet to go in the floor (plus some small bits of the hatch that got glued in, and one piece of scrap):
Several shots of everything on the top back together and drying:
The worst scar on the hatch is on the edge of what will be a window, so that will be fine. The other missing shards will have to be filled in with some spray foam.
It is almost back to where it was in early winter...
The Following 3 Users Say Thank You to NeilBlanchard For This Useful Post:
aerohead (05-28-2014), California98Civic (05-26-2014), Xist (05-26-2014)
Old 05-27-2014, 06:18 AM   #596 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
You might have to change the name of the car to the Pheonix. Your dedication to getting this thing rebuilt is commendable. I can't wait to finally see the finished product.
Aerospace Controls Engineer.
Currently driving a mostly stock 2014 Mitsubishi Mirage DE hatchback.
The Following User Says Thank You to HydroJim For This Useful Post:
NeilBlanchard (05-27-2014)
Old 05-27-2014, 07:12 AM   #597 (permalink)
The Phoam Phoenix.
The Following 3 Users Say Thank You to Galane For This Useful Post:
aerohead (05-28-2014), NeilBlanchard (05-28-2014), Xist (05-27-2014)
Old 05-27-2014, 01:16 PM   #598 (permalink)
Karmann Eclectric
jray3's Avatar
Odysseus - '00 Honda Odyssey
MR BEAN - '12 Mitsubishi i-MiEV SE
Karmann Eclectric - '71 VW Karmann Ghia Electric Conversion
BOB - '87 Ford 250 Lariat ext cab
Wink
Originally Posted by Galane View Post
The Phoam Phoenix.
CARBENstein! (complete with stitch marks and a couple of little bolts sticking out until the final paint job)
Keep up the fight, Neil- it's been quite inspirational!
2012 Mitsubishi i-MiEV, 112 MPGe
2000 Honda Odyssey
1987 F250 Diesel, 6.9L IDI, goes on anything greasy
1983 Grumman Kurbwatt, 170 kW "Gone Postal" twin
1983 Mazda RX-7 electric, 48 kW car show cruiser
1971 VW Karmann Ghia electric, 300 kW tire-smoker
1965 VW Karmann Ghia cabriolet, 1600cc
Have driven over 100,000 all-electric miles!
The Following User Says Thank You to jray3 For This Useful Post:
Old 06-22-2014, 02:46 PM   #599 (permalink)
I have a small update - I had hoped to do more; but I ordered 25 yards of 38" wide 8.9oz S-glass from US Composites last week and it arrived Thursday. I used a can of low expansion (urethane?) foam on most of the gaps and cracks (some from the damage and some that didn't glue well) and that's where it sits, now.
I trimmed off the excess with a hacksaw blade, and it looks to be very sturdy foam. I will rasp and then sand it down. I'm thinking I will fit the windshield and the wipers, and then start to 'glass the roof and the hatch door.
Xist (06-23-2014)
Old 06-22-2014, 11:20 PM   #600 (permalink)
Are you going with wood glue or polyester resin?
