Old 02-07-2011, 08:26 PM   #11 (permalink)
Mighty Mouse - '93 Honda Civic VX
90 day: 43.3 mpg (US)
Tank - '03 Infinity G35 premium
90 day: 22.24 mpg (US)
I will look into it for sure. The car is a good candidate for the Fed conversion right now because it's doing the infamous part throttle hesitation. I'm debating whether to do the conversion now or just swap in the standard 4 wire 02 for the moment. This way I could have a baseline to compare from when I actually do the swap.
Old 02-09-2011, 10:04 PM   #12 (permalink)
Patina - '80 Vespa P 125x
90 day: 67.27 mpg (US)
nonya - '00 honda insight
Gen-1 Insights
90 day: 67.62 mpg (US)
I have the fed model vx. passed smog in california twice no problem.
Old 02-09-2011, 10:24 PM   #13 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
Good data point, thanks! How long ago was the last time it was smogged?
Old 02-10-2011, 12:10 AM   #14 (permalink)
Gen-1 Insights
It was originally Smogged around Oct 2008, and then they made me smog it again for some reason last time I had to do my registration, which was last october(2010) i believe.
Old 02-10-2011, 02:45 AM   #15 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Smog is biennial in CA for most people.
Old 02-16-2011, 09:14 PM   #16 (permalink)
Originally Posted by NachtRitter View Post
My philosophy when doing the conversion on my car was to do a completely reversible conversion, in case I needed to convert back to the Cali version (with narrow band O2 sensor and Cali ECU) for either smogging or for selling the car, or in case I foinked up the work. Folks that don't have this concern may find it easier and faster to chop up the stock wiring to get things connected the way they want. These instructions are not for those folks.
Could you shed light on how to do this? Is it a matter of hacking the harness at some point between the shock tower and the 02 plug (so only one plug is needed) or would I need to create a 2 plug harness from the shock tower to the sensor?
Old 02-17-2011, 01:11 AM   #17 (permalink)
NightKnight
Subaru
Diesel
Since I haven't done it, the best I can do is give you vague guidelines... basically get the wiring diagram out and cut & splice so that the 5-wire O2 sensor connects to the correct pins on the ECU. How that is accomplished is going to be up to the individual.
Old 02-17-2011, 02:03 PM   #18 (permalink)
TomO provided a nice image of the wiring diagram which showed the 4-wire O2 sensor and the 5-wire O2 sensor side-by-side:
Thanks, do you have this wiring diagram still? It's not coming up
nevermind. Found it
Old 02-22-2011, 01:34 PM   #19 (permalink)
Found all the plugs I needed at the local Pick your Parts on Friday and made the harness this weekend! Now I'm just waiting on my A00 ECU and L1H1 to come in the mail! Will post pics soon
Any advice on pulling the carpet down so it doesn't get messed up? I want to do it as clean as possible...
Old 02-24-2011, 04:19 PM   #20 (permalink)
I got my 5 wire L1H1 sensor today but it looks like pins 3 and 4 are missing. Is this right? I'm confused now.
How will D22 via pin 3 and D3 via pin 4 receive signal?
5-wire o2 sensor, ca to fed conversion, civic vx
lean burn rules~! coolwHip Introductions 42 10-01-2011 05:42 AM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Craigslist Milwaukee: '97 Civic HX lean burn love MetroMPG For Sale 0 02-05-2009 04:02 PM
VX lean burn Nden DIY / How-to 11 12-05-2008 09:01 AM
