Old 05-03-2018, 11:48 AM   #101 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Originally Posted by mpg_numbers_guy View Post
That's good...how easy is it to install? I know that's kinda relative but...
Is it possible to work the other way and have the O2 sensor failing in that it runs leaner instead of richer?
On my Insight, I can get to both the sensors just by reaching down behind the engine. On your D17A, the exhaust is on the front of the engine rather than the back, so I'd expect it to be very easy. Just unplug the old sensor from the wiring harness (connector might be stiff), use a large crescent wrench to break it loose, unscrew and replace. It might be wise to put a bit of anti-seize on the threads when putting the new one in.
As for lean vs rich, I'm not sure.
Old 05-03-2018, 11:52 AM   #102 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
The upstream and the downstream sensors are both really easy. Upstream is on top of the exchaust manifold and downstream after the catalytic converter. You need a wrench and hands. The ratchet or wrench should be of the open type, like a crowfoot. Careful removing the clips for the harness, which are close to the sensor itself. The plastic gets brittle. You DEPRESS the tab to release the lock on the connector. You do not pry it loose. You have the manual?
westb87 (05-03-2018)
Old 05-03-2018, 01:50 PM   #103 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
Seems fairly easy. Should I replace it now or wait until later? My second trip today was 49.9 mpg (day average of 49.2 mpg) so it really isn't affecting my MPG....still want to know how I got only 29.4 mpg on that one trip yesterday..
I have the basic user manual, but not the in depth repair guide manual though.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
Old 05-03-2018, 02:16 PM   #104 (permalink)
https://www.civicforums.com/forums/1...e-updated.html
Old 05-03-2018, 02:35 PM   #105 (permalink)
No idea what I'm doing
westb87's Avatar
Sleek - '04 Honda Civic Coupe LX
90 day: 36.38 mpg (US)
Broomstick - '18 Volkswagen Atlas SE w/ Tech & 4Motion
90 day: 21.66 mpg (US)
The Denso O2 I bought for my D17A had a little squeeze packet of the copper colored high-temp anti-seize in the box with the sensor.
Sleek (2004 Honda Civic LX Coupe, Auto). The Commuter
Broomstick (2018 Volkswagen Atlas SE w/ Technology & 4Motion All-Wheel Drive), Auto 8-speed with "Tip-tronic". The Family 'Wagen...also the weapon of choice of the "Wicked Witch of the Wests" a.k.a The Wife.
Old 05-03-2018, 02:37 PM   #106 (permalink)
westb87's Avatar
Well that route last night is known to get really bad mpgs (I never got above 30 before hypermiling) and I usually get in the 30s (I did get 45 once) but 29.4 is just terrible.
O2 sensor isn't dead yet; I managed 48.5 mpg for the first half of my driving today.
And yes my car does the same thing - one moment I'm cruising at 55 mpg and the next it jumps to 65 mpg without any change in elevation or anything. There's one stretch where I can average 70 mpg for about half a mile on completely flat terrain both ways.
If only though lol.
That sounds complicated. I might consider that but for the most part I'm happy with the MPGs...except for those occasional bad trips...but 29.4 last night lol...I could go 80-85 mph and get that.
I drive my Civic about 25 miles daily so taking off the road for longer than a few hours isn't really practical.
I thought about it and I'm still considering my SG2 to be lying to me until I calibrate again. I'm at 290 miles on this tank and I've used just the first tick-mark past a half tank of fuel. If that's about 6 gallons, I'm at 48mpg right now. Won't know for sure until I fill up, but I'm hoping! I ran a bottle of Redline SI-1 into this tank before filling up, so I'm wondering if it helped to "clean" combustion chamber/valve/injector deposits which are helping to free up some extra MPGs. Have you run any fuel system cleaner through your Civic since you've gotten it?
Old 05-03-2018, 02:53 PM   #107 (permalink)
Team Mazda
The download links on the site didn't work for me.
The fuel tank is 12 gallons used right on E (1.2 mile reserve). One tick past halfway is 11/20 marks, so theoretically you've used 6.6 gallons. 290 miles on 6.6 gallons is 43.9 mpg. However this estimate is generally 1-1.5 mpg optimistic for me at fill up. Like my tank now per Torque shows 45.2 mpg (and Torque has been within a quarter of a mpg accurate) when if I base it on the gas gauge it'd be closer to 47 mpg.
Get going on your Scangauge!!
I haven't run any fuel system cleaner in the Civic yet. Most people I've seen do it haven't noticed any benefit for the cost.
Still getting comments on my car's ecomods...one of my classmates laughed at the idea (he gets 10-15 mpg out of an '07 Saturn Vue) but my response is always that I'll be the one with money in my wallet at the end of the day.
Old 05-03-2018, 03:08 PM   #108 (permalink)
Try again at night.
Old 05-03-2018, 08:08 PM   #109 (permalink)
Team Mazda
Try again at night.
I'm getting the NXDOMAIN error on Google Chrome opening it, which means that the download website is no longer in existence.
Old 05-03-2018, 10:16 PM   #110 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
You’ll always have folks poking fun at your ecomods, but you won’t spend nearly as much as them in fuel... I had a co worker recently advise me that he would just “be happy to get 30”, and that’s cute IMO... only in severe cold, with a misfiring cylinder, did I ever drop below 30mpg lol...(like 25-27)
My current Ecotec project...
My last Ecotec project...
7th gen civic, automatic transmission, build thread, civic auto, honda civic
