03-31-2015, 02:56 AM
#251 (permalink)
OK I'm going with mileage > ~150k or if not advertised, or salvaged, then not posting. Also mpg of 33 mpg or better is good.
2004 Cavalier - $1500
2004 Cavalier in excellent condition... 4door 5speed manual transmission.... Has 51,000 miles... engine and transmission are excellent... clean title... call
2001 Hyundai Accent
Runs Great. The car has a new clutch, clutch slave cylinder, clutch master cylinder, and throwout bearing, rack and pinion, new drive axles, new catalytic converter, and the oil and transmission fluid has been changed recently and regularly. The windsheild is a year old. The tires are brand new. The radio is missing but the heater works good. Registration is current and has had no probems passing smog. I have all the reciepts to prove the maintenence. $1500 obo. Pink slip in hand. Call Andrew at
1997 saturn sl2
I really hate to get rid of this car but I have a lot of bills coming up. So I have a 1997 Saturn sl2 clean tittle stick shift no grinds or pop out, Shifts good with 155,000 miles. It has the service engine soon light I think it's the O2 sensor. Tags till Jun 2015. I did the smog check last year so you don't have to do it again this year. Runs good very reliable car. Takes me from west Covina to Ontario 5 days a week.
RECENTLY REPLACED:
Brake master cylinder
valve cover gasket
spark plugs
spark plug wires
front brake pads
belt tensionar
New battery
Air filter
03-31-2015, 03:09 AM
#252 (permalink)
5 Gears of Fury
I never thought I'd say this, but that Cavalier looks like a deal. An 11 year old economy car with 51k miles is a good start. They aren't particularly good cars, but with miles that low, you can forgive them a lot. If the mileage is true then I'd go look at it if I needed a cheap set of wheels, you could do a lot worse. And you can get parts for those things at the bulk section of your favorite grocery store haha, one of the easiest and cheapest cars around to fix. Just my 2 cents.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
03-31-2015, 07:48 AM
#253 (permalink)
Originally Posted by User1
I'll start using that site to check. Would be great if all the cars were listed in one huge list, that had them listed 1 to whatever on their mpg performance, huh?
I go by the highway results, hope that's not cheating
Those are some of the best deals I have seen anywhere regardless of the highway mileage and in California no less, where rust is generally not an issue.
regards
mech
03-31-2015, 08:39 AM
#254 (permalink)
Rat Racer
Originally Posted by Old Mechanic
Those are some of the best deals I have seen anywhere...
It's going to be the trend for a while:
US gas prices near 6 year lows: guess what that means for the forum!
Originally Posted by elhigh
Start warming up your checkbooks, boys. Flyweights are gonna get cheap.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
04-01-2015, 08:10 AM
#255 (permalink)
Vader - '15 Dodge Grand Caravan 90 day: 23.13 mpg (US) Cmax - '13 Ford Cmax SEL 90 day: 40.92 mpg (US)
I got over 200k out of my '96 Cavalier until it threw a rod. Also never switched over to green coolant fwiw.
04-08-2015, 06:28 AM
#257 (permalink)
04-08-2015, 08:35 AM
#258 (permalink)
How would you fix the bottom of the bumper on that Prius? My friend's Altima is like that.
04-08-2015, 08:39 AM
#259 (permalink)
Title status says "parts only". Not sure about MI but in Va that means it can never be titled again. Probably some damage from the impact that got the front bumper.
xist, they make two part body repair epoxies that will hold those parts together as long as nothing is missing.
regards
mech
04-08-2015, 11:13 AM
#260 (permalink)
low miles Sentra
This is the first car I've seen in a while that has really caught my interest:
'95 5-speed, 1-family car with only 118k kms / 73k miles! And the ad says it's been rust-proofed, which is critical for a car that old around here.
I'm unclear on the highway MPG. It's either 34 or 36.
Too bad the paint's so oxidized. That's rare to see up north.
For Sale By Owner
Year 1995 Nissan Sentra
Kilometers 118000
Transmission Manual
Mom bought the car new in '95 and gave it to me in '07 for the kids when they started universtity. Both are finished school and car is no longer required. It is driven daily to work, very reliable and cost effective to operate and maintain. Gets 27 plus mpg in the city and 40 plus mpg on the highway. Very reasonable to insure. Exceptionally clean inside and out. Does not burn a drop of oil between changes and has been maintained regularly since new including Krown protection. Car is ready for paint. $1500 cert, e-test and painted (black as I have the paint) or make me an offer.
1995 Nissan Sentra Coupe (2 door) | used cars & trucks | Kingston | Kijiji
