Old 08-09-2010, 03:34 PM   #51 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
Awesome job!!
Old 08-10-2010, 08:27 AM   #52 (permalink)
Sedan - '95 Honda Civic DX
90 day: 50.67 mpg (US)
Optima SX - '12 Kia Optima SX
90 day: 33.28 mpg (US)
Thanks! Only took me junking 2 other clusters until I figured out a way that I liked... lol
Old 09-15-2010, 10:47 PM   #53 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Some nice installs! This inspires me to reconsider where I'll put mine. It's still naked in front of the instrument cluster...
Old 10-29-2010, 06:07 PM   #54 (permalink)
EG6 - '93 Honda Civic Si
There are great ideas here. Props to all of you. I will start this project soon.
Old 11-10-2010, 03:32 AM   #55 (permalink)
Originally Posted by ben98gs View Post
Just got done installing mine last night. Still have to calibrate it and hook up the switches, but I think it turned out pretty good:
Love your install!! Looks factory.
Old 11-10-2010, 06:59 AM   #56 (permalink)
Thanks, took some time to get right, but I definitely like the way it turned out too.
Old 11-30-2010, 07:52 PM   #57 (permalink)
The Odyssey - '98 Honda Odyssey
90 day: 24.45 mpg (US)
The Civic - '98 Honda Civic DX
90 day: 32.5 mpg (US)
First I have to say, thanks guys for inspiring me with all your creative solutions. MPGuinos are so much fun!
Here's one for the Metro lovers - in dash installation!! Super slick.
You can do it too, if you're not scared of messing up the cluster. Oh BTW- this DOES mess up the cluster, meaning irrevocable damage done. But if you screw it up, the non-tach ones are only 20-30 bucks, don't worry. Go for it!
Super-quick how to:
1)Starting with a Geo Metro instrument cluster, no tach. Mine has no lights in the center. Remove from car.
2) Open the casing, measure, mark, cut, until you have enough room:
3)Doesn't fit yet? Repeat step two......Lather, rinse, repeat.
Should end up like this:
Hope this helps someone.
Old 10-26-2011, 10:36 PM   #58 (permalink)
JJMunoz's Avatar
Seriously? II - '02 Honda` Insight
90 day: 67.94 mpg (US)
Endearing Fuel Gulping Box - '08 Honda Element EX
90 day: 32.18 mpg (US)
Talking 1994 Civic DX MPGuino Cluster Install
So I got my MPGuino in the mail the other day and decided to install it in the cluster like I saw on another civic on this forum a while ago.
I have a 1994 Civic DX with a 1994 Si cluster installed.
This is a picture of the one I saw.
I had no experience with silicon boards so this was a first time thing for me.
So of course, the first and most logical thing to do would be to tear the switches off the MPGuino since I wasn't going to be using them, right?
Yikes.
I tore them off and realized the solder and old pieces of switch weren't going to come out of the board.
So my first experience in soldering was installing 6 wires on the board ( I didn't realize the front of the board was a common ground for all 3 switches), which came out pretty good!
I soldered wires onto 3 switches and put connectors on the end of them.
Then I embarked on grinding away the cluster.
The front portion of the cluster came out good right away.
I cut the bottom of the plastic face on the tach around the bottom of the 8k rpm line.
The mistake I made was using the 1994 DX cluster (without tachometer) and trying to fit the MPGuino in there, thinking the two casings of the DX and SI clusters were the same.
Wrong.
I realized this when I pulled the SI cluster out my car and tried to fit the MPGuino in it and the MPGuino was pressing against the bottom of the tach.
My second problem was that this guys MPGuino was separated into two boards and not two boards glued together like mine.
I had this space discrepancy of a little over an 1/8" to take care of.
This is where my nightmare began because I had to cut a shield off the bottom of the tach and grind down the plastic base of it, which in the Honda tuner world would probably be considered complete sacrilege,
and I had to grind down the MPGuino board, just to fit it on an angle in the cluster ( You can see the grind down point next to the two red connector covers in the picture.).
I heard the MPGuino gets hot so I drilled ventilation holes in the top of the cluster.
I had to grind away portions of the cluster backing for the wires to pass through and a portion of the plastic to the bottom-right of the tach to fit the MPGuino properly.
I drilled 3 holes in the right side of the cluster cover for my switches and began installing it in the car.
The leads on the civic are as follows:
- Green and Black are +12v and Ground as it says on the MPGuino wiki.
- The Cylinder #1 Brown Injector Wire in the engine bay is your injector lead, NOT the brown wire coming out of the first connector in the ECU.
- The only yellow and blue wire coming out of the ECU is your VSS lead. It's in the middle connector of the ECU.
I ran the power off an unused hot at all times terminal in the fuse box and the ground off a bolt near my clutch pedal.
The VSS lead is easily hidden under the carpet but the injector lead was a little harder to hide. This was how I did it. :/
After all said and done, it came out pretty nice.
It was scary, but successful.
The Following 3 Users Say Thank You to JJMunoz For This Useful Post:
Cd (05-05-2012), ECONORAM (06-25-2012), NachtRitter (05-09-2012)
Old 10-26-2011, 10:49 PM   #59 (permalink)
JJMunoz's Avatar
I just realized ben98gs is the one whose gauge I saw, so thanks to him for that!
Old 10-27-2011, 06:55 AM   #60 (permalink)
Looks great! Glad I could be some inspiration as it fits about perfect there when all is said and done.
Where did you end up mounting your switches?
Something to note if you do not want that wire showing through the engine bay... I tapped into the fuel injector lead at the PCM since it is already inside the cabin. Do not remember if I did the same with the VSS or not (slept a few times since then... lol)
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
STUFF HAPPENS TV Show bennelson The Lounge 2 10-17-2008 10:05 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
Change a thread title? wagonman76 Forum News & Feedback 3 06-27-2008 06:40 PM
