09-06-2016, 03:36 PM
#271 (permalink)
Originally Posted by Bill the Engineer
Brace yourselves...
Then I mounted the Firebird radiator support to the brackets. (It is the part that holds the front of the fenders in place, and where the hood latch parts are mounted.)
It was an EXCELLENT DAY!!!
Bill the Engineer
Most Excellent Bill!
That's awesome seeing the Firebird nose on there.... but the picture I left in your quote shows quite a lot of misalignment of the Firebird radiator hole and the Prius radiator. Are you planning some sort of ducting there to help with cooling?
Reason: Reviewed my copy of 'Grammar for Dummies'.
The Following User Says Thank You to darcane For This Useful Post:
09-06-2016, 05:50 PM
#272 (permalink)
home of the odd vehicles
Originally Posted by darcane
Most Excellent Bill
If he's an ecomodder its probably apart of his grill block
The Following 2 Users Say Thank You to rmay635703 For This Useful Post:
09-06-2016, 07:32 PM
#273 (permalink)
Cyborg ECU
You are the hero of the ancient slavic stories, on an impossible quest to find and capture a firebird none have seen.
The Following 3 Users Say Thank You to California98Civic For This Useful Post:
09-06-2016, 08:48 PM
#274 (permalink)
Actually the core support is about an inch too high in that photo. I realized after the bumper was on that I had left the old rubber supports on the bottom that should have come off first. (D'oh!)
And yes, there will be both ducting and bracing between the Prius structure and the Firebird core support, plus the original baffling between the core support and the front bumper assembly.
Bill the Engineer
The Following User Says Thank You to Bill the Engineer For This Useful Post:
09-06-2016, 08:51 PM
#275 (permalink)
Cool. At least some of my ancestors are Slavic too. (Bohemian)
Bill the Engineer
09-11-2016, 06:40 PM
#276 (permalink)
Mostly a clean up weekend so I could walk through the garage without tripping on anything.
I'm still uneasy about the added length to the nose, but I don't see any way around it since the bumper brackets are already only an inch away from the frame lifting points on the Prius v.
Bill the Engineer
09-11-2016, 06:52 PM
#277 (permalink)
What about a 69 nose? Do they have a bit more room?
The Following User Says Thank You to Hersbird For This Useful Post:
09-11-2016, 11:48 PM
#278 (permalink)
Nope. The '69 was basically the same car face-lifted. It even uses the same hood.
Bill the Engineer
09-12-2016, 12:55 PM
#279 (permalink)
can you shorten the brackets for the nose mounting?
Bill
It's hard to tell from the photos, but it appears the nose could move back at least 4-5 inches. Is there a way to shorten the bumper brackets, or another point where they could be attached to the Prius frame? From what I can see in the photos, it appears the prius frame mounts are even with the radiator/hood mount, but the bumper mounts extend out another 8 inches. Could you modify the nose to mount in a different way to the steel frame at the front of the car (by the radiator)? Perhaps even a couple of steel angles welded horizontally across that metal front piece could give you a different mounting point to use.
With the extended nose, you might be able to borrow some styling cues from the Dodge Superbee. https://en.wikipedia.org/wiki/Dodge_Super_Bee
The Following User Says Thank You to jgatl For This Useful Post:
09-12-2016, 03:26 PM
#280 (permalink)
Experienced UAW Mechanic
2.5 pages in, I realized you missed your calling in life. Both the musclecar lover in me and the Prius-hating genius in me say this is the most perverted concept ever, but somehow you manage to present it in such a way that i keep reading the next post, then the next, and so on. I will post again after i read the rest of it, then sleep on that.
The Following User Says Thank You to cosmick For This Useful Post:
