Old 07-08-2012, 08:50 PM   #421 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Wow.
Why isn't this on the front page of the site ???
This is by far one of the most impressive project cars on this site.
The Following 2 Users Say Thank You to Cd For This Useful Post:
California98Civic (07-08-2012), Flakbadger (07-09-2012)
Old 07-08-2012, 08:57 PM   #422 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I'm not going to go back and re-read several pages to see if anyone asked , but ....
is there any way you can insure your work ?
Have you taken any molds of the tail in case some knucklehead smashes into you ?
And with a mold, I can see others being interested in some sort of DIY kit for Insight owners.
( I know I would be interested if I had an Insight .)
The Following 3 Users Say Thank You to Cd For This Useful Post:
California98Civic (07-08-2012), sheepdog 44 (07-08-2012), Sven7 (07-08-2012)
Old 07-08-2012, 10:27 PM   #423 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Man, a fiberglass mold, some mounting hardware and lighting, and you'd be in business! Make back that money you spent on bondo
Old 07-09-2012, 04:38 PM   #424 (permalink)
2000 Honda Insight
Hey, you mentioned me, cool. It was great to meet you at the Stevens Point MREA energy expo. I asked all the question that I wanted to ask but am still curious about the 'maximum sustainable lean-burn speed'. It's perplexing to me that you haven't tested this but I don't blame you as you do have your goals. I keep remembering back to my trip that I took from Rapid City, SD to where I live nearby Minneapolis, MN. 630 miles and got 73mpg holding lean-burn the entire time at the maximum speed that lean-burn allowed which on the flat was around 70mph and any uphill it went down but downhills I could get the maximum speed to hit the PSL of 75mph in SD with the ability to exceed the PSL but of course I don't exceed the speed limit as there are 'enforcers' who probably patrol the web. I had another driver drive the car and LB runs in 5th gear up to 78mph before the RPM is too high and it kicks out at any TPS and LOD value on my scanguage so that's the top speed that I'd ever drive if I drove in TX with the highest speed limits in the nation that exceed the 78mph point. Either way I'll remain curious and hope that you test higher speeds, if not just the interstate PSL in WI for what MPG you'd get. ...anyway do what you wish but I drive cross country and the curiosity tortures this cat.
Old 07-19-2012, 10:30 PM   #425 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
No I have not made any molds of the body work. Sorry.
Actually I learned more about foam/fiberglass/water based products such as water based spackling.
The tail started the summer very smooth in finish but not yet painted red to match the car. Well after painting red, we had some very hot June days, and I'll bet the surface temperature of the red paint was close to 150°F or so, and that heat reacted with the spackling, and caused some "puffing" in spots.
Now because of this, to make high quality molds, the entire surface would have to be pain-stakingly sanded and smoothed over the span of the summer.
Well this won't happen this summer as my wife and I just finished putting a sheet metal roof on the house, and we still have some bathroom work to do, so guess what takes the back seat?
I would also like to put a trickle charge plug under the tail to make it easier to charge at night, and this will hopefully happen this fall sometime.
Anyway, the simple answer is no, there are no immediate plans to make molds at this point.
Jim.
Old 07-19-2012, 10:36 PM   #426 (permalink)
3-Wheeler's Avatar
Well we know that the tail offers about 18% better aero at 56 mph, as tested two years ago (or was it three?) when the tail was first put on the car.
I typically do not drive at any speed close to 55 mph on the way to work, so I can not answer that question directly.
However, I can say that on the way to Stevens Point, I did get 105 mpg on the way there and 97 mpg on the way back, and this is with no under body panels at all during that time.
The panels were off because I had to get a wheel alignment and the garage wanted everything off. Plus, upon removing the panels after two years, there were several very rusted fasteners that simply broke off when removing the panels. I spent several days trying to work out and/or drill out the fasteners to make room for new ones.
As you know, the temperature that day was probably 90°F or so, maybe hotter, and that really helps the mileage.
Jim.
Old 07-19-2012, 10:47 PM   #427 (permalink)
3-Wheeler's Avatar
AeroHeads Latest Streamlining Template
I still am not completely satisfied that we have adequately addressed how to duplicate the Streamlining Template, especially for those of us who need to render this shape for tails on our cars.
To help determine how to duplicate this shape, I downloaded the "C" version, straightened the "road surface" in a photo editor, then placed that copy in a 2D CAD program, and started working.
The first picture shows the "C" template with some geometry applied. You can see that a radius of 5.64 times the height of the car body provides a very good curve fit of the aft curvature down to 21° slope.
This is a closeup of the curve fit to AeroHead's rendering. Very close indeed.
I would have to say, overall this method gives a very close fit to AeroHead's standard.
Jim.
ID:	11181   Click image for larger version
ID:	11182   Click image for larger version
ID:	11183   Click image for larger version
The Following 3 Users Say Thank You to 3-Wheeler For This Useful Post:
BamZipPow (07-20-2012), California98Civic (07-20-2012), euromodder (07-20-2012)
Old 07-19-2012, 10:58 PM   #428 (permalink)
The boat tail looks very good, it almost looks as if it came from the factory that way.
The Following User Says Thank You to 2006Corvette For This Useful Post:
3-Wheeler (07-20-2012)
Old 07-20-2012, 04:41 AM   #429 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Now there's an easy way to get a good curve fit !
The same can be done in plan view.
Old 07-20-2012, 11:56 AM   #430 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
That is a great way to look at the shape. It is nearly spherical.
Do you think that if the front is not as good as the ideal image that we might need to be more conservative and use a 6 or 7 d shape?
I am thinking of my 86 jetta with it basically being a box with very little radii on the front.
Did I miss you tuft testing your tailbox?
Noah Webster, 1787
FS: All USED Honda Insight Parts For Sale Fabio For Sale 17 06-16-2013 02:49 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
Project: Zombie Insight (2000 Honda) RobertSmalls Hybrids 191 03-03-2012 06:35 PM
Designing a tail extension for the first-gen Insight RobertSmalls Aerodynamics 187 07-11-2010 10:44 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
