Old 01-25-2019, 10:40 AM   #251 (permalink)
Originally Posted by rmay635703 View Post
My Volt has a max of about 50 miles driving normalish with 10.5kwhrs available
If you are going 100 miles you are likely using more than 15kwhr of juice
Duh!
Wasnt comparing ranger to electric ghia, was comparing battery packs based on incomplete picture of back seat using swag engineering back estimating what the pack was.
15 kwh is 50% more than 10kwh so 75 miles in a volt is an acceptable napkin equation which I indicated
Ranger also goes 40 miles in the flats using a 2011 volt pack. Cd is brick shaped which affects freeway range significantly.
Old 03-07-2019, 07:14 PM   #252 (permalink)
Hoopie
Hoopie's Avatar
https://youtu.be/pY9BFGreHM0
Doors are finally on.
The Following 4 Users Say Thank You to Hoopie For This Useful Post:
freebeard (03-07-2019), HHOTDI (03-07-2019), RedDevil (03-08-2019), Xist (03-07-2019)
Old 03-07-2019, 10:11 PM   #253 (permalink)
Rapturee
HHOTDI's Avatar
Sippy2 - '15 Honda NC700XD DCT
90 day: 59.51 mpg (US)
Shorty - '02 Ford F150 XL
coming along nicely!! :{)
Old 03-14-2019, 05:21 PM   #254 (permalink)
Hoopie
Hoopie's Avatar
https://youtu.be/Z9EA4u8O7b8
Dashboard and gauges.
The Following 2 Users Say Thank You to Hoopie For This Useful Post:
Daox (03-16-2019), freebeard (03-15-2019)
Old 03-14-2019, 06:09 PM   #255 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Looking good!
My current Ecotec project...
My last Ecotec project...
Old 03-15-2019, 12:20 AM   #256 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Cool view line to the cluster... incognito almost.
Old 03-15-2019, 12:43 AM   #257 (permalink)
Let's hope you don't need to get to those strut mounts after it's welded back together.
"We're deeply sorry." -- Pfizer
Old 03-16-2019, 01:06 AM   #258 (permalink)
VFAQman
talonts's Avatar
Or ANY of the Prius stuff from the dash forward.
Getting to the dash harness, the HVAC, the HUD, half the engine wiring, looks to be extremely difficult if the front isn't made to be removable, with weather-tight covers under it.
Tom Stangl
* http://www.vfaq.net/
* Prius Visual FAQ Home
* 04 Prius AM #7
* 06 Prius NL #7
* http://www.vfaq.com/
* DSM Visual FAQ home
* 90 Talon AWD Turbo
Old 03-16-2019, 11:53 AM   #259 (permalink)
Hoopie
Hoopie's Avatar
Removable front clip.
I’m working on a way to remove the front clip. Thinking of creating “A-pillar” inserts. That way if I need to get into the deeper repairs, I can remove the windshield and detach the A-pillars. Seems like a lot but I just changed the thermostat in my son’s 2002 Passat and it was a nightmare. Search it on the google. Service position, what a joke. I’ll share pictures of my plan soon.
freebeard (03-16-2019), Xist (03-19-2019)
Old 03-17-2019, 11:35 PM   #260 (permalink)
I don't remember where I saw pictures of a Karmann-Ghia with a removable front clip. But since the body panels are not nearly as stress members as they would be in an unibody, it might not be too hard to turn the front clip into a tilt single-piece for easy access.
