Old 04-18-2008, 03:33 PM   #21 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I'd suspect killing the fuel pump would be more likely to trigger a CEL than killing the injectors (another guess)
How about finding the power for the odometer, and adding a tank circuit?
Do you guys know we have made this WAY to complicated?
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 04-18-2008, 03:36 PM   #22 (permalink)
DMC - '99 Honda Civic DX
Originally Posted by RH77 View Post
Duh, why didn't I think of that!
Oh, maybe because...
  1. It won't immediately kill the engine
  2. As the engine dies, you're killing it by running lean, and
  3. Then you need to build the pressure back up for the EVAP can.
Have you tried it?
RH77
1. It does immediatly kill the engine because I have pressed the gas after and there is no noise and the scangauge goes dead...
2. This is not some performance engine where's it's making 600hp and needs to be tuned so it won't run lean...it's not like i'm flooring it to redline and cut the engine. I press in the clutch let the rpms go down to idle and cut the engine.
3. What pressure???
Besides what do you think happens when you park your car and turn the key to the off position??? I do exactly the same thing except I do it while driving...
Old 04-18-2008, 03:39 PM   #23 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
If hypermiling was easy, everyone would be doing it
The trick is, we have a variety of models, years, etc. with the same requirement: Streamlining the process, without CELs.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 04-18-2008, 03:45 PM   #24 (permalink)
I have never gotten a CEL doing this and even if I do get one the scanguage will take care of it...
Old 04-19-2008, 12:10 AM   #25 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
May work for you...
But I definitely have some sputtering issues sometimes after killing the fuel pump.
Makes sense, kill the pressure in the fuel line and there'll still be some residual pressure in the lines that will have to be released by the injectors. Resulting in injectors firing after the switch is thrown. More so if the gas pedal isn't depressed (engine idling) when the switch is thrown.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 04-19-2008, 12:30 AM   #26 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
3. What pressure???
1. Perhaps on your engine... mine sure doesn't (ditto my last car) And that's weird you SG goes dead - I'll add that to the list of reasons I'd prefer not to go that route (my SG stays live with spark cut)
2. emissions
3. pressure: colloquial for vacuum pressure
When I turn my key off - my ECU cuts fuel and spark, some solenoids close etc...
RH77 got it spot on
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 04-21-2008, 01:52 PM   #27 (permalink)
I think I may have a solution that will work best for me. I can cut the ignition wire in the steering column, add a 12v10A SPDT relay, and run it to a button switch by the parking brake to activate the relay. I would still prefer a time delay relay to make things easier, but that can come later.
Compaq888, I'm not ignoring your solution, but since I can't reset error codes with a ScanGauge ('95 model year ), I would like to avoid the possibility of throwing a code at all. I have also used a fuel cut-off switch on an old truck that could run Gas, or Propane, and it could go for 1.5 blocks before the gas totally ran out. Granted that engine had a carb, and this is FI, and my logical brain does know the difference, my emotional brain wants nothing to do with it. I like that you have found a solution that works for you though.
*Time period is from 1 January 2006 - 1 March 2007*
Old 04-25-2008, 10:33 AM   #28 (permalink)
Blue - '77 Chevy P/U
how much is a engine kill going to gain you ??
Old 04-25-2008, 10:46 AM   #29 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
Killing the engine while coasting is an advanced technique that should only be learned away from traffic, and it's not suitable for every car.
That said, you could expect gains of about 10% if you consistently shut the engine off where you currently let it idle while stopped and when coasting.
Old 04-25-2008, 11:00 AM   #30 (permalink)
wow 10% seams high for just cutting out idle , how about re-start ?
oh i mean rolling idle
DIY: Push Button Start SVOboy DIY / How-to 20 07-10-2014 09:43 AM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
