Old 02-04-2014, 01:49 PM   #171 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
Thanks xntrx!! That's very cool stuff. Consider me signed up for that!!
Yea the failsafe on the fords is if the ecu sees above 4.5 volts from the signal side of say the tps or map, the ecu will cut the injectors just enough to shut the engine down but still show noid. This I very useful info in diagnosing ford no starts of that vintage. It will have noid, spark, good fuel pressure but won't start unless you introduce Gas down the intake. Then it's either fuel volume/quality or a sensor. In which case I start unplugging sensors one at a time and see if it starts. Or you could manually ground a couple injectors while a buddy cranks it.
Don't mean to ramble, hopefully someone might find it useful
Burn lean and prosper \\ //
Old 02-04-2014, 05:49 PM   #172 (permalink)
Too busy for gas stations
Superfuelgero's Avatar
Turtle - '92 Honda Civic Vx
90 day: 67.09 mpg (US)
Rolla - '10 Toyota Corolla Le
Beast - '91 Chevy V2500
Bus - '01 VW Eurovan MV
Speed - '93 Harley bored and storked Harley w/ turbo/ nitrous
90 day: 53.09 mpg (US)
Cal - '68 Ford Mustang GT/CS
Thanks guys. This is at the end of the list due to potential of drivablility issues on a dd. Its a long list also, but I will post progress.
Originally Posted by mechman600 View Post
Remember when the engine is off, compressing a full cylinder of air is like compressing a giant spring. So all the effort required on the compression stroke is returned on the [ex] power stroke when this giant spring pushes back down, resulting in a net power consumption of zero. Minus friction, heat, etc.
Exactly. The concept is from motorcycles, where engine braking during shifts is not desired. Historically this has been done through slipper and sintered clutches. Now, the ECU's are being programed to stay slightly open to reduce engine braking. Hopefully the software and controls will bleed over, and we can extend it to full WOT.
This should improve narrow window of speed P&G in tighter traffic, and remain legal (since EOC is not in some areas).
Shooting for 600 miles of range at 65-70 mph out of a vx.
Old 02-04-2014, 06:47 PM   #173 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Then automate EOC. Hybrids are legal. :P
Old 04-11-2014, 09:28 PM   #174 (permalink)
Part 5 with results
Old 04-11-2014, 10:03 PM   #175 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
So what is the message we are suppose to take from this journey?
They created a car that no normal person can obtain reasonably. They spend thousands of dollars on parts, hours on intensive labor, and stripped the car down to something no one wants to live with on a daily basis. All for a result that many many people here achieve year round with nearly stock cars, with cheap DIY parts like garden edging.
I would completely understand it if they chose to implement driving techniques. At that point it would be a battle for max MPG, no matter what the cost. Instead they made it sound crazy to drive under the speed limit, but it's fine to custom build carbon doors and body panels to save a few pounds. So what the average person takes away from this story is that it's cool to spend a lot of time and $$$ on a custom car for good MPG, but it's not cool to simply improve your driving and achieve the same results.
1998 Honda Civic HX - My Project Thread
The Following 4 Users Say Thank You to cbaber For This Useful Post:
Bugzilla (04-11-2014), niky (04-12-2014), oil pan 4 (04-13-2014), tvbd56 (04-12-2014)
Old 04-11-2014, 10:42 PM   #176 (permalink)
Mr. Bean - '95 Honda Civic VX
90 day: 67.13 mpg (US)
Big White - '00 Ford F-250 4x4 Super Duty XL
90 day: 12.66 mpg (US)
For less than the cost of the doors on their car my VX avg 58 mpg with only one mod. The nut behind the wheel.
Old 04-12-2014, 12:42 AM   #177 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 39.03 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
I agree with what your saying, but I do love the idea of them bringing awareness of fuel efficiency to the younger crowd. Now I would like to challenge them, and have them show what you can do by implementing fuel efficient driving techniques to this vehicle? This would be awesome, to bring some attention of saving fuel to a their already younger captured audience.
Fuel efficient mods opens the door to their advertising supporters. This could be the next big business for the import suppliers if the would just create a already needed demand for fuel efficient products aero mods, LR tires etc (not snake oil crap)
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Bugzilla (04-12-2014)
Old 04-12-2014, 06:14 AM   #178 (permalink)
Burning oil to move air.
ausiasmobil - '06 Seat Leon 1.9 TDI Reference
90 day: 40.22 mpg (US)
EcoTxec - '99 Skoda Octavia 1.9 TDI 110 cv Laurin & Klement
90 day: 52.85 mpg (US)
they need to increase the horses to get good fuel economy with taller gearing and the other very smart and cost effective mods:
and also instead of painting the car they need to wrap the car in carbon because this will increase the apparent performance.
Sold:
Old 04-12-2014, 10:51 AM   #179 (permalink)
Too late!
We met our goal and look forward to transforming our fuel sipper into a pure street machine.
http://www.importtuner.com/features/1402_1992_honda_civic_vx/
Superfuelgero (04-12-2014)
Old 04-12-2014, 11:08 AM   #180 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Too late!
Ahhh Crap!!!
Oh well you can lead a horse to water but you can't make him do you dishes.lol
$$$, civic vx, fartcan muffler, import tuner, project sipper, ricer
