Old 01-13-2025, 02:21 AM   #541 (permalink)
Originally Posted by pgfpro View Post
Got the FE modified intake mock upped. This Intake has the N20 system I use for FE to increase flame speed during extreme Lean-Burn 30:1. I'm going to use this during the drive part of Drag and Drive events. Then switch out the intake, injectors and T/B as a whole to the race manifold injectors and large T/B. Also, when I'm daily driving it or street driving during a Drag and Drive event I'll be using the rear 16-gallon pump gas fuel cell.
Also added front vertical bars to the front fenders. After calculating the down force, it had me worried so went ahead and added these bars. Once again, their mocked up and will have grade eight bolts and an added .1875 steel backing plate.
That looks like some really nice fabrication craftsmanship pgfpro.
I assume those suspension arms aren't plain old mild steel? Chrome Molly of some sort?
It looks like your intercooler is going to be behind the coolant radiator?
That doesn't seem optimal?
I love to see what the turbo intake looks like without the air filter.
Any Bell Mouth action there?
It's nice that you have all that extra space to work in/with.
pgfpro (01-13-2025)
Old 01-13-2025, 09:56 AM   #542 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Thank you.
You guessed it right. The arms are Chrome Molly.
The air to water intercooler will have an insulator wrap later in the build. I also run ice water in which the passenger side cell will hold the ice water. The ice water only last about 9.0 seconds on full wack before all the ice is melted. The air to water also has a second use during FE mode in which the water with no ice will be around 200*F IAT temps. This involves an exhaust heating coil.
The large 88mm turbo intake pipe will have one of my PGF crankcase pressure systems. It will have a two-stage water/oil separator. First stage water separator and the second stage an oil coalescing filter. It will also have a PGF N2O system with a 45* vortex nozzle.
The space is really nice but there is an issue with the hood and it not opening very far that is not sitting well with me. I think I'll ditch the hood hinge springs and modified the hinge to open almost straight up and down? The engine sets way back and it is a paint to get to now.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
Logic (01-13-2025)
Old 01-13-2025, 11:24 AM   #543 (permalink)
Thank you.
Man! I wish I could see all this with my own eyes!
Are you pulling a vacuum in the crankcase?
Or is this ...er... more complicated, involving 'intake and exhaust' reed valves?
Ye getting at stuff and wishing you had 4 arms is a feeling I know all too well!
Finding someone with the gumption to lend hands that do the right thing and anticipate the required tool to pass etc is near impossible.
The bit of bonnet I can see looks interesting too?
pgfpro (01-13-2025)
Old 01-13-2025, 05:21 PM   #544 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Yes, pulling a small amount of vacuum. Pretty much a simple system that starts at the cold air intake pipe between the air cleaner and turbo with a 10AN line that go to an oil scrub then to the water trap and oil separator that goes to another oil scrub at the top of the valve cover.
It does take a minimal amount of HP but it doesn't amount to much when on full wack.
Logic (01-14-2025)
Old 01-15-2025, 01:01 AM   #545 (permalink)
Just Video I think you'll enjoy on how and where to get metal (Inconel, Titanium, etc) parts 3D printed and the whole series is just damn good engineering and fabrication in general.
IMHO a 13B Rotary in an (overheating) BMW i8 is a great idea and it fits fortuitously well.
Also, assuming you're still thinking about that acetone powered combined heat and power (CHP) system for your home, this guy has some info on open source electrics etc.
pgfpro (01-15-2025)
Old 01-15-2025, 09:48 AM   #546 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Once again you killed it on information. Thank you so very much.
I do have a lot of people asking to replicate my setup for their car and a truck. This could be my answer.
One more thing I'm looking at building a team moving forward. I would like to definitely include you. I will send you a PM later next month.
Logic (01-15-2025)
Old Yesterday, 07:21 AM   #547 (permalink)
I'm glad you found the info so useful pgfpro.
I look forward to the PM!
pgfpro (Yesterday)
bio fuel, lean burn, turbo compound
