Old 06-27-2008, 08:18 AM   #11 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
thanks for all the comments & ideas guys!
I'm thinking about doing a trap door with reusable body panel clips for an access window to do the oil changes...but i need to get some more coroplast first
the engine heat should funnel right out of the center, maybe i should leave it open...?
i used self tapping screws to install it, but i predrilled the holes in the metal body first...made it go faster, up front, its just screwed into the factory tray that goes from the air dam to the radiator, the rest was in the frame like rails, or channels in chassis, so no screws popping into the carpet, or other important stuff
mileage is down, but not of this, cuz my parents used the car to run around in for like the first 1/2 tank of gas, then i just beat it the rest of the week, this new tank, i should really see numbers as i plan to return back to hypermiling/driving
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 06-27-2008, 08:51 AM   #12 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 50.48 mpg (US)
Boy that looks slick. Super, super slick. I gotta do that.
Old 06-27-2008, 09:23 AM   #13 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
Wow that looks really great. I need to find a sign shop around here and get some coroplast NOW. I need to figure out how to manage this engine heat first though. I'm having huge issues right now with the front air dam I built causing my fan to come on constantly and that's without any sort of partial or full belly pan on the car, only a lower grill block, top one is open. I might try removing the center section of my middle block to see if that helps any. I think the belly pan might actually help, because I get the feeling the cold air coming in is actually just leaking out the bottom the way it is now, the tray might help keep cool air in.
But looks great, can't wait to see new versions.
Old 06-27-2008, 12:51 PM   #14 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Cool, looks great! Id like to see the results.
Not sure about the engine heat, but I would have at least the same open area for exit air as you do for inlet air.
Someone mentioned about oil change access which is a good idea. One other thing I would do is to locate the AC evaporator drain and make it so it can drain out the bottom.
Winter daily driver, parked most days right now
Summer daily driver
The Following User Says Thank You to wagonman76 For This Useful Post:
mcrews (11-03-2009)
Old 06-27-2008, 01:05 PM   #15 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Well, you helped me make my material decision! I found an ad on craigslist for free old 18"x24" coroplast election campaign signs, so I'm picking up 100 from the guy tomorrow. I figured about 50 will be enough for a belly pan, grille block, wheel skirts, and partial kammback, and I might want to re-configure a second revision later.
You should try to find some old campaign signs or boxes or something for your trapdoors - I'm sure you can find them.
Mine won't look near as nice as yours, but it will be cheap and crappy like my car! - only the cost of duct tape to seal them together!
I hope you have to do some driving... we're all anxious to see any coastdown/mpg gains!
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 06-28-2008, 12:38 PM   #16 (permalink)
Whitey - '05 toyota corolla LE
90 day: 28.91 mpg (US)
Send a message via AIM to blackjackel Send a message via MSN to blackjackel Send a message via Yahoo to blackjackel
how did you get it so flat and smooth? How did you attatch it to your underbody?
Old 11-03-2009, 12:23 AM   #17 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Greg,
Very nice job!!!!
I went to the link of where you work.......
TWIN REAR TURBOS ON THE CTS - V CADDIE!!!!!!!
How fast will that thing go???????
I have seen a DIY 1999 InfinitiQ45 w a single rear turbo. But that caddie is IMPRESSIVE!
Old 11-03-2009, 09:08 PM   #18 (permalink)
recession proof rebel
k.civic.f4i's Avatar
geez higher than 265 degrees? kinda off topic but where can i find coroplast that size? what stores would have it?
Old 11-04-2009, 08:53 AM   #19 (permalink)
Hi,
You can get 4'x8' Coroplast at a sign shop. I paid $20 for a sheet at a local sign shop.
Old 11-04-2009, 09:31 PM   #20 (permalink)
thanks neil. i figured so.
Chrysler Expected To Kill Models, Bring Italian Vehicles Ashore Jammer The Lounge 17 06-26-2010 07:29 PM
Underbelly clean up Phase II EXPIOWA Aerodynamics 3 04-29-2009 01:23 PM
Underbelly smoothing options Sunwapta Aerodynamics 17 11-08-2008 01:41 PM
2007 Dodge Caliber: The Drive DifferentPointofView EcoModding Central 0 06-19-2008 07:58 PM
Dodge ZEO BEV sports car cfg83 General Efficiency Discussion 0 01-16-2008 10:55 PM
