Old 06-05-2010, 03:44 PM   #521 (permalink)
I changed all serialWrite and serialRead for Serial.write and Serial.read but now the problem is "Sketch too big; see Arduino - Troubleshooting for tips on reducing it.".
Binary sketch size: 15494 bytes (of a 14336 byte maximum)
Anyone is having the same problem?
Old 06-05-2010, 04:49 PM   #522 (permalink)
Do you have Atmega328 chip?
youre out of memory
Old 06-06-2010, 09:41 AM   #523 (permalink)
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
Are you sure you are using OBDuino32K.pde and not the original one?
2013 Hyundai Sonata Hybrid
Old 06-06-2010, 10:04 AM   #524 (permalink)
I have an Arduino Duemilanove that has a ATmega168 (the normal one).
Compiled with the latest version (Arduino v0.18)
EDIT: I compiled with my old version of Arduino v0.12 (with Serial.write, serial.read instead of that is in the code) and I had a success to send the code without going over limit.
Thanks, not trying to solder that little chip of the iso... soo freaking small haha
Old 06-06-2010, 12:13 PM   #525 (permalink)
1) I have build the whole setup and uploaded the code. When I plug in into the USB I see ISO 14... Failed. So I know that the code work and the LCD can light up.
2) When I try with the car, the LCD doesn't even raise up. I have check the the Multimeter (I am newby) and if I put the probe to the 9v and to its ground I see 0.785 (I have put the Multimeter to 20). When I try to check the 5V of Arduino the number are very small!... seem to be a power problem somewhere...
Edit: I have plug a 9v battery instead of the power of the car and the LCD open but I have a message that it fails. It seems that the problem is between the car and the electronic because 1) not enought power 2) transmission fail.
If anyone have some tips I will be glad to hear.
Old 06-06-2010, 07:05 PM   #526 (permalink)
OBDuino coder
Magister's Avatar
Make sure you have the 12V from the car on the OBD2 plug and that it goes to the Arduino?
Old 06-07-2010, 09:26 AM   #527 (permalink)
I have check the pin of the OBD2 and I have all pin like you guys.
If I put a wire direct in the pin of the power and the ground (Pin 1 and 9):
I have 0.7 Volts... I do not get it why it's not the full 9V
It doesn't even open the LCD cause I guess the power is not enough.
Old 06-07-2010, 10:09 AM   #528 (permalink)
OBDuino coder
Magister's Avatar
Pin 1 and 9 are on the RS232 port (DB9 plug, like a COM port), try to take a measure between pin 5 and 16 directly on the OBD2 plug under the dash?
Old 06-07-2010, 06:20 PM   #529 (permalink)
I have some measure from the OBD2 plug.
If I take the Multimeter:
pin 7 has 12 volts
pin 14 has 4.73 volts
pin 16 has 0.44 volts
pin 4, 5, 12, 9 = 0 volts
why it's not the pin 16 like you?
I have a CIVIC LX 2003...
Old 06-07-2010, 08:39 PM   #530 (permalink)
OBDuino coder
Magister's Avatar
wow no clue, it's a 2003 so it must be OBD2, did you try a scangauge or an ELM327 interface from someone else?
pin 16 must be 12V, this is very strange...
obd2
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1061 01-17-2020 01:37 AM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Vacuum gauge problems :( DifferentPointofView Instrumentation 3 05-14-2008 11:04 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
