Old 02-01-2016, 12:37 AM   #2561 (permalink)
PaulH
MPaulHolmes's Avatar
I found a significant error for the PI loop, but it only showed its ugly head in the PMSM case. The Leaf motor works SOOOO much better now.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
thingstodo (02-01-2016)
Old 02-01-2016, 09:47 PM   #2562 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by e*clipse View Post
Paul, thingstodo -
Is the net current between the AC motor and the battery pack flowing into the battery at all times during regen? If not, it's more of "reverse torque" than pure regen - does it switch modes?
If so, (if it does reverse) what happens with the current near 0 rpm?
E*clipse
The data shows approximately where the energy that the AC controller is regenerating from the AC motor is not enough to run the AC controller, and the High voltage pack begins to use power again. Between 1100 and 1200 rpm. Below 1100 rpm the motor takes power.
First test
https://youtu.be/GWUgdRVXpCs
Second test
https://youtu.be/PQRFHKEAPIU
Log files 18 5, 18 6 plus spreadsheets .. all attached .. as a 2 zip files .. because they are too frigging big.
The Following User Says Thank You to thingstodo For This Useful Post:
MPaulHolmes (02-01-2016)
Old 02-01-2016, 10:27 PM   #2563 (permalink)
Update for Jan 18, Check AC voltage output from AC Controller
https://youtu.be/ShSbnuXRANk
Update for Jan 18, Max out Regen current
https://youtu.be/vNbh6GT2Jsw
Old 02-03-2016, 05:26 PM   #2564 (permalink)
Jan 31 update
I tried again to get over 360 AC Amps, with a freshly-charged Lead-acid pack.
Log file and spreadsheet attached.
https://youtu.be/GR2rcev1Mlo
The Following 2 Users Say Thank You to thingstodo For This Useful Post:
Astro (02-04-2016), MPaulHolmes (02-03-2016)
Old 02-03-2016, 05:53 PM   #2565 (permalink)
PaulH
Is it just me, or was that freaking awesome? I'm surprised that there are no occasional overcurrent trips. Things seem to be pretty under control. Oh that just makes me so happy!
kits and boards
Astro (02-04-2016)
Old 02-04-2016, 02:42 PM   #2566 (permalink)
AC Customs car builder
S10 - '99 Chevy S10 Base
90 day: 23.5 mpg (US)
Purple People Eater - '95 Geo Metro LSi
90 day: 34.76 mpg (US)
Volt - '14 Chevy Volt Premium
90 day: 1680 mpg (US)
I can't wait to get my leaf motor up and running. I'm excited. Seems like everything is going good on the test end.
The Following User Says Thank You to WindyDrew For This Useful Post:
MPaulHolmes (02-04-2016)
Old 02-04-2016, 06:51 PM   #2567 (permalink)
Dreamer
Same here, except with a rewound industrial motor.
It is all sounding very positive.
My build is still a work in progress so i am in no hurry for Paul to ship my controller.
It is much more useful where it is letting Paul and thingstodo squash software bugs.
It also shows how solid the hardware design is that it has survived all the testing without failure.
Well done.
The Following 2 Users Say Thank You to Astro For This Useful Post:
MPaulHolmes (02-04-2016), WindyDrew (02-05-2016)
Old 02-11-2016, 04:20 PM   #2568 (permalink)
Hello guys, I'm trying to build this board (thank you so much for making this open source Mr. Holmes, such kindness) but I have a couple of questions worrying me:
1.I have Lem La 100-p current sensors at hand and these things require +-15V supply voltage.If I connected these to the circuit with 5v and ground would they work like yours?(like 2.5V at 0A and ~5V at max current)
If not is it possible to make an external circuit that will make the sensor reading the same format with it?
2.Is it possible to replace 5x22uF MLCC ripple smoothing capacitors feeding bjts with single 100 uF electrolytic aluminum-tantalum ones with the polarity in mind or would reverse transients blow up these ones? If it is possible what were the reasons for choosing 60 pieces of relatively expensive capacitors?
and finally
3.If I supplied the dc bus voltage from a rectified high power 3 phase transformer with no ground connection and 24V from AC-DC converter fed with same grid would it cause a isolation & short circuit fault?
Would you enlighten about these issues? Sorry for being a pain in the neck
Old 02-11-2016, 05:44 PM   #2569 (permalink)
Received my controller today from Paul. Plan on writing a instruction guide with pics as I put my race car together. Thanks
The Following 3 Users Say Thank You to WindyDrew For This Useful Post:
Astro (02-12-2016), mora (02-12-2016), thingstodo (02-11-2016)
Old 02-11-2016, 09:56 PM   #2570 (permalink)
AWESOME! If you would like someone to critique/comment on the instructions - I am available!
Paul - what do you say to an official release version number? Change the firmware from 1.00 to .. 1.1? 2.0? Make no other changes and post the source and executable, schematic files, etc on your web site?
Do you have a revision number for the instructions? Maybe 2.0?
Astro (02-12-2016)
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
