Old 03-17-2011, 01:52 PM   #4471 (permalink)
jackbauer's Avatar
12" x 6" pre drilled for 4 of the powerex cm400du-12f igbts , 4 mounting holes and 2 ports for cooling fluid.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 03-17-2011, 02:32 PM   #4472 (permalink)
ReVolt Enthusiast
Originally Posted by MPaulHolmes View Post
I'll send stuff to Mark.
Hey Paul,
You can email me the new files, and I'll post it on the wiki as soon as I can.
-Mark
Old 03-17-2011, 03:05 PM   #4473 (permalink)
EvEagle
Did someone say “water cooled IGBTs”?? This is what I’ve been working on. The white tape shows the 3/8” drilled coolant path in a ¾” aluminum plate.. It has 3, 300Amp IGBTs, and 16, 75Amp 1200V Hyperfast Diodes. The 4400uF caps are 300V..
Paul do you have any more of the IGBT driver boards?
[/IMG]
Old 03-17-2011, 03:07 PM   #4474 (permalink)
EvEagle
Old 03-17-2011, 03:09 PM   #4475 (permalink)
EvEagle
Old 03-17-2011, 03:15 PM   #4476 (permalink)
EvEagle
Old 03-17-2011, 03:28 PM   #4477 (permalink)
My, edown, what big capacitors you have. Jack, what is your heatsink going to be made of? Aluminum, stainless, copper, or other?
Old 03-17-2011, 06:24 PM   #4478 (permalink)
hi, i'm new to the forum but i'm looking to build a healthy motor controller with more than enough power to do whatever needs to be done. I'm running a warp7 dc series motor on an electric snowmobile conversion, and need a new motor controller. ideally i'd like to run as much as 400 volts to the motor controller, and then limit that to a max of 170 volts out to the motor. i haven't yet read all of the pages here but i'm sure someone has talked about this already, if one of you could kindly point me in the right direction. i guess what i'm asking is what all would i have to change in order to operate the controller with a 400V max instead of 144. to me it seems like this would mostly be a change in the power board of the controller, by switching to components that can handle a higher voltage.
-isaac
Old 03-17-2011, 06:50 PM   #4479 (permalink)
You're not looking at a minor modification to the power board, you're looking at an entirely new power board design.
Not to be a downer, but where the hell are you going to put 400V worth of batteries on a snowmobile? That's a lot of stuff in a pretty small package. Unless you're planning to use C cell batteries and only go a few miles.
Old 03-17-2011, 08:41 PM   #4480 (permalink)
EVVette - '71 Chevy Corvette Coupe
-isaac
Isaac,
Running 400V and reducing to 170 would be pointless unless you are using batteries that sag by 60%. You would most likely not need to go over 250V to always get 170 at the motor and nothing lower.
As for going higher then 250V, you will need to redo the power board at the minimum to increase the isolation gaps or else you will have problems with the high voltage humping the gaps.
If you want high voltage, you will be better off going with IGBT modules.
Are you riding the sled long range or doing something like grass drags?
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
