Old 10-31-2011, 05:15 PM   #51 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Originally Posted by mcrews View Post
got one during the day......
Very nice and stealthy. Thanks for all the how-to photos. I will copy this on my car next spring. What was the best method of cutting the polycarbonate? Jig saw?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
mcrews (07-11-2016)
Old 10-31-2011, 07:10 PM   #52 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
cocylist,
thank you!
yes, a jig saw. fine blade.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 02-24-2012, 12:28 AM   #53 (permalink)
mcrews's Avatar
I made some edits in red to correct or update infor.
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-14-2012, 10:39 AM   #54 (permalink)
Originally Posted by cfg83 View Post
mcrews -
Your skirt reminds me of this one :
Frankfurt 2007: Mercedes-Benz F 700 revealed
CarloSW2
Why doesn't the wheel skirt go all the way to the bottom of the rear bumper and the bottom of the side skirt ahead of the wheel? Is the way they did it more aerodynamic? Is it just for looks?
Also, you can use a heat gun to mold plexiglass and lexan. I saw you used clamps which probably worked fine, but if you get it in the shape you want and heat it up, it will kind of conform permanently to that new shape.
Those look very nice BTW and has inspired me to do the full moon hubcaps and then rear skirts on my civic hatch.
Old 04-14-2012, 12:50 PM   #55 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
steffen707 -
I don't know but I will speculate that it's an aesthetic choice because the angle follows the character(?) lines of the bumper (upper white line) :
I think they could have gone down to the lower white line in the above picture, but the tire is starting to jut out more because the body of the car is tapering inward :
I made a similar aesthetic choice for mine :
That's not a pure side picture, but I think you can see that I am angling it upwards (ha ha, kicking it up a notch).
CarloSW2
American Solar Energy Society
Old 04-14-2012, 02:06 PM   #56 (permalink)
mcrews's Avatar
there comes a point where the lower you go, the more tire exposer your having to deal with. which translate into curving out from the body. the braking of the flat plane then will create turbulance at those points.
(All this of couse is 'imho')
ECO MODS PERFORMED:
First: ScangaugeII
Old 04-14-2012, 02:17 PM   #57 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
mcrews -
Yeah, that sounds right to me.
CarloSW2
The Following User Says Thank You to cfg83 For This Useful Post:
mcrews (07-11-2016)
Old 04-14-2012, 02:22 PM   #58 (permalink)
why doesn't
Looking at the rocker panel,it seems like they've extended the panel downas low as they dare before it strikes the tire sidewall.If the rocker panels were more flush with the outer face of the tires,they could have continued them down as with their C-111 III of 1978.
Old 07-11-2012, 11:44 AM   #59 (permalink)
ERTW's Avatar
Bu - '08 Chevrolet Malibu LS
90 day: 32.29 mpg (US)
The top half of the tire is spinning against airflow - this is what we don't want. The bottom half of the tire is spinning with airflow - so there's little to no gain. Hth
Old 07-26-2012, 10:11 AM   #60 (permalink)
Like a 2CV only newer
stargazerf3a's Avatar
Booboo - '06 Renault Clio 2 PH.3 LPG
90 day: 34.69 mpg (US)
Love you skirts ! i was thinking to do the same on my Clio. Did you notice any changes regarding the road noise?
The Following User Says Thank You to stargazerf3a For This Useful Post:
mcrews (07-11-2016)
q45
