Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 08-18-2014, 06:07 PM   #81 (permalink)
Thanks for keeping this topic in front of people.
Originally Posted by Old Mechanic View Post
Google transonic combustion for the next generation of fuel injection. Mixing air and fuel outside of the combustion chamber is a recipe for KABOOOM!!!!!!
regards
Mech
Maybe you should start a discussion thread to see if we can foment action and build on the idea.
I went up to look at Transonic's Camarillo facility a while back. I agree with you that their technology is going to allow Internal Combustion Engines to compete much longer in the market place than naysayers would like to admit. In-cylinder emission control possibilities as well as improved thermal efficiency make the idea a winner. However, Transonic has not been able to leverage the idea into a rapid market penetration and profitability. This means their implementation of a heated injector tip will become soon available to all. Of course we can play with the idea well before that for our own personal benefit and for readers of the forum.
And you are correct that fuel mixing before the combustion chambers has its flaws. But not to any greater problem than carburetors and injection systems have.
Old 08-18-2014, 08:49 PM   #82 (permalink)
Originally Posted by RustyLugNut View Post
It doesn't provide anything constructive and reflects badly on you.
The claim was made that I have no practice experience and that I don't leave my living room.
He started it, I finished it.
Why don't you put down others on this forum who use nothing more than duct tape and cardboard to mod their cars? How about the pie tin and coroplast crowd? Are zip ties allowed?
I love those guys. They don't come on the aerodynamics forum with extraordinary and inconsistent claims.
Are you capable of mirror TIG welding a back shielded stainless tube/plate joint that will be visibly, ultrasonically and occasionally X-ray inspected? If you can, I know a project engineer at Fermi Labs who has just fired the third guy who said he could do so.
Actually I don't tig weld and I have never tried it.
I have passed bend tests with fcaw, gmaw in flat, verticle and overhead and smaw in flat. I think that's decent since I have never been a full time weldor.
I have mig welded with titanium. Its a lot like welding stainless, but with more prep work.
Pgfpro is doing both.
And he looks good doing it.
a system that will reduce wasted energy upstream.
I just don't like how with a gasoline engine you are always fighting isobaric expansion. Your pumping losses at the throttle body are going to be around 2 horsepower on a small 2.0L 4cyl engine and there are lots of really complex ways to try and reduce this. Or you can go with a tiny sub 1L engine and run it wide open, but then you are limited to sub 1L power, okay for a car, not useful in other applications.
I would rather just eliminate the isobaric losses all together.
Old 08-18-2014, 09:40 PM   #83 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
This is my thought process on how and why I built my hot air injection vapor system.
After reading about "Smokey Yunick's Hot Vapor Fiero" I thought that there must be some truth to utilizing fuel in a vapor form.
Today's DI test engines are now seeing major improvements in a fuel vapor form, and as Mech as mentioned "transonic combustion" has improved even more on this by adding a fuel heater to help with the DI soot problem. So the questions now is how does a back yard mechanic get there.
My pour test in the above pics, showed me a few things. The biggest visual is the distillation curve of today's pump gasoline is way different then yesterdays. The very slow evaporation rate of the pump gasoline stands out big time!!! So I had to do some fact finding on what and why is today's fuel so slow to evaporate.
GASOLINE REQUIREMENTS AND PROPERTIES
In order to maintain top road performance and best fuel economy gasoline must be formulated and blended to provide:
Good mileage under all driving conditions
Fast starts
Rapid warm-up
Smooth performance
Minimum engine maintenance
There are three major factors which govern the performance characteristics of gasolines:
Volatility
Anti-knock quality
Deposit control
Volatility
This is a measure of the tendency of a gasoline to change from a liquid to a vapour. The distillation curve (Diagram A-1) of a gasoline is an indication of its volatility and is obtained by a distillation test (ASTM D-86). Another measure of gasoline volatility is its Reid Vapour Pressure. RVP is a measure of fuel vapour pressure at 38°C under specified conditions (ASTM D-323). It is largely a measure of the butane content of the gasoline.
There are a number of performance characteristics affected by volatility:
- Cold starting
- Vapour lock
- Fuel system icing
- Warm up and acceleration
- Economy (especially short trips)
- Combustion chamber deposits
- Crankcase dilution
2. Starting and Vapour Lock Protection
These gasoline properties are directly opposed and it is necessary to strike a compromise in the interest of over-all fuel performance. Starting ability is controlled by the Reid Vapour Pressure and the front end of the distillation curve. (10 - 20 - 30% temperatures) Fortunately, during the winter months, when quick starting is important, it is possible to blend in adequate front end volatility for starting without exceeding the desired vapour lock protection temperatures. (As shown in Diagram A-2)
Conversely during the summer months, vapour lock protection becomes important, and the somewhat less volatile gasoline distributed in the warm weather provide this protection without sacrificing starting ability. Spring and fall call for careful adjustment of front end volatility to make the best compromise.
It should be kept in mind that there is an exchange between RVP and front end distillation values and that vapour locking tendency should not be judged by RVP alone.
Gasoline volatility is adjusted seasonally. For optimum performance in all gasoline engines, it is best to use fuel which is blended for the season in which it is used.
3. Engine Warm-Up and Acceleration
The effect of fuel volatility on engine's performance is quite marked and is related to the 50% and 90% evaporated temperatures (or to the % at 100°C and 160°C). In general, the lower these temperatures are, the faster the engine will warm up. This is because once the engine starts, the temperature of its induction system must rise to a point where sufficient gasoline is vaporized to obtain good mixture distribution to all cylinders, and to permit full throttle acceleration without hesitation or "bucking" without choke. This is defined as warm-up time.
The trend has been towards lower 50% and 90% temperatures, since the motorist readily detects good warm-up and acceleration. Another advantage of a low 90% evaporated temperature is the reduced tendency for crankcase dilution.
4. Fuel Economy
The carburetor or fuel injection air-fuel setting has a major effect on gasoline consumption. If it is richer than necessary the consumption will be high. The general relationship between air-fuel ratio, power and fuel economy, is illustrated in Diagram A-3.
The driver and driving conditions are important factors in fuel economy. Also the useable energy content of the fuel is significant. The higher boiling components have higher energy contents per litre, thus the backend of the distillation range is a measure of the energy content of the fuel. However, the higher boiling components contribute most to crankcase oil dilution and to some degree to combustion chamber deposits. A compromise between economy, oil dilution, and deposits is necessary.
Surveys show that about 2/3 of all driving consists of trips of 10 kilometres or less. For such short trip driving, particularly in winter when engine temperature is lower, the more volatile fuel with a greater mid fill volatility gives greater economy.
5. Anti-Knock Quality (Octane Number)
Increasing the pressure of the fuel mixture in the combustion chamber before ignition helps to increase power of an engine. This is done by compressing the fuel mixture to a smaller volume. Higher compression ratios not only boost power but also make for more efficient power. But as the compression ratio goes up, knocking tendency increases and the anti-knock value of the fuel becomes critical.
The octane number of a gasoline is a measure of its anti-knock quality or ability to resist detonation during combustion. Detonation, sometimes referred to as "spark knock" or "ping" can be defined as an uncontrolled explosion of the last portion of the burning fuel-air mixture due to excessive temperature and pressure conditions in the combustion chamber. Since detonation creates shock pressure waves, hence audible knock, rather than smooth combustion and expansion of the fuel-air mixture, it results in loss of power, excessive localized temperatures, and engine damage if sufficiently severe.
There are two commonly used methods of determining the octane number of gasoline, the Motor Method and the Research Method. Both use the same type of laboratory single cylinder engine, which is equipped with a variable head and a knock-meter to indicate knock intensity. Using the test sample as fuel, the engine compression ratio and the air/fuel are adjusted to develop a specified knock intensity. Two primary standard reference fuels, normal heptane and iso-octane, arbitrarily assigned 0 and 100 octane numbers respectively, are then blended to produce the same knock intensity as the test sample. The percentage of iso-octane in the blend is considered the octane number of the test sample. Thus, if the matching reference blend is made up of 15% n-heptane and 85% iso-octane, the test sample is rated 85 Motor or Research octane number, according to the test method used.
The test conditions for the Research Method are less severe than for the Motor Method. Accordingly commercial gasolines have a higher octane number by the Research Method than by the Motor Method.
Both ratings are required to predict the performance of the gasoline in actual road usage, but the relative importance depends on the type of engine and operating conditions. In truck and farm equipment operation where the gasoline must perform at high temperatures and under maximum throttle, the Motor Octane Number (MON) is more significant than the Research Octane Number (RON). Similarly in passenger cars with automatic transmissions under full and part throttle the Motor Octane Number (MON) is more significant, particularly in engines of recent manufacture. In passenger cars with manual transmissions at full throttle where the engine can be loaded at low engine speed the Research Octane Number (RON) is more significant than the Motor Octane Number (MON), while at part throttle the reverse is true.
Road Octane Number is the rating of the gasoline in terms of reference fuels, by a test car under full throttle acceleration from 10 to 50 mph. However, Road Octane tests are too expensive for routine testing and are reserved mainly for special octane requirement surveys. An approximation may be made by calculation of the average of Research and Motor Octane Number:
(RON) + (MON)
2
This calculation is known as the Anti-Knock Index and correlates with a gasoline expected "Road" Octane Number requirements.
For our purposes in keeping our members better informed, the Anti-Knock Index is perhaps the most important reference to Octane. The Anti-Knock Index is commonly referred to in vehicle operator's manuals and is on gasoline pumps in the U.S., by law.
There are a number of factors that affect octane requirement in addition to compression ratio (as shown in Diagram A-4):
Another important fact to know in regards to anti-knock quality is that nothing is gained or lost by using gasoline of higher octane quality than required by the engine in the whole range of its operating conditions. The full value of higher octane gasoline is only obtained when an engine is designed and adjusted to take advantage of it. Most engines are satisfied with the "regular" grade gasoline, but those that are not satisfied can use a "mid" or "premium grade".
GASOLINE ADDITIVES
The following is a list of gasoline additives showing properties and uses:
1. Oxidation Inhibitors
Gasoline stability is important since gums formed during storage by the reaction of some gasoline components with each other and with oxygen may result in harmful deposits in the engine. Oxidation inhibitors are added to help in controlling gum and deposit formation.
2. Metal Deactivators
Reactions between the fuel and the metals in the fuel system may form abrasive and filter plugging substances. Metal deactivator additives are used to inhibit such reactions.
3. Detergents
Detergent additives are used to keep carburetor and fuel injection system parts clean and allow for the designed functioning of these engine components.
4. Rust Inhibitors
Fuel system parts are protected by the addition of rust inhibitors.
5. Octane Enhancers
Since the ban of lead in auto gasoline as of December 1, 1990, refiners are required to use alternate compounds to improve the anti-knock quality of the gasoline. MMT (methylcyclopentadienyl manganese tricarbonyl) is a catalyst compatible octane improver.
UFA GASOLINE ADDITIVES
All blends and grades of gasolines marketed by UFA are fortified with a comprehensive additive system.
These gasoline additives have been specifically designed to precisely alleviate the type of fuel related problems associated with fuel injectors and carburetors. By removing and preventing deposits, it restores and maintains peak engine performance.
Many benefits can be achieved through regular uninterrupted use of UFA gasoline, which is fortified with a unique additive system.
- Smoother acceleration
- Improved warm-up and idling performance
- Protection against rust
- Elimination of emulsion problems
- Improved fuel economy
- Increased engine reliability
As shown in Diagram A-5 fuel injectors must be deposit free in order to provide an even fuel flow pattern. UFA gasoline can eliminate deposits which lead to fouled fuel injectors.
All UFA gasoline contains sufficient deposit control additive to meet ASTM D5500, which requires an intake valve deposit of less than 100 mg average deposit mass per valve after a 16,093 kilometre (10,000 mile) driving cycle, or less than 25 mg average deposit mass per valve after a 8,046 kilometre (5,000 mile) driving cycle.
Source:
Gas fuel characteristics and resources
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
RustyLugNut (08-19-2014)
Old 08-18-2014, 10:39 PM   #84 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
OK I posted that because I was having issues with my computer and didn't want to lose the information.
So as you can see "front end components" make up the lower boiler points and
"back end" components make up the higher boiling components.
Some interesting facts:
Front End components are use for ignition light off and help during cold start and are increased with winter grade fuel. These are very easy to turn into gas vapor. So there wont be to much trouble here.
Back End components are used to provide a higher energy amount (your great BSFC numbers come from most of the back end components) but are very hard to turn into gas vapor.
Some of you racers can relate to buying a 55 gallon of race fuel and accidentally leaving the drum unsealed during the off season. Then you go racing in the spring but the car is very lazy out of the hole, but runs fine at higher rpm. This is because all the front end components have evaporate during the winter months and your left with mostly back end components.
OK back to our vapor systems. So after talking to a few race fuel chemists and doing some reading I decided that pulling fuel from a fuel container utilizing a bubble vaporizer would most likely pull all of the front end components out of the container first leaving the back end components left behind. Now some of you said a carburetor is nothing more then a vaporizer in itself. I don't agree, because a carburetor pulls fuel from the main jet well first then runs through the emulsion tubes last while adding air from the air bleeds. So a carburetor using all the front and back end components and emulsify them together.
I also had concerns of a lean back fire that could possible reach the bubble container itself and result in a explosion.
So I decided to build my system to add hot air at 250+F .50 inch from the exit of the injector. This will only used at very low load, and during lean burn mode.
My goal is to only go after the front end and mid end components of the fuel.
IMHO I believe some of the back end components need to be there for boundary layer protection.
Now with all of this said... does my system work? I don't have a clue??? At this time I'm still in paint mode and should have some results later this fall.
Work or not I will let everyone know. My cost to build this was maybe $100.00
My labor well way more then I want to tell. lol
Old 08-18-2014, 10:39 PM   #85 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
Why don't you put down others on this forum who use nothing more than duct tape and cardboard to mod their cars? How about the pie tin and coroplast crowd? Are zip ties allowed? .......
SC started his posting in the UC. this is where theories are on the loony side. want better responses? post in another area, not piggyback another. also, there are SEVERAL examples of his remarks bashing others opinions, he's was, from the beginning, asking for conflict. i won't quote them, you can do that yourself.
since you are such a fan of his, tell him to tone it down, act respectful or continue the route this is going. i find it funny how a person can come off at the starting line with such an attitude and then have another scream "give him respect". i see this a lot at work, mostly the '80's' generation where they were taught "you are the best and can do no wrong". this is MY experience, it's what I do.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 08-18-2014, 11:31 PM   #86 (permalink)
boiling gas
I like electric heat because it is easy to control.
12 volts at 20 amps will heat 3 gallons of gas 100 degrees F per hour. If your boiler holds a small quantity response can be rapid.
Old 08-19-2014, 12:46 PM   #87 (permalink)
pgfpro, your three posts are chock full of good reading.
I don't want to tell you to start another thread but it bears discussion on it's own.
My father was once a baker and when he pulled his 7 grain, molasses sweetened whole wheat bread out of the oven, it was worth eating with nothing else because of its hearty goodness.
These posts are reaching those levels. Good stuff. I will have to link to this as reference.
The description you put forth of your device parallels work done by Orbital of Australia in heavy fuel spark ignition. They use a modern air assisted injector to facilitate the atomization of JP-8 and diesel. Similar injectors are found in Hondas and Subarus and some Italian makes if I remember correctly. They, however, do not specify the use of hot, 250 degree air.
I am utterly intrigued by the possibilities of your work, along with soulcrushers and others. Add in what Kirk mentioned about electric heating and there is a real possibility of a working system that can approach what a Transonic injector can provide.
The Following User Says Thank You to RustyLugNut For This Useful Post:
pgfpro (08-19-2014)
Old 08-20-2014, 11:23 AM   #88 (permalink)
In Lean Burn Mode
pgfpro's Avatar
Team Turbocharged!
Rusty, Thanks again!!!
As soon as I get my car back on the road again I will start collecting all the data that I can, and post all the results of the following.
Hot Air injection at stoich.
Hot Air injection with EGR at stoich.
Hot Air injection with Lean Burn activated.
Hot Air injection with EGR and Lean Burn activated.
I'm hoping around late September I should be testing again.
