Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 07-23-2011, 06:30 PM   #11 (permalink)
New CNG tank setup in truck - Diesel Place : Chevrolet and GMC Diesel Truck Forums
http://www.mrsharkey.com/lpg.htm
I thought every one that was a diesel modder knew of propane/natural gas fumigation.
Xist (04-16-2023)
Old 07-23-2011, 07:42 PM   #12 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Of course we know about the "drugs"!
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 07-23-2011, 08:01 PM   #13 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
puddle jumper - '93 Suzuki sidekick base model
energizer bunny - '86 isuzu trooper base model
Clifford the big red dog - '84 GM S-10 durango
mmmm horse tacos
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
Old 07-23-2011, 09:05 PM   #14 (permalink)
...beats walking...
...when ALL the energy contents per volume are accounted for (assuming constant volume, of course) it comes down to effective proportions of BTU content of all the fuels. Look up Gasoline Gallon Equivalent on GOOGLE.
...I've always associated ether with "starter fluid" for cold diesel earthmoving equipment, but, yeah, it'll "burn" too.
...NOX supplies additional oxygen, which helps combustion and HP output, but not MPG!
Old 07-24-2011, 04:17 AM   #15 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The good part is you win on total BTU, so the diesel is also used more efficiently.
It's this sort of benefits the HHO-crowd is screaming about, but can't realize as they have to produce their own H2.
Of course, going CNG all the way is better than diesel, but adding it to diesel is apparently more easily accepted in the transport world. The bi-fuel trucks will still run on diesel alone.
Old 07-24-2011, 04:41 AM   #16 (permalink)
If we could get the same mpg or better, and the infrastructure was in place, we would use CNG. One less major overhaul to have. Heck, we could probably get 3 million or more miles out of an engine, save incredible amounts of money on oil changes, pollute way less, which means we won't get sick as much, not to mention the lower cost and domestic reserves which require no overseas supply. We have so much natural gas it's ridiculous.
OOPS, shoot, that's why we don't have straight CNG trucks now.
Old 07-24-2011, 05:54 AM   #17 (permalink)
...beats walking...
...maybe the French should come up with a "Champagne" fuel, ie: "Bubbly-Gasohol" that has CNG 'bubbles' pumped into it?
...it could be labelled Super-Magnum (93), Magnum (91), Bubbly (89), and Spritz (87).
Old 07-24-2011, 07:17 AM   #18 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Can you provide supporting links pls. The ones oil pan posted seem to be broken (in that they contain erroneous/conflicting information)
Old 07-24-2011, 12:38 PM   #19 (permalink)
90 day: 19.36 mpg (US)
No, we don't. What's usable and what isn't are in contention, and subject to misinterpretation. There's NG that we'll not ever be able to afford as the EROI is so out of whack with reality.
Propane is the better addition to a diesel for several reasons (with the way things are). One, it can be found all over the US. Second, it's a cheaper conversion. Third, it can be used for quite a few appliances for heating and cooking that a truck provides a portable fuel source for (and NG is not easily usable in the same way).
Propane -- again, in a truck -- may provide some additional range for the more valuable store of diesel, and, IMO, it's more important to think of the work value of goods transportation for ones family. A margin enhancer.
Old 07-24-2011, 02:31 PM   #20 (permalink)
CNG is cheaper to use but the start up cost is high and its difficult to store a lot of CNG on a car or truck.
I wouldn't mind running propane again but I think my compression ratio with turbo is too high, if I did use propane I would only be able to use it in say the 2-6 psi of boost range.
I have considered running water methanol at lower boost.
I think I would be better off running water methanol since it would enhance the temperature differential between both the hot and cold reservoirs. The evaporation of the water methanol makes part of the cold reservoir cooler, then when the diesel is injected and lights off the methanol, both burn off and help make the hot side hotter.
