Old 11-13-2020, 12:57 AM   #351 (permalink)
IIRC, the Korean 'police action'.
Back in my day there was so much toilet paper and eggs that we would throw them at the houses of our enemies
Old 11-13-2020, 01:05 AM   #352 (permalink)
It always sounded quite weird that Ford delayed the release of the Y-Block engine due to the Korean War.
Old 11-13-2020, 01:30 AM   #353 (permalink)
Do you know about the french military flathead V8s? French Flathead
And DDG says
Simca Used Ford Flathead V-8s Until 1961 and We Found One!
https://www.hotrod.com/articles/simc...il-1961-found/
The V8-60 flathead is quickly differentiated from its larger siblings via its 17 head studs. The original 221-cube flathead used 21 studs (1932-1938). ... By 1951 the French economy had improved ...
This 1958 Simca Vedette Trianon packs an American V-8 surprise under its bent hood. A similar model called the Aronde was offered but with a 78ci, 48hp OHV four-cylinder.
Old 11-18-2020, 01:13 AM   #354 (permalink)
Of course. The so-called SUMB (Simca-Unic-Marmon-Bouquet) engine.
The same model became the Simca Chambord in Brazil, and lately evolved into the Chrysler Esplanada which already incorporated ArDun-like cylinder heads on the old faithful Aquillon which then became the Emi-Sul engine.
freebeard (11-18-2020)
Old 11-21-2020, 06:14 AM   #355 (permalink)
90 day: 32.98 mpg (US)
All right. I am about to talk crazy, but stick with me! 2x8s are $8.67. I argue that I can make my own Tstud for... $8.67.
Cut out the black part and use a router to reduce the crossmember to 2x2 (or 1.5x1.5). There would still be thermal bridging, but 2.25 square inches per linear foot.
I call it the Shtud!
Why not Hstud?
Histud?
Hustud?
Aychestud?
How would you pronounce that?
[There is a good chance I would only make sch... at least at first]
Okay, how do I make [and pronounce] a Xtud?
I present to you the Xtud!
Their dowels seem to be at a 45° angle, except they are at an angle in two dimensions. They are thinking with triangles and stuff!
Having the crossmembers at an angle makes that part 40% longer, reducing the thermal bridging. If I just made an X it would be a more complicated H with a 2" thermal bridge.
Imagine the crossmembers are 1/2" thick, separated by half an inch. Half an inch of insulation wouldn't do much, but it would do more than an H!
How the heck would I make one?!
I could use a router to make the X, put a wider bit on a 1/2" spacer to create a channel in the middle, and then chisel it out?
I would want to make a 2' section for a proof of concept and maybe patent it.
Not everyone has a patent!
If I made a sandwich of 5/8" and 3/8" plywood it would be negligibly thicker than 1.5". That would be vastly easier than carving a board, but it would not be as impressive.
With much enthusiasm I present to the world the kstud. Yay:
All right. Let's say that I use something like that instead of Honey-do Carpenter's metal studs.
It was 115.0°F (46°C) in Phoenix on July 16th, 2019. The low was 89.1 F (32°C)
Matt Ringleader sang praises to T studs here. There is a note that they cost as much as a premium stud.
What is a premium stud?
Someone commented that they cost five times as much as standard lumber for at most R3.
A double wall makes far more sense to me!
Someone claimed that metal studs made more sense.
No, they don't.
https://youtu.be/3zGzcn9rDKg
Old 11-21-2020, 10:45 AM   #356 (permalink)
A premium stud has a bit more processing to keep it potentially straighter by less knots, bit more drying and a pass through a better planer. Not worth the price when you can sort your own for the same effect in the piles at the box stores.
Old 11-21-2020, 03:00 PM   #357 (permalink)
It sounds like the Tstuds are clamped down while they dry so they don't warp. Sure, plenty of boards warp at the box store, but how many of you have had them warp after you bought them?
I am unimpressed with the kiln-drying process, but what is the success rate?
90%?
99%?
I am sure that it depends on the dimensions.
I am positive that I already watched this, but I started playing it on Mom's television yesterday. I expected her to come home and yell at me to change it to Hallmark, but she seemed to enjoy criticizing the Canadian.
"How many sheds have you built?"
"None! I am not a carpenter!"
"He has been doing this successfully for decades. Look at his house! That is beautiful!"
[Grumbles]
He said that he ran to Home Depot and looked at their commercial sheds. He built this with 16" on-center studs [the roof is 12"], but theirs were 24", and they used many 2x3s.
He said that all of his materials, including the concrete foundation, cost as much as the commercial one, but it would last far longer:
Old 11-21-2020, 05:38 PM   #358 (permalink)
When Chicago burnt down due to asteroidal impact, it was rebuilt with the newest innovations, 2x4s and wire nails. They used balloon framing where the studs were two stories tall and the 2nd floor hung from them.
In a single story structure, 2x3s and/or 24" spacing are adequate.
I've built and filled a 6x8ft dirt-floored lean-to shed in the last 60 days.
Old 11-21-2020, 06:30 PM   #359 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
That depends on how much you want to pay for a shed. Home Deport will sell you a shed framed with 2x4s 16" on center.
Old 03-28-2022, 02:51 AM   #360 (permalink)
I mentioned Legos elsewhere and remembered watching a video about Lego-style hempcrete blocks, which freebeard mentioned here.
Matt Ferrell explained it here: Oddly, while he calls his channel "Undecided," he definitely presented more positives than negatives.
Here is the most popular video about hemp blocks: I keep trying to find a video showing construction with those blocks, but instead I keep finding videos with a competitor.
Instead of having a resin core making it look and act like Legos, it is like an Oreo, with the filling being the same size, just offset, but then they reinforce it with rebar and concrete.
Even though I searched for "Justbiofiber," YouTube showed me this Jo-Blox video instead, although I couldn't tell by the thumbnail that it wasn't what I specified!
freebeard (03-28-2022)
