07-24-2014, 10:08 AM
#631 (permalink)
Glass is higher tensile strength than steel. I will be using S-Glass on the 'A' pillars, which is 20-30% stronger than E-Glass.
07-26-2014, 07:37 PM
#632 (permalink)
07-26-2014, 09:34 PM
#633 (permalink)
Wow! It's really looking like an actual car! I've been watching this since i first found ecomodder your work is really awesome I can't wait to see the finished result.
Aiming for 50 MPG from an automatic.
See how I'm doing here, My Build Thread
The Following User Says Thank You to backpacker3 For This Useful Post:
07-26-2014, 10:57 PM
#634 (permalink)
Growin a stash
You have some serious skills! This is a really ambitious project but it's starting to look like you might pull it off.
The Following User Says Thank You to ME_Andy For This Useful Post:
07-30-2014, 10:59 PM
#635 (permalink)
Not banned yet
getto - '02 Volkswagen Jetta GLS TDI 90 day: 53.82 mpg (US) Blue - '03 Chevy S-10, LS
FOR SALE: 02 TDI Jetta- 5 sp: Cooper CS5 at 50 psi, ventectomy, mufflerectomy, LED plate light, upper fiberglass grille block, front lower pan, front fairing.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following 5 Users Say Thank You to deejaaa For This Useful Post:
08-01-2014, 11:39 PM
#636 (permalink)
That basalt fabric looks a lot like carbon fiber, but I guess it may even have some enhanced thermal properties.
08-02-2014, 12:19 PM
#637 (permalink)
deejaaa -- Thanks for ordering the samples, I'd never have gotten 'round to it. The rigid felted panel is interesting. That would be handy for interior bulkheads and such.
Are you going to do tests with the sample pieces, like put a rod in a tubing bender?
08-02-2014, 09:29 PM
#638 (permalink)
Not banned yet
if there was a way to measure stresses, i would. pieces are about 5 inches each. not sure how accurate measures would be. i will send some off to someone if they can do some testing.
08-03-2014, 12:44 AM
#639 (permalink)
The test I was thinking of would be along the lines of 'can I do it with hand tools'.
08-03-2014, 12:39 PM
#640 (permalink)
Not banned yet
i can do something. didn't know there was something more specific needed. i will be outside doing some cutting/welding and will try to get it then.
