Old 09-04-2009, 11:47 PM   #31 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Yeah, I still don't think it's gonna happen that way... I'm sure those yards were required to monitor/separate those vehicles from other "available" stuff, or still to document what had been removed/dismantled. There was ALOT of paperwork necessary to be a part of the program.
Old 09-05-2009, 01:14 AM   #32 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I'm not sure how, but a co-worker was offered a clunker as a used vehicle (this was pretty early in the program). It was an older vehicle for her son, which qualified as a C4C. My best assumption is that the buyers took rebates instead of the Government program, or flat out, the dealer was selling vehicles traded into the program (but without the engine killer).
Each clunker's death can't be overseen by a representative, on-site (they barely have enough people to process the claims).
Who's to say that someone didn't pull the old switcheroo with an old salvage Buick out back, use that VIN, and take the running clunker and put it in the 'Used' pool. The dealer even admitted over the phone they were selling clunkers!
Aside from that, what's the penalty for selling clunker engine parts, and how hard will it be enforced?
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 09-05-2009, 05:32 AM   #33 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
This is actually pretty innovative, I mean if you want to enforce C4C, then do this little ditty and nobody is going to want to touch the engine afterwards.
Old 09-05-2009, 01:42 PM   #34 (permalink)
ZeroFuel 1,2,3 - '96 Geo Metro
Here is the real story behind C4C, a wide spread conspiracy.
REPORT: Cash for Clunkers leads to shortage of destruction derby cars. Oh, the humanity! — Autoblog
Old 09-05-2009, 10:15 PM   #35 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
Originally Posted by roflwaffle View Post
Meh, someone can still yank it and disassemble it if they really wanna. Replace the bearings/rings, maybe clean up the bores, clean everything else up well, and it'll probably run fine.
IOW completely rebuild the block and heads, making sure to clean every single bit of the silica/sand (a.k.a. glass) out of it before daring to turn the crank. Possible maybe, but economically impractical in the extreme.
BTW the smoke coming out the exhaust pipes is predominantly steam.
Cash for Clunkers Gets $2B, Back on Track SVOboy EcoModder Blog Discussion 24 08-14-2015 08:53 PM
Cash for Clunkers results Clev General Efficiency Discussion 25 11-05-2009 12:58 PM
Scratch X results RandomFact314 Off-Topic Tech 14 06-22-2009 10:28 PM
Subaru Outback Hot Air Intake Results brucey EcoModding Central 22 12-10-2008 07:41 PM
