Old 06-11-2021, 03:57 PM   #91 (permalink)
wind
Seen the latest from the solar parker probe?
The solar wind up close to the sun is far more chunky and coherent than anyone thought possible.
So the crazy science fiction idea that a "super flare" might contain an impact hazard just became probable.
It's 'strength', per particle, will be ruled by the inverse-square law.
By the time any of that wind reaches Earth, it will be so feeble, as to be a mouse fart on a cotton ball.
Old 06-11-2021, 04:16 PM   #92 (permalink)
tens of thousands
Originally Posted by slowmover View Post
The story of pollution the past century — of which we can’t get enough — is electricity. Or call it radiation. EMF.
The dial keeps getting turned up. Air, water and ground pollution are investigated for catalytic effects. Modified to be so.
If it “requires” electricity . . . it ain’t what it seems.
Music, first and foremost. Have to plug in to play? Then it ain’t music, just ffng around with voltage potentials.
From servant to master in under a century. Is electricity. In what today passes as thinking or emoting. But isn’t. (Free electricity will be the most expensive bargain ever purchased).
The Phoenician Navy has (what is it?) four or five thousand years of modern experience. And the records barred to everyone else detailing several tens of thousands before that.
Stories to excite the imagination are just trials to set the dials
I don't believe there are any examples of written language predating Sumer.
Old 06-11-2021, 06:12 PM   #93 (permalink)
black body would be limited strictly to infrared. The sun emits 'light' all over the electromagnetic spectrum.
That went way over your head.
aerohead (06-16-2021)
Old 06-11-2021, 06:13 PM   #94 (permalink)
I wasn't talking about normal solar wind at all.
Old 06-11-2021, 06:23 PM   #95 (permalink)
solar wind
Solar wind of any type is plasma, yes?
Old 06-11-2021, 07:07 PM   #96 (permalink)
Solar wind is plasma. Until it isn't.
Old 06-11-2021, 10:48 PM   #97 (permalink)
aerohead -- Looks like your catching up in the thread. The way the Bible describes it, the Sun turns black, as a shell of materials is ejected and by the time it reaches Earth it's turned into major impactors that were thought to be cyclic asteroid rains. That doesn't fit the facts.
At 1:59 He uses the expression 'cools and congeals' to describe it.
You can't be wise and in love at the same time. -- Bob Dylan
Old 06-12-2021, 03:41 AM   #98 (permalink)
Why does that lightning strike look like a 50bmg incendiary round hit that pipe line?
Even if the sun doesn't turn black and blow off condensed materials, the lightning is starting to display biblical, mythical properties right now.
Should be a little concerning.
Star goes dark for a few hundred days then comes back to full brightness. Did astronomers observe this biblical black sun phenomenon? It's never been seen before (ha) and they have no idea what happened or how to explain it.
Sounds familiar. Starts at 2:07
Old 06-16-2021, 02:34 PM   #99 (permalink)
went
That's probably true, however your response doesn't help me to focus more specifically.
The Parker Solar Probe would be investigating some of the 4% of mass we can sense/ detect in the corona. Electrons, protons, atomic nuclei, neutral hydrogen, ionized hydrogen, particles, magnetized plasma, flares, coronal mass ejection, magnetic sheets, Parker spirals, plages / faculae, irradiance, solar neutrinos, muon-type neutrinos, electron neutrinos, tau-type neutrinos, r-Modes, Rossby waves, inertial oscillations, Coriolis effect, vorticity, convection, ephemeral active regions, x-point magnetic-field topological annihilations, super-heated thin-filament ejection, magnetrohydrodynamics, moats, sunspots, ultraviolet photons, infrared photons, visible photons, X-ray photons, antipodal magnetic fields, synchrotron photons, solar radio photons, solar radio-burst, gamma-ray photons, gravity-lensing, Magnetic periodicies, wave superposition, rogue waves, Alfve'n waves, interplanetary magnetic field, magnetic field storm orientation, upper-atmospheric nitrates, solar wind, latitudinal photospheric rotation, coronal holes, bow- shock compressions, rarifactions, overtaking shockwaves, edge effects, Alfe'n MACH number, ram pressure, stationary draping pattern, wake, current sheets, whistler-type waves, MACH cones.......... the dark side of the Sun.
Old 06-16-2021, 02:39 PM   #100 (permalink)
biblical astronomers
That would require that they have magnification, which didn't exist, and a hydrogen-alpha filter, which didn't exist.
Xist (06-19-2021)
