08-13-2021, 05:22 PM
#321 (permalink)
comedy
Jim Carey and Jeff Daniels?
Arson & Arsoner?
08-14-2021, 09:51 AM
#322 (permalink)
It's only a comedy if you can understand the jokes, otherwise it's drama.
08-18-2021, 03:29 PM
#323 (permalink)
2015 Paper on earthquakes and solar magnetic fields
https://suspicious0bservers.org/wp-c...04/Paper-1.pdfI located the 2015 paper.
Language ranged from :
* 'reveals'
* 'maybe'
* 'potential'
* 'may'
* 'indicative'
* 'worthwhile to consider'
' lightning underground...... exceeding 1-million amperes' ( no voltage, no Watts, no Power )
Earth's lithosphere, as a 'capacitor' is introduced, however, nothing is volunteered with respect to any known connection between magneto-telluric potential and fault-rupture triggering.
There is a Friedemann Freund of NASA , who has spoken of underground lightning, electric currents in igneous magmatic rock, created under tectonic stress/strain at fault boundaries, as oxygen bonds in the lattice structure of basaltic olivines are broken, free electrons liberated, creating a plasma-like state, which at Earth's surface, ionizes local atmosphere, creating bursts of light, flashes, avalanches.
Friedemann mentions that the piezoelectric effect isn't strong enough to produce this, nor the triboelectric effect.
I haven't found the citation for the actual earthquake predictions. I'll keep looking.
Reason: add link
08-18-2021, 03:51 PM
#324 (permalink)
Let the record show, on this date aerohead posted a Suspicious 0bservers link.
New Concepts in Global Tectonics Journal, V. 3, No. 3, September 2015. w
Didn't find you answer there? Try www.everythingselectric.com/product/billy-yelverton/. This points to his Youtube channel Mr2Tuff2 and has 4 related pages at the bottom. He's reproduced Valles Marineris in miniature in his lab.
I first discovered the guy after 2013 with his Remote Control lawn mower video.
08-18-2021, 04:46 PM
#325 (permalink)
videos
I watched the videos. I didn't experience anything really informational. No basic premise. Mixed technology of questionable relevance to Mars. No data for materials. No explanation of methodology. How it might reflect actual conditions on Mars. No mention of other mechanisms which might reproduce the same artifacts investigated. It's a tough sell.
Recent programs, by those who study Mars know that what we see today does not reflect how Mars was in the distant past. And what they believe about how Mars was back then, easily explains what we do see today.
On April 13, 2029, Asteroid Apophis, about 1,100-feet across, will come within 20,000-miles of Earth. A structure of this size, if it were to just graze us, could dig a ditch as remarkable as the Martian structure in the video.
08-18-2021, 05:45 PM
#326 (permalink)
Between 12:51 and 1:46 [local time]?
Plasma phenomena scale. 'As above, so below'
Apparently.
08-18-2021, 06:12 PM
#327 (permalink)
between
Apparently.
I looked at all of the first two.
The longest video was on a shaker table, like one would use to create concrete table tops, and I considered it non-germane to 'lightning' events.
The underground plasma was from shear-strain at the fault boundary knocking atoms apart, not the other way around. And I don't consider the process to be reversible.
If there's an isotopic paleo record for Mar's early atmosphere, at that surface anomaly, it may tell us something about a time when liquid was present on the surface. Or bombardments, as there are known specific markers for meteoric, asteroidal, and cometary impactors and such. Magma, lava.
08-18-2021, 07:46 PM
#328 (permalink)
08-20-2021, 11:24 AM
#329 (permalink)
Litchtenberg
Every time I fly to Reno, Nevada and back I get to see these from the aircraft. And the water down inside them, and at their terminus, a clue as to their formation.
1) Mars 'froze' ( geologically ) about 2-billion years after its formation.
2) Before 'freezing', Mars had water vapor in its atmosphere, and liquid water on its surface.
3) In September, 2015, NASA's Mars Reconnaissance Orbiter's imaging and spectroscopic analysis showed that seasonal flows on the Martian slopes ( including the ' Litchtenberg' feature ) contain hydrated minerals that can only form in the presence of liquid water.
4) Martian minerology and sub-surface erosion features imply flowing water, rather than lightning from the rain clouds as the causal factor in the creation of the Litchtenberg feature.
5) For a single Martian thunderstorm track, discharging a continuous and variable-power volley of cloud-to-ground lightning, as with a plasma-cutter, or a series of multiple storms following only an identical storm track, discharging lightning, and not only 'striking twice', but 'infinitely', from a single cloud-base each time, time an time again, would constitute a statistical impossibility on Earth, known for its annual lightning strikes.
6) Early Mars, as known so far, never possessed a 'special' case for physics, which might explain 'impossible' lightning behavior.
7) And there is no evidence on Earth, that lithospheric disintegration can occur in the presence of lightning. Even the 1947 atomic bomb detonation at Trinity Site, New Mexico could only produce green glass 'Trinitite.' I know, I've been there.
08-20-2021, 12:54 PM
#330 (permalink)
Mars didn't freeze geologically, that's obsolete science. The Mars geologic mission is only takes seismic data from its 1 location and it's identified a mantle, core and an over all stunning level of activity.
