Old 01-07-2011, 01:32 PM   #101 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Update: test run
Today I needed a tube of caulk and some 1x2s to make a floor in the tail. My brother was heading off and so I had him follow me for a mile and watch the light snow flow off the tail. Then we swapped cars I and watched. I also took a video clip (not sure how to embed so here is the link) :
Nothing fell off on my trip into town. I taped the gaps and the tape held just fine.
I also took some pics:
snow build up, so I think this area could use some help:
Ideas?
The Following User Says Thank You to Weather Spotter For This Useful Post:
Piwoslaw (01-11-2011)
Old 01-07-2011, 03:02 PM   #102 (permalink)
Wiki Mod
Well I did some more work on the tail. I closed up some gaps and made a floor that is even with the car floor.
I used the 1x2s I bought this morning to make the frame:
The I used some colorplast for the floor:
As it is now:
brucey (01-07-2011)
Old 01-07-2011, 03:05 PM   #103 (permalink)
Wiki Mod
From my one short trip I watched my MPG's and it seems that I am 4-7MPG higher then I was last week when I drove the same route. This is very subjective testing (no wind today) roads have some snow etc...
Old 01-07-2011, 03:08 PM   #104 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
It looks really good to me. Judging by the video, it looks like you have some turbulence down low but the top half appears to have attached flow. In the sunlight on the driver's side there is some airborne snow that breaks off cleanly at the transom. I believe you have significantly reduced the size of your trailing wake. Good news for hatchback or wagon owners.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 01-07-2011, 03:16 PM   #105 (permalink)
Wiki Mod
So how do I fix the lower turbulence?
Old 01-07-2011, 04:09 PM   #106 (permalink)
Wheel strakes would likely help.
(click on image for link)
Darin tried them on his boattail:
Weather Spotter (01-07-2011)
Old 01-07-2011, 04:44 PM   #107 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Love the interior shot of the extended floor! Any plans to sleep in it? I've had thoughts to this effect, making a boat tail and capitalizing on the extended sleeping volume at trailheads. But it's such a big project, and I parallel park in the city most days...
Old 01-07-2011, 09:24 PM   #108 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Reducing the angle on the bottom maybe, as it seems rather steep.
Did you measure or calculate it ?
It'd require some serious redesigning to do that though.
Old 01-07-2011, 09:33 PM   #109 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Can't wait to see the ABA testing! Good idea with watching the snow bounce off the car. Pretty simple test. (: Looks to be working quite well.
Old 01-07-2011, 09:35 PM   #110 (permalink)
Wiki Mod
I have thought of it before, say on long trips pull off in a rest stop and sleep. I have not done it but now I have the needed length I can also watch stars out of my new moon roof.
@ euromodder
I want to reduce the turbulence but I think that NeilBlanchard is on the right track. The wheels seem to be making a vortex. In the middle the bottom still has attached flow. The trick will be making the mini boat tails for the tires and still be able to go through 8" of snow and debris on the road.
MetroMPG's ones look too big any ideas on how to?
BOAT TAIL Drag Reduction Estimates aerohead Aerodynamics 12 01-30-2016 05:08 PM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 9 01-19-2014 10:59 AM
Project: Geo Metro boat tail prototype - 15% MPG improvement @ 90 kph / 56 mph MetroMPG Aerodynamics 500 05-10-2012 11:30 PM
collapsible curved folding 10mm coroplast boat tail miket Aerodynamics 5 08-12-2010 02:58 PM
Subaru Outback Prototype Boat Tail Test Results brucey Aerodynamics 10 10-02-2009 06:03 PM
