Old 11-27-2009, 09:10 PM   #31 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I've read that there is a reasonable aspect ratio between the width and length of the "T" in reverse trikes that should be something like .75:1 (longer than wide), but I don't recall the reference.. I read it "en passant", and it may have been entirely false. Seems logical, though... if you've got a 75 inch front track, a 100 inch separation between the front and rear axle centers seems proper.
I would be inclined to think there's just more to it than that, though... such as center of gravity, etc.
Old 11-27-2009, 10:09 PM   #32 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
If I had a Metro truck, I would go all out on it............
Visor
Stacks (Tri-Stacks?)
Running boards
Bed rails
Dual whip CB antennas
Grille Gaurd
KC Hi lights
Yeeehaw!
GeoMetroforum.com - got mpg?
Old 11-27-2009, 11:39 PM   #33 (permalink)
So what would you do with a Caravan? LOL. Friend wants to put it on a Blazer frame and rock 33's!
Man, rednecks...
Old 11-27-2009, 11:41 PM   #34 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Visor
Running boards
Bed rails
Grille Gaurd
KC Hi lights
Yeeehaw!
I'd make it a dually. lol
Old 11-27-2009, 11:44 PM   #35 (permalink)
On the front tires? :P
Old 11-28-2009, 01:07 AM   #36 (permalink)
nah, on the trunk...lol
Old 11-28-2009, 01:11 AM   #37 (permalink)
I just wondered, cuz ya know... drive tires and all...
Old 11-28-2009, 01:23 AM   #38 (permalink)
electricman
I've heard of High Schools Students that have 'pickup' modded the Geo B4, so we know it can be done - and the eBay pic Proves it - and - hey it's a mod that (probably) saves on weight! So - that's better at slow speeds - less weight to accelerate = more eco friendly - hence - here we are on 'ecomodder'!.
It the AeroCap was made lighter weight than the stock - I am betting your aero would be better, and your weight penalty would be small over the current (pictured) style of pickup mod. You could make it wiith foam - like mine essentially - then fibreglass it using epoxy resins, and then - just disolve out the foam with some old Gasoline! A Bit oa a small RC Modeler Trick for small Airplane fuselages! Robert
Old 11-28-2009, 01:47 AM   #39 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
My suggestion was streamlining the three wheeler, though. The initial RR loss would probably be insignificant until the extra weight of the chassis was shed, but as the project were to progress, it would take a better chunk of the RR away as well. IF you've got less weight on a tire, it's bound to have lower frictional loss.
RR doesn't change unless you swap in different tires, only the power needed to roll it due to whatever drop in weight. Technically, there may be a drop due to having three bearings instead of four, but I don't think it would be measurable.
Old 11-28-2009, 01:50 AM   #40 (permalink)
I don't think that's right... the tire's RR is measured at a specific load rating, but it doesn't always apply to all situations. If you load a tire less, it will have less rolling resistance. We've already proven this by overinflating tires, or removing weight from vehicles, and recording coast-down times.
I believe RR tests are done at max pressure and max load, but I don't recall specifically... seems I forget more about this stuff than I learn lately.
Need Geo Metro information.. Chris D. Off-Topic Tech 5 01-23-2013 05:28 PM
Restoring a 1989 Geo Metro IheartGeos Introductions 18 02-22-2010 01:00 AM
My 1989 Geo Metro Story owlafaye Introductions 2 10-05-2008 06:31 PM
1990 Geo Metro Idle test cinaroh EcoModding Central 2 07-08-2008 10:15 PM
1995 Geo Metro DRL disengage tip akcapeco EcoModding Central 1 06-10-2008 10:07 PM
