Old 08-30-2010, 04:49 PM   #51 (permalink)
jackbauer's Avatar
Looking at an idler sprocket option. Gonna get a price tomorrow. Might be the simplest option.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 08-30-2010, 06:40 PM   #52 (permalink)
You should be able to take care of it in the way the motor mounts. See if you can make it swing out so it's just like putting on an alternator belt.
Old 09-01-2010, 04:08 PM   #53 (permalink)
jackbauer's Avatar
14t idler sprocket turned up today so i went ahead and turned a piece of 25mm steel round stock to make a mounting. Drilled through 8mm and tapped an m8 hole in the plate to mount. Ran the bottom motor on its own no prob. Then went for series mode. Ran a bit slower obviously (just 12v) but also fine.
.........get you motor(s) running ........
ID:	6755   Click image for larger version
ID:	6756   Click image for larger version
www.evbmw.com
Old 09-02-2010, 03:39 PM   #54 (permalink)
jackbauer's Avatar
Motors running in both series and parallel:
www.evbmw.com
Old 09-02-2010, 05:06 PM   #55 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
You shure ain't wasting no time
Old 09-18-2010, 03:12 PM   #56 (permalink)
euromodder's Avatar
Any new developments ?
Old 09-18-2010, 04:44 PM   #57 (permalink)
jackbauer's Avatar
Sadly no. I've been tied up with work and getting the evbmw through its test. I will be returning to this project soon though as i have ordered new wheel bearings and a magura twist throttle.
www.evbmw.com
Old 10-19-2010, 04:10 PM   #58 (permalink)
jackbauer's Avatar
Finally got back to a few jobs on the bike after a month and a half of fun getting the car through the test. The magura throttle turned up today but i was disappointed in the way the wire was setup. Got that sorted so next job is to sort out the back end ........
www.evbmw.com
Old 10-23-2010, 01:15 PM   #59 (permalink)
jackbauer's Avatar
Well I got the back wheel off , cleaned and repainted. Also replaced the wheel bearings , sprocket carrier bearing , sprocket , brake disc and brake shoes. All in the back end of this bike was in bad shape. Cleaned up the swing arm a bit but this is a conversion not a restoration. I had to make a simple tool to push back the caliper piston. Just a piece of 50x10mm flat steel with a 8mm tapped hole for a bolt. worked great.
I've been wrestling with the battery choice ever since i started the project and came to the conclusion that building a lead acid bike would , quite simply , be a waste of time. My first thought had been odyssey pc680 agm to keep the weight down but the range would have been abysmal. Anything bigger would have yielded a two wheel battering ram.
I bit the bullet and purchased some headway cells for testing and have been blown away with the performance. Based on that I made a further purchase of a quantity of 16 off 16ah cells to begin sizing up a pack. Plan is to start off with a 20s2p pack and work up to a 30s4p. That would allow for at least 600amp peak discharge.
ID:	7184   Click image for larger version
ID:	7185   Click image for larger version
ID:	7186   Click image for larger version
ID:	7187   Click image for larger version
ID:	7189   Click image for larger version
ID:	7190   Click image for larger version
ID:	7191   Click image for larger version
www.evbmw.com
Old 10-24-2010, 10:10 AM   #60 (permalink)
do you have a link to those cells were i could look up the specs?
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 158 01-12-2013 11:59 AM
1993 Honda Del Sol conversion delsolectric Fossil Fuel Free 5 06-09-2009 12:18 PM
Honda CRX good for conversion? resestop Fossil Fuel Free 10 05-08-2009 09:10 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Conversion: 91 Honda Accord w/ HHO anox195 EcoModding Central 36 08-21-2008 07:00 PM
