Old 08-31-2009, 05:16 PM   #21 (permalink)
Relevance is irrelevant!
bluetwo's Avatar
CR-EX - '12 Honda CR-Z EX
Send a message via Yahoo to bluetwo
Did I miss it or has anyone considered making the front wheels electrically driven? I mean you already have half the system in place. I'm no expert but it seems like you could do it.
I've tried to encourage people to hook up an electric motor to a CRV too. It would have to be a non-realtime AWD model though I think. Or not, by all means, correct me if I'm wrong... nicely though. Don't be a ****ing **** or I'll report you in a heartbeat.
Old 08-31-2009, 05:18 PM   #22 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Yeah, we explore that in another thread for this member. I think that's still the best way to go.
The CR-V has an electrically operated clutch pack at the rear. If somebody could figure out a way to either remove or permanently lock up that clutch pack, they could then run the rear off of a motor. (A bit more of a clearance problem under the CR-V than under a pickup, though.)
Old 08-31-2009, 06:18 PM   #23 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Clev, that post that you quoted of mine, I was referring to solid mounting the motor to the frame, and using a chain to connect the motor to the driveshaft.
What you were suggesting in that same post, is basically the equivalent of using the e-motor for a carrier bearing. This is fine, as long as the armature can stand up to the driveshaft's speeds and torque. Remember, that driveshaft gets going REALLY fast. Also, it would require less of a HP rating, and thus, a smaller e-motor, if it were chain driven with a lower gear ratio, such as the same as 2nd gear in a truck, which would still allow for most low-speed city driving scenarios, and be more efficient for said purpose, due to less weight and power requirement.
Old 08-31-2009, 06:26 PM   #24 (permalink)
Lurking footless halls
Silveredwings's Avatar
Dark Horse - '16 Ford Mustang GT convertible Premium
Gutless Beauty - '19 Toyota Corolla SE
Originally Posted by roflwaffle View Post
An ADC 9" should be fine as long as the driveshaft angles and mounting are solid. Here's an example of a similar setup. I hesitate to recommend it from the POV of cost in terms of engine assist for automatics because it's only reducing engine operating efficiency in that context. The only payback is if the vehicle's owner has a manual transmission and can operate on battery power alone instead of using their engine at low load AFAIK.
Another example of the emis inline drive shaft mounted motor:
Any sufficiently advanced technology is indistinguishable from magic. - Clarke's Third Law
Old 08-31-2009, 06:28 PM   #25 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Strong insecurity in this one...
Christ, if you geared a motor to run at effective "second gear" speeds, wouldn't that make it (the motor) rev to hell and back @ 60?
Old 08-31-2009, 06:29 PM   #26 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
Sorry, I must not have read closely enough. I read enough of your post to think you and I were on the same page.
I guess the only problem with the chain-driven smaller motor is that you'd need a disconnect or overrunning clutch to keep from overspeeding it at freeway speeds.
Old 08-31-2009, 06:34 PM   #27 (permalink)
bluetwo's Avatar
What the?.... I admit I'm feeling a bit clueless on that one but does that go in a bimmer? I have got to look at that closer.
Old 08-31-2009, 06:34 PM   #28 (permalink)
It's cool, it really did apply to both, though it was more directed at being chain driven. Either way, you've got to have a 2 piece driveshaft to pull it off properly, or a very elaborate variable mount system, which just makes it not even worth it.
I was thinking more like an overrunning gear hub, like you'd find on most 20" and larger bikes with a single speed rear tire. This way, the motor couldn't be used for braking, but in the interest of "cheap", regenerative braking is out the window anyway.
Old 08-31-2009, 06:35 PM   #29 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
Yeah, that's kind what I was getting at. It doesn't look like Netgain did anything special to that except bolt on a U-joint at each end. (The EMIS box is actually the motor control bit; looks like they use a standard Warp motor.)
One person on the EVDL has two ADC 8" motors belted together, and another had three 9" motors mounted end-to-end. In both cases, the motor closest to the transmission must handle the torque from the other motors. In both of these cases, the standard ADC shaft was sufficient. There might be a slight possibility of concern in the case of using the 4WD low range for something like pulling a stump, but even then, half of the torque is going to the front wheels.
Old 08-31-2009, 07:37 PM   #30 (permalink)
Yes, my particular application has a manual, however.
Is the loss of efficiency you refer to WRT an unlocked torque converter?
Thanks
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Motor probs - commutacar electrique Forum News & Feedback 7 09-11-2009 02:14 AM
Motor Brush Advance TomEV Fossil Fuel Free 19 05-07-2009 11:50 PM
AC Induction Motor used as Brushless DC? WaxyChicken Fossil Fuel Free 5 01-29-2008 09:26 PM
