Old 02-16-2008, 03:07 AM   #1 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Super Metro (powered by CBR 600 superbike engine)
I thought some of you would get a kick out of this..
I found this when searching for Geo Metro's for sale..
enjoy..
http://losangeles.craigslist.org/lac/car/571452983.html
1993 Geo Metro 2 door hatch back.
Powered by a CBR 600 superbike engine.
Uses the bikes six speed gearbox.
Fully gutted track car with 4-point cross braced cage.
Light weight high bolstered bucket seats.
Simpson 5-point cam lock harnesses.
Painless wiring switch panel.
All lights, blinkers, horn, etc works as if the car was stock.
WILL NOT PASS SMOG. Should be used as a track car only. Thanks.
Old 02-16-2008, 12:30 PM   #2 (permalink)
EcoModding Minded
Chris D.'s Avatar
http://www.psiman.net/geo1.htm
Old 02-16-2008, 02:55 PM   #3 (permalink)
igo
igo's Avatar
Mini Box Truck - '05 Scion Xb
90 day: 32.87 mpg (US)
It FITs - '09 Honda Fit Sport
90 day: 36.2 mpg (US)
Impreza - '13 Subaru Impreza Sport
90 day: 30.92 mpg (US)
It looks rust free! I wonder how fast it is and what mpg it would get.
Old 02-16-2008, 03:39 PM   #4 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I was thinking the same.
There's a Swift Team from Canada that participates in the Rally here in MO -- pretty quick actually.
-RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 02-17-2008, 08:53 PM   #5 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
What an awesome build!
Of course I was wondering the same thing... mpg... mpg... mpg...
Old 02-17-2008, 08:54 PM   #6 (permalink)
Oh, and since it runs through the bike's transmission... can it go backwards?
Old 02-17-2008, 10:20 PM   #7 (permalink)
Linky says no.
No mention of year of engine... since it was "cheap", it's probably not brand new... mid '90's put out about 106 hp.
What does a stripped out Metro shell with a bike drivetrain weigh- 1000 lbs?
It should go pretty good. I'd imagine they have a tough time getting enough traction at times.
I'd also imagine FE to be pretty bad, with crazy rpms at highway speeds.
Old 02-17-2008, 11:35 PM   #8 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Very interesting conversion.
There are some great ideas here that could be used for trike building. I like the Metros old stick rigged up for shifting the cycle engine.
This also does bring up some interesting possibilities about putting a SMALLER than stock engine in a Metro or similar.
That chain connection from the cycle tranny to the differential also looks pretty interesting and gives some ideas for different ways an electric motor could be hooked in.
The only EV Metro I ever saw had a chain going straight from the motor to the transaxel similar to this setup.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 02-18-2008, 12:13 AM   #9 (permalink)
Depends on the Day
RH77's Avatar
Sports Cars
There's a Suzuki Swift team from Québec successfully in Rally racing (from what I've seen at our competition in MO).
In our tournament, the vehicle has to be robust: "Low-Water Bridge" crossings often have at least 4-6" of water to ford at speed, and high velocities include air-time on abrupt hills. I've observed this team the last 2 years and have really been impressed with the how the vehicle holds-up. I also give the team credit for their expertise...
I wouldn't write-off the modified Suzuki-clone as a racing-machine...
RH77
_
_
Old 02-18-2008, 01:18 AM   #10 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Linky says no.
Thats the great thing with bike motors.
Infinite gearing possibilities.
Just change one gear @ a time and record results.
It appears to be 4:1 right now.
10 teeth on tranny 40 teeth on diff. (as best as i can count from the pics)
say you're twisting 6500rpm @ 60mph
Change tranny gear to 12 teeth and you are down to 3.33:1
now your twisting 4875rpm @ 60mph
add infinitum.
what a great way to increase engine load by reducing rpm @ speed.
if load gets too great you just change back up.
If the engine would produce enough torque you could lope down the highway @ 60mph twisting ~ 1500rpm.
That'd get you real close to 100mpg.
Just another way of looking at the equation.
Have fun.
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
MetroMPG.com mailbag: Metro engine won't stay warm in super cold weather MetroMPG General Efficiency Discussion 13 02-01-2008 11:28 PM
