Old 03-08-2008, 12:22 AM   #1 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Just starting on wheel skirts, need opinions/ideas
I desided to hit home depot and see what I could come up with..
I figured on this flat steel thats easy to bend into shape..
I'm going to make L brackets to mount to the inner wheel wells and drill two holes.. one to mount them and one for mounting the skirt..
I have bolts that i'll weld to the frame and use washers and lock washers with wingnuts for easy removal from the backside..
I'm wondering how to cover these? fiberglass? any ideas?
My wheels and tires tuck if I were to slam the vehicle down to the ground..
but the bottom needs to kick out slightly to make room for the wheel/tire..
I taped some cardboard onto the tire to use as my gap..
are my angles looking ok or are they too steep?
I'm going to weld the frame together and use some wire to make an outter frame to fit snug..
If you have any ideas what to use to cover this, kick em my way..
I'm taking my time and in no rush
heres my mockup.
be kind, I've never made these
Top view
back view..
any constructive criticism is truely appreciated..
Thanks in advance
Old 03-08-2008, 04:55 AM   #2 (permalink)
EcoModding Minded
Chris D.'s Avatar
And I actually think it'll look pretty cool as well..
I'll have to fire up the compressor and hit it with some factory paint..
Rendering..
Old 03-08-2008, 06:44 AM   #3 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Quite decent.
What material is that cover?
Coast long and prosper.
Old 03-08-2008, 09:17 AM   #4 (permalink)
Doesn't look like a bad start to me. Lets see it finished!
Old 03-08-2008, 11:29 AM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Yeah, it looks like you're on the right track! Excited to see the finished product,
Old 03-08-2008, 04:43 PM   #6 (permalink)
EcoModding Minded
Chris D.'s Avatar
Originally Posted by brucepick View Post
Quite decent.
so far its just metal flat stock..
I'm thinking glass is the way to roll when covering it..
Old 03-08-2008, 04:49 PM   #7 (permalink)
EcoModding Minded
Chris D.'s Avatar
I took that off weeks ago, I also ditched that billet grill, dropped 8lbs..
Old 03-08-2008, 04:52 PM   #8 (permalink)
90 day: 51.82 mpg (US)
Chris: check AndrewJ's Civic CX aero mods thread - he used some thin plastic to form his wheel skirts.
I'd like to see someone do some foam sculpting to make a set of glass skirts though. Mostly because that's what I'm thinking of doing for my partial Kamm back this summer, and I'd like to learn from someone else's mistakes rather than my own .
I second Frank's comment: lose the bug deflector. If it's there to protect the paint, I'd put on some of that plastic film instead.
EDIT: whoops, I see you've already taken it off.
Old 03-08-2008, 05:02 PM   #9 (permalink)
EcoModding Minded
Chris D.'s Avatar
I've made lots of stuff doing foam/fiberglass work..
I use expansion foam, let it setup and shave it as i see fit,
then I lay glass on it..
then you pour gasoline inside and it eats away all the foam..
watch what a drop of gasoline does to styrofoam..
Old 03-08-2008, 05:39 PM   #10 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
if it were me i would bring it back in slower on the bottom back edge.
i would keep it high enough and/or out far enough to be able to get the wheel off with the suspension all the way down.
Name:	airfoil image.gif
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Done: A-B-A test on rear wheel skirts - Corolla, Camry Hybrid MetroMPG Aerodynamics 11 06-06-2009 03:49 PM
wheel skirts for 91 civic bbb3108 Aerodynamics 11 03-11-2008 12:39 AM
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-27-2008 11:23 PM
