09-11-2014, 12:22 PM
#131 (permalink)
Hypermiler
I went hunting for this very reason, and found a theory that fuse 39 (IGP) may be the right one to kill the injectors instead. I may go out there an pull it just to find out.
* on the 2nd gen "GE" Fit.
09-11-2014, 01:28 PM
#132 (permalink)
Rat Racer
From what I've seen, IGP (ignition power) may also power the ECU in some Hondas.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
09-12-2014, 10:34 AM
#133 (permalink)
Hypermiler
Yeah, it might. I miss the huge tuning community from when I had my Civic. Details like this are hard to track down with a smaller volume car like ours.
09-12-2014, 08:26 PM
#134 (permalink)
ALL UP ON THE INTERWEB!!!
Here's my kill switch, a normally closed momentary contact switch ( like a backwards doorbell )  . got it at menard's for about $4 or so, don't remember.
I followed california98civic's how to - this applies to 96-00 civics here: http://ecomodder.com/forum/showthrea...vic-18242.html
I can reach the switch with my hand on the shifter in any gear, and this looks clean enough for me ( my car is a mess ):
Enjoy!!
09-15-2014, 09:51 AM
#135 (permalink)
Hypermiler
"Whatever you do, don't touch the red button!"
09-15-2014, 09:56 AM
#136 (permalink)
Rat Racer
That's why I got a black button, and why I'm still trying to pick a spot that's convenient and... unobtrusive. And why it's momentary open and not a toggle.
Some things just don't really belong in a family car.
09-15-2014, 10:33 AM
#137 (permalink)
Furry Furfag
Originally Posted by MetroMPG
If you're concerned the injectors may spray added fuel before the engine stops, search on IC: there's a second, more complicated method that involves wiring the kill switch to 3 relays (which you add) on the fuel injector circuits for each cylinder instead of killing spark via a simple switch.
I didn't think it was worth worrying about. Caveat Kill Switchor.
One last question, how did you keep the battery charged with the engine off all the time? I wish regen braking worked with the engine off...
09-15-2014, 10:42 AM
#138 (permalink)
Simple: if you have to brake, leave the engine on or restart it (shifting into any gear restarts it automatically).
Also: I rarely used assist (clutch switch mod), so I didn't drain the battery much.
09-15-2014, 11:39 AM
#139 (permalink)
Originally Posted by andrenoites
Could it be F31 the fuse that I have to disconnect?
If I pull the fuse with the engine running no warm will happen to the engine right?
09-16-2014, 12:32 AM
#140 (permalink)
Fusion - '16 Ford Fusion Hybrid SE
Here's the switch on my 98 Civic. It's a spring loaded NC switch from a hair blow dryer - the one that turns the heat off for fan only - hence the blue colour.
