Old 09-07-2008, 02:18 PM   #51 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Originally Posted by dcb View Post
Update, sorry this didn't sink into my head till now, but on the metro at least (and probably many other cars) YOU ONLY NEED TO INTERRUPT THE CAMSHAFT SENSOR CIRCUIT. I just ran some real world tests to confirm this. This would be a good wiki thing.
Oh, excellent idea! Does doing this trigger the Check Engine light?
Old 09-07-2008, 02:24 PM   #52 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Not on a 98 metro. But if it does on other cars then we should add a column to the hypothetical wiki table to indicate that.
Old 09-18-2008, 06:33 PM   #53 (permalink)
METROANNOSAURUS REX
FunkSkunk's Avatar
The Mach .05 - '98 Chevy Metro LSi
90 day: 48.88 mpg (US)
Ok I'm lost is there a write up for 96 & newer EOC cut-off switch? Or will the original work for any year Metro? GREAT THREAD btw!!
Old 09-18-2008, 09:17 PM   #54 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
Thanks, and I believe you could adapt this to work on 96 newer as well, or any car with enough knowledge. I may switch mine to dcb's way of the camshaft sensor. Especially when my MpGuino stuff is waiting at post office for me.
Old 09-18-2008, 09:37 PM   #55 (permalink)
METROANNOSAURUS REX
FunkSkunk's Avatar
Sounds good! I'll have to look over my factory service manual and see where I need to splice in to make this happen! Thanks again
Old 10-06-2008, 01:56 PM   #56 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
Hi, I have a 1993 Metro that I am modding.
What is the benefit of cutting the injector wires, or the coil power, or the cam sensor, etc, instead of just cutting the ignition wire from the key switch?
Is there any reason I shouldn't simply install an SPST toggle switch in the ignition wire (black with blue stripe) coming from the key?
Also, can anyone tell me the purpose of the big yellow wire with the black stripe? It is currently disconnected with no apparent effects.
Old 10-06-2008, 02:06 PM   #57 (permalink)
90 day: 51.82 mpg (US)
Depeding on the OBD-II protocol your vehicle uses, cutting the ignition may cause a ScanGauge to shut down and take an unacceptably long time to re-initialize after you turn the power back on again. During that time, it's not recording speed/distance, and over time will skew the SG data and become a pain in the butt.
The ISO protocol in the Metros is one like this.
The other kill switch methods stop the engine witnout interrupting power to the SG, so it continues happily factoring speed/distance into the MPG calcs while instant MPG sits at "9999" (the SG value for 0 fuel use.)
Old 10-06-2008, 02:09 PM   #58 (permalink)
A 1993 Metro doesn't have OBD-II, does it?
Old 10-06-2008, 02:11 PM   #59 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
Well, that and I wouldn't want to power cycle the ECU any more often than necessary...
Old 10-06-2008, 03:27 PM   #60 (permalink)
Good point, Clev.
Nope, it doesn't, hypermiler01.
I didn't know what kind of car you had when you posted your first question. You'll be wanting to build yourself an MPGuino for your instrumentation, and it's not affected by ignition-off.
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Kill switch accomplished homeworkhome53 DIY / How-to 22 08-11-2011 02:19 PM
Geo Metro Kill Switch Idea? HotRod EcoModding Central 5 01-27-2011 06:13 PM
help W/ Remote Kill Switch Idea 93hatchDX DIY / How-to 21 07-31-2008 03:46 PM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
