Old 02-05-2019, 10:46 PM   #201 (permalink)
90 day: 29.78 mpg (US)
There is a cheaper version which lacks a balance circuit. You may be fine without it.
https://www.batteryspace.com/lifepo4...assed-dgr.aspx
That's the one I've been running in my Prius for the past 3 years. Haven't even checked up on it yet.
Old 02-06-2019, 07:34 AM   #202 (permalink)
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Believe I've gotten to the bottom of my issues - looks like the 12v lithium is gradually dying over the course of a few weeks, and I don't notice it until the voltage drops very sharply near zero charge as the caps still have plenty of starting current. It's losing more charge while the car is sitting between drives than it's getting back while driving. I'm unsure if the balance circuit(s) are primarily responsible but I'm thinking removing the resistor between battery and caps will let it get fully charged on my short commute. I'll investigate the balance circuits this weekend.
Old 02-06-2019, 08:49 AM   #203 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Or a bypass relay for the resistor.
Old 02-06-2019, 08:57 AM   #204 (permalink)
The point of the resistor was to limit charging rate in winter, and unfortunately it seems to be doing that too well.
redpoint5 (02-06-2019)
Old 02-06-2019, 11:24 AM   #205 (permalink)
Oh, gotcha. I thought the resistor was to limit starting current, and that the alternator fed directly to the battery.
Old 02-07-2019, 09:22 AM   #206 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Sounds like you need a low voltage cut. Maybe if you're starting current is low enough with the caps you could find a low voltage cut with an appropriate rating.
https://www.amazon.com/Volt-Voltage-.../dp/B00KI1Z8TY
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 02-07-2019, 11:11 AM   #207 (permalink)
I've read that a starter might be expected to draw 80-120 amps average, but that the initial current rush could be as high as 4-600 amps.
Old 02-07-2019, 11:14 AM   #208 (permalink)
What ohm resistor did you put in series with the supercaps?
Old 02-07-2019, 12:04 PM   #209 (permalink)
The resistor in series with the batteries is 0.3 ohms.
Here's a rough diagram, minus fuses/breakers:
Old 02-07-2019, 12:34 PM   #210 (permalink)
Seems like the battery should be topped up well enough at that low resistance. Would be curious to throw some meters in there to see what's going on. I picked up a few for something like $10 each.
Similar to this:
https://www.amazon.com/HTRC-Precisio...ne+power+meter
