Old 12-21-2019, 01:40 AM   #81 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Continuing the conversation
Throwing some ideas out on how to flesh out the skin for race only rear IC
1 rules state bed cover cannot be higher than the top of the bead rail. They only state a max NO min. So Im thinking a verry large NACA duct 'ish.
Top "contoured plate"
never fails...
Bottom with an additional section forming the front half of the NACA duct.
From the back with the horizontal part of the Bonneville spoiler.
3/4 view with a pice of 3/8 polycarbonate twin wall( similar to colorplast) 8"x58" +2"gap adding up to regulation 10". 58"is the inner plane of the rear tires.
Set the tailgate at an upward angle to match the diffuser starting at rhe differential.
For the street. Flesh it in the same as the front. Same twin wall 2' x 8' bent qith a heat gun needed 10' to makeit match the IC correctly.
For the front.
ID:	27348   Click image for larger version
ID:	27350   Click image for larger version
ID:	27351   Click image for larger version
ID:	27352   Click image for larger version
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following 2 Users Say Thank You to gumby79 For This Useful Post:
aerohead (12-26-2019), BamZipPow (12-31-2019)
Old 12-21-2019, 02:24 PM   #82 (permalink)
I think I see what you're getting at. If you step back a bit there'd be more context.
So, no more camping out in it?
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
Old 12-21-2019, 05:54 PM   #83 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
Ran out of yard the driveway ( where I did the mock-up) is 18" wider than the truck. And the nabors dog will not allow me to brake the plane of the property line
The rear mount IC idea would be for after 150mph when going for a LSR . LSR comp requires a suport /push rig(not allowed to move a "race"rig under its own power except on the track), so sleeping quarters would be in the tow/push rig, or the camping aera at "the bend in the road".
Former
87' Hyundai Excel
The Following 3 Users Say Thank You to gumby79 For This Useful Post:
aerohead (12-26-2019), BamZipPow (12-31-2019), freebeard (12-21-2019)
Old 12-21-2019, 07:10 PM   #84 (permalink)
If your neighbor's dog is that finely tuned, then lucky you. I'm surrounded by tiny trailers that have little dogs inside that go off, and their enablers shouting 'shut up! shut up!'.
I guess I get it. It looked like it was already halfway done.
This likely the first picture I ever posted on Ecomodder. I wanted to suck air through the Beetle's back window to create a 'roostertail' full of downforce:
The seats would have been an EMPI fiberglass rear [bucket] seat moved forward, IOW teardrops around the X-point (posteriors).
For the 4" steel wire brush U-shaped air dam, just drive on concrete roads for the first 10s of mile until it 'seats in'.
________________
Old 12-21-2019, 08:02 PM   #85 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
This is what I skeched about a month ago for minding the rules .
Use an extended cab short bed. This wluld alow moving the seat back to give me some leg room . Then mod the floor to form the duct through the front bulkhead.
The part above the open tailgate is the Bonneville spoiler.
The duck face to the right is a front view of the truck . The blue mock up was a twin flat bed sheet, to give me an approximation of what the shrink wrap will look like.
What I see as ideal would be to turn the contour inside out. A shot without the CAD hood scoop it is aloud 11"tall at the center line and 11" eather side of center.
What the inside will look like when the wight pice is finished.
7°taper=9:1. 3-6"R at the IC core.
ID:	27355   Click image for larger version
ID:	27356   Click image for larger version
Former
87' Hyundai Excel
Old 12-21-2019, 08:13 PM   #86 (permalink)
Luigi Colani[RIP] would approve.
________________
Old 12-22-2019, 08:23 AM   #87 (permalink)
I've kind of lost track of where you are with this project; are you shooting for 2020 and which event?
Old 12-27-2019, 02:35 AM   #88 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by gumby79 View Post
This all started in 2013 when my cousin sugested theres a pile of steel and that I build one of my Ideas . It became the "Aero Tonto".
Sorry no pictures the sight is not allowing at this time.
To those that dont like WOT this is not a thred for you sorry context in too important.
3.08 final rear end will help a bit
that is what gm uses for highway gearing at 85mph it's barely spinning at 1900rpm in V4 mode..
Old 12-27-2019, 04:06 AM   #89 (permalink)
gumby79's Avatar
Team Streamliner
Pickups
I'd love to throw a 10.5" 14bolt with 3.08 gears Detroit locker and disk brakes, if you could send me a link to a sorce For the gears.
85 with 3.08, 31.7" tires , is 1693 in 6th gear,(.61) 1971 in 5th(.71).
This makes prime speeds @ 1900 (splitting peek hp and peek TQ) are 58 4th(1.0), 82 5th(.71), 95 6th(.61)
2 more major purchases left (for130mph). Hoping for 2020 world of speed.
1 a devorced Drop Box from SCS (a midmount quick change single speed transfer case)
suitable tire and wheel package (100v rated min100(Y) would be ideal)
Jan i installed a Hx35. Improved spool and increased max pressure by 5psi
February I visited Aerohead, he donated all the personal safty gear needed through 150mph, helmet, fire sute, and parachutes needed for 178 and up.
April I installed a 6sp Allison trans witch got me to103mph from 92.5from the stock RH46.69OD. With better OD 5th .71 6th .61 and lockup torque convertor. Makes it like 7gears.
July-sept , I tested a BW S366/80 .80(16cm) turbo with and without a custom 2 into 1 t-3 spacer ,reduces the exhaust housing size by hafe. turns too big by 1-3 sizes for current OEM fule settings only able to muster 10psi(12psi was stock) into 20psi with spacer/ reducer(3 psi better than upgraded stock ). I got the injectors repoped to 258bar and spray pattern confirmed(they were down to 209bar). Reinstalled HX35 with the BD Diverter valve (quick spool valve, QSV) dose the same as the 2 into 1 spacer under low boost but opens to full flow by 20psi. Almost spools 1psi @ idle takes ~50° egt bump to hit 1psi, this is down from 200+ in gear.
Installed a MPG 12C from The Sensor Connection. Com. 12probe egt with max recall, 3 minute color graph display, 4 alarm set points (2 for all egt and 2 for the rest "CHT")
Dec installed a hot air intake using the stock 1st gen filter on a 2nd gen air filter pipe. 2nd gen is a 180° off the turbo and places the filter between the exhaust manifold and finder next to the cowl. In preparation for the cowl induction hood scoop. With the HAI just befor Christmas at the idaho-montana border I was seeing 11° intake (air at filter) 112° post Turbo, and 9° at the intake manifold. This was with the top 10" of rad blocked with cardbord and 12" of the passanger side (IC hot side ,rad cold side) top to bottom blocked with cardbord also.
Currently working out plans for 2 body kits. 1 to comply with race rules above 150mph and 1 for best practice (daily driving/40mpg) up to 150mph.
Per current race rules Body Mods are extremely Limited for pickups only cars have classes that allow almost full modification. Wile at Bonneville Last Summer I talked to some of the rules folks about getting things more of an even Keel between diesel and gass/fule cars he said nah we got too many classes , as it is there's over 800 classes. Over 200 of those are just for roadsters.
body mods allowed are a bead rail or lower rear deck lid, hood scoop, and grill mods not extended more than 1/4" past a plan farthest forward point of the original bumper and its original position
For 150mph and up will require installing a cage as well.
It depends on which is king HP or TQ as to how much more aero is needed for 130mph
Former
87' Hyundai Excel
aerohead (12-28-2019), BamZipPow (12-31-2019), slowmover (12-27-2019)
