Old 08-28-2010, 08:54 PM   #41 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Well I tried it out tonight
I only hooked up one actuator (both are fully set up I just undid one wire). The actuator fired just fine, but the epoxy broke right off the grate slider (plastic).
I need some ideas on better attachment ideas.
On this pic you can see the lever that needs moving via the actuator rod:
Ideas please!!!
Old 08-28-2010, 09:09 PM   #42 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
I'd try to attach it to this bar. Maybe where the brass rivet is?
Old 08-28-2010, 09:10 PM   #43 (permalink)
what does the grate slider connect to? Could you screw it to the slider?
Old 08-28-2010, 09:16 PM   #44 (permalink)
Wiki Mod
it connects to the rotating stuff (in pic above you post) and to the louvers via the brace rivet.
Patrick: how would you take the vertical motion and move it so it does not bind?
closed:
Open:
Old 08-28-2010, 09:22 PM   #45 (permalink)
i would put a screw through the slider but if that didn't work why wouldnt pushing on the brass rivit work? isnt the actuator and the slider parallel? simply connect something between them.
Old 08-28-2010, 09:27 PM   #46 (permalink)
Patrick's Avatar
Can you move the vent assembly towards the rear of the car some, maybe 1", so that the vent bar and the rod from the actuator are in alignment vertically? If so, you might be able to put a screw or rivet through the open hole in the vent bar so that it actuates directly. Hopefully the actuator rod has enough play/movement to allow for the front-back movement of the vent bar.
Old 08-28-2010, 09:28 PM   #47 (permalink)
Wiki Mod
The slider is plastic and thin, any screw will break it
If I turned the grate around I could attache the acuator to the bras rivit spot, but how to do that with a round rod?
Old 08-28-2010, 09:30 PM   #48 (permalink)
Wiki Mod
the actuator does have some play to work with.
How to attache the round rod to the hole in the vent bar?? the rod is like 1/8" or less in diameter.
Old 08-28-2010, 09:35 PM   #49 (permalink)
Patrick's Avatar
Can you adapt that clamp that's shown in the pics? Or maybe a bicycle brake cable clamp?
Old 08-28-2010, 09:36 PM   #50 (permalink)
hmm if you have a threaded rod you could drill a hole in the plastic knob put the rod through and put a lock nut on each side of the knob?
edit; nm its pretty slim
Arduino controlled automatically actuated grill block Daox Aerodynamics 167 11-08-2016 11:23 AM
Piwoslaw's Peugeot 307sw modding thread Piwoslaw EcoModding Central 295 03-28-2016 03:25 PM
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
another project idea: electronically controlled grill block rjacob Aerodynamics 3 07-10-2008 04:36 PM
