Old 06-13-2008, 09:32 PM   #21 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Here is the transmission installed in the car........................
Here is the hose and O-ring from behind the water pump......................
I had to remove a 10MM bolt located on the block just above the starter and carefully wiggle it free. I found an O-ring the same size from a simple shop O-ring kit, added some vaseline to it and when the hose popped on, it felt good. It felt real good. After burping the coolant, we went for a 20 mile ride and the car feels like a completely different vehicle!
GeoMetroforum.com - got mpg?
Old 06-13-2008, 11:45 PM   #22 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Thanks for all the 'how to' pictures !
Old 06-15-2008, 05:46 PM   #23 (permalink)
Hi-Tech Redneck
Well, instead of fixing the car, it's nice to just drive it for a change! The new trans is sooooo quiet and shifts very smooth. I am actually glad I fixed this car instead of just junking it.
I have gone through a lot of cheap, beater cars, but anytime something major went wrong, I would just get rid of it. This car is a different story and even though I had to do 2 major repairs on it, it's still saving me money in gas.
Old 06-16-2008, 10:46 AM   #24 (permalink)
90 day: 51.82 mpg (US)
Nice thread, Mullet!
I also did the blank/silicone installation over the passenger side mirror gap, but took it off this spring - the plastic I used wasn't as thick as yours, and its edges started curling up (probably from getting hot in the sun). I need to do v.2.
Old 06-16-2008, 12:49 PM   #25 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
We have half dozen or so old mud-flaps laying around at the shop, I never even thought of using one for the blank-off for the mirror. I justed lurked around the boneyard till one came available.
Keep it up JM I've enjoyed your thread and will probably use some of your ideas (Chrome-In-A-Can) when I can finally get mine off the street for her re-man.
Schultz
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 06-16-2008, 08:15 PM   #26 (permalink)
Hi-Tech Redneck
A new car
The car has been doing good and I already notice a MPG increase. I was getting almost 59 MPG before the trans started grinding and slowing the car down and I believe I shall get close to that again.
This is not any kind of mod (unless you include sleekness ) or repair, but what the after affect of me cleaning up this hidden jewel for 5 hours today and boy was I surprised
Also notice the new wheel covers. They look good on the car and not intended for aerodynamics, but seem they might cut through the air better than the dished steel rim.
I will be making my permanent partial grill block here real soon and will post the pics up!
ABS Plastic wheel covers = $29.00
Last edited by Johnny Mullet; 07-21-2008 at 07:54 PM.. Reason: Updated pic with higher quality.
Old 06-16-2008, 10:03 PM   #27 (permalink)
Wow - that cleaned up nicely. Quite a turnaround from kicking it to polishing it lovingly
Glad to hear the efficiency is back. Did I miss it in the posts above... what exactly was causing the noise?
Those wheel covers don't look bad from an aero perspective.
(You should save your images as "JPG" instead of "GIF" though - better quality for photographs.)
Old 06-17-2008, 06:32 AM   #28 (permalink)
Hi-Tech Redneck
I did not know what was internally causing the noise and the junkyard needed the core, so I happily gave it to them. It must have been the idler shaft bearings or support bearings that were bad.
I actually resize all my photos from 1200 resolution to 500 so it's easily seen on the forums and using .GIF makes editing (adding text) to them a lot clearer. A crappy computer has trouble scrolling down these pages with oversized images resized by the forum software.
I like the wheel covers also. I will be updating my fuel log in a day or so. I got 1/4 tank left and driven almost 400 miles on 7.5 gallons so far. This is gonna blow away my 53 MPG average. I never knew a bad trans could hurt the MPG so bad, but after the replacement I can feel the difference and the car coasts better and don't downspeed as bad in gear. I think removing that extra mirror was a big help also.
The MPG shown on the car's profile is without "Pulse and Glide", "Engine off Coasting", or any other extreme hypermiling techniques. I use most of the common sense tips, don't idle, monitor my vacuum gauge, drive slower, and I am happy with the outcome.
Fender skirts are on hold until I complete my partial grill block.
Old 06-17-2008, 08:33 AM   #29 (permalink)
Certified Freak
Greenblazer's Avatar
Greenblazer's Taco - '07 Toyota Tacoma PreRunner Double Cab SR5 V6 4.0Liter
90 day: 24.54 mpg (US)
Go Johnny, go Johnny, go Johnny go! I am starting to miss my '87 Chevy Sprint Turbo that I bought new back in 1988. Good thread thank you!
Later,
Allan Greenblazer
Old 06-17-2008, 08:58 AM   #30 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Toyota Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 Trek 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Honda Civic DX
90 day: 33.29 mpg (US)
Still wish I could find a good MANUAL transmission metro. I found one in an automatic, but the mpg difference is astounding between the two.
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 10:31 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 01:21 AM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 04:05 PM
