Old 06-16-2008, 10:13 PM   #1 (permalink)
dwendt1978's Avatar
Dragon - '93 Geo Metro XFI
90 day: 51.13 mpg (US)
EOC miles per tank
How many EOC miles do you guys get per tank. I figured if you got around 50 that was good. How many does it take to really boost your mileage. The 16.6 I've gone already is at 60 mph, I kill the motor and let it coast to 15 mph which usually nets me about .5 miles to 1 mile at a time.
So far if gone 16.6 EOC to 45 miles with engine running.
Old 06-16-2008, 10:17 PM   #2 (permalink)
90 day: 51.82 mpg (US)
When I tested Engine Off Coasting against idling while coasting in strictly sub/urban type driving, I saw 12.9% better fuel economy using EOC. The engine was off for 3.9 km of the 9.7 total, or 40% of the distance travelled.
Coasting experiment: engine off VS. engine idling
Old 06-16-2008, 10:25 PM   #3 (permalink)
is awesome
I turn my car completely off when eocing. The odometer doesn't turn this way but it is the most energy efficient method.
I would guess that I do it for 12-15 miles for every 160 miles of engine on driving.
KU School of Engineering
'72 Datsun 240z
'96 Chevy lumina
Old 06-17-2008, 12:50 AM   #4 (permalink)
Iwishthiswasamanual - '98 Ford Escort ZX2
90 day: 32.95 mpg (US)
You realize thats terribly unsafe? No airbags.
Not to mention, how can you justify any fuel savings if your odometer isn't moving. I mean really, your numbers are going to be much much lower than real mpg.
Old 06-17-2008, 01:11 AM   #5 (permalink)
is awesome
As far as safety goes, airbags are at the bottom of the list of things to worry about in my '72.
'72 Datsun 240z
'96 Chevy lumina
Old 06-17-2008, 07:21 AM   #6 (permalink)
Baz - '93 Peugeot 106
90 day: 62.39 mpg (US)
The thing I'd be more concerned about are your brake lights with the electrics off.
Goal: 3L/100KM
Old 06-17-2008, 08:11 AM   #7 (permalink)
POS - '97 Ford Aspire
90 day: 47 mpg (US)
brakes lights are not tied to the ignition ckt; they ALWAYS work. Try it when you go to start your car next. before putting the key in, step on your brakes and look for the reflection or glow of the lights. turn signals, on the other hand, are will not work w/o the key in run
Back on topic: i EOC for about 8 miles of my 50 mile round-trip to work.
Old 06-17-2008, 08:58 AM   #8 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.47 mpg (US)
Can you just let the engine die, then switch back to IGN ON? That'd fire the odometer back up, and the airbags and turn signals would be active (though I do my EOC on long straightaways, and hold the right lane).
Old 06-17-2008, 09:42 AM   #9 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
wish i could EOC more, but im on single lane roads so I try to keep up to the speed limits here.. If i had a dual lane hiway id be accelerating to the speed limit then EOCing to 10mph below then accelerate back again then EOC to 10 under.. the entire time .. However here if i did that id be ran over in the CRX for impeding traffic .. \
Heck, today accelerating to the 55mph speed limit a tahoe accelerated past me at 50mph to get around me.. it was a co worker.. on the road to work.. she got to her parking spot 10 seconds before I did and I was doing the speed limit, not hard accelerating, and EOCing in that 5 mile stretch where she passed me from a stop sign..
Literally I pulled into works parking lot and she was still gassing it around the parking lot to find that "primo spot".. I rolled in and coasted up to my parking spot near the rear of the lot with very few other cars.. I was out of my car and walking before she got out of her SUV. All I can think while walking into work is 15mpg vs 47mpg.. and I'm walking into work before she is.. why did you pass me again?
Old 06-17-2008, 09:47 AM   #10 (permalink)
Technically you're describing Pulse & Glide, not EOC.
EOC is simply occasionally coasting up to stops or turns, or down grades. P&G is a repeated cycle out on the "open road", as you describe. It's a fine distinction.
The acetone test trikkonceptz EcoModding Central 88 06-16-2008 10:27 PM
EOC fuel usage ?'s reformed EcoModding Central 4 06-12-2008 08:51 PM
new to EOC homeworkhome53 Hypermiling / EcoDriver's Ed 12 06-05-2008 12:09 PM
First tank w SG homeworkhome53 Instrumentation 3 04-13-2008 11:57 PM
EOC Question - what did i do wrong? Doofus McFancypants Hypermiling / EcoDriver's Ed 12 02-15-2008 01:18 PM
