09-09-2013, 12:54 PM
OBII Smarter than us?
OK I have tried a lot of things on a 2000 Mercury Grand Marquises. (HHO, water injection with and without Menthol, resetting Air/Fuel ratios, many interrupts to the sensors, gas additives, throttle body mod, )
This is an OBII car. And nothing seems to be able to get better than 34MPG.
So the question is: Are these programed to keep ANY improvement from working, IE is the computer stopping me.
Has anyone had any real progress with any of these cars? (And I don’t mean hypermileing…)
I want to be able to make better MPG in all OBDII Cars.
Rich
09-09-2013, 01:22 PM
Well, you could try things that are known to work. Grille block, air dam, wheel covers, belly pan, tire pressure, LRR tires, the list goes on.
22 Maverick: TBD
09-09-2013, 01:23 PM
I need to get me some of that menthol-flavored water. Mmmmmm
09-09-2013, 01:48 PM
...beats walking...
Blame it on EPA / CARB emission regulations, because of these 3 facts:
• best POWER occurs at about 12:1 AF-ratio, for E0 gasoline.
• best ECONOMY occurs at 16-18:1 AF-ratio, for E0 gasoline.
• todays ECM's maintain 'stoichiometric' 14.7:1 AF-ratio in "closed-loop" operation for catalytic convertor operation.
09-09-2013, 01:57 PM
I have devices that allow me to reset the Air/Fuel ratios, and found that on the car 16.7 to 1 gave apox 34MPG with a major lost of take off power.
So IF I had a way to change that setting automatically for cursing (a lean cruse setting) then I could gain something like 5MPG, but at a cost of around $200.00 to $300.00 to have the computer reprogrammed don't consider it cost effective.
As for the other ideas, A) the car has a air dam, aerodynamic side mirrors, hidden wipers (Under the hood) B) The rest are impractical, I ran stock tires and got 27 to 30MPG and then switched to safer 18 inch sticky tires so I can hold the road and stop best and lost 1 to 2 MPG, I will take my safety over MPG any day.
I am in AZ with 115+ temps and have a hard time keeping the engine under 200+ in the summer...
Rich
09-09-2013, 02:26 PM
In the fasting lane
On fuelly the Grand Marquis typically gets about 20 mpg on average.
34 mpg would be hard to beat. If you're not satisfied then maybe this isn't the right car. But a small car or a hybrid could almost double it if driven with some TLC.
The things you list in your first post have been proven to have little effect, if any. Just check them out with the search button.
As you get 34 mpg you'd know a thing or two about driving economically, but at the risk of elaborating the obvious:
- Get a OBD2 FE monitor like ScanGauge or UltraGauge,
- Keep a fuel log, and log anything in it that deviates from the usual,
- Digest the 100+ Hypermiling Tips and 68+ Efficiency Mods linked on top of this page,
- Pump them tires...
 lifetime FE over 0.17 Gmeter or 0.1 Mmile.
Investors woes:
"In hindsight, I should have placed a bet on the horse that won the race"
"In hindsight, I should have bet more on that horse"
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
09-09-2013, 02:45 PM
First, I have BOTH MPG Gauges as I found the scangaugeII is easily fooled by tricks done to the sensors (I had it reading 45MPG when in fact the car was only doing 27MPG. So I run a MPGunio as well.
Second 24/26 is more common for these cars as I also belong to a Ford site and we have discussed this fact.
Third I thought I was asking this question on a site that deals with making MPG, making changes that make MPG.
Forth a funny thing happens if I pop it out of gear, the RPMs go higher...
( MY 93 Chevy and 91 Toyota don't pull this, both drop to idle as I coast...)
So I was hoping to find out IF it is the ECU.
OH FYI I HAVE seen a Toyota and Hyundai get over 60MPG on HHO.
And we did the full test, 100 miles: 50 Miles one way and then back same day full tank.
Rich
09-09-2013, 02:49 PM
This is really all you need to know.
09-09-2013, 02:54 PM
#9 (permalink)
Really??
WHY?
Rich
I was hoping to get real info here...
I already know if I draft a Simi I can get great MPG as long as I don't run into him and the driver doesn't get mad at my tailgating him, (most do) or drive down hill all the time...
09-09-2013, 04:02 PM
#10 (permalink)
In the fasting lane
Ooh..! So what I wrote wasn't real? Sorry for that then.
Fuelly is wrong? You say so.
The 100 Hypermiling Tips and 65 mods are no good, you want the REAL stuff? Sorry, that is just for members that know the Secret.
No, just kidding, if we knew anything better it would be on those lists.
You want info but we just have to work with what you provide. You did not tell you had those OBD2 gauges until I mentioned them. And I did apologise in advance, still you, well...
But do not worry, I will not bother you again.
(unsubscribed)
Investors woes:
