Old 09-20-2014, 08:17 PM   #141 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I hate trying to diagnose car problems on the internet. Fyi, ive never used a pressure tester before.
Have you replaced your pressure cap?
Here's an idea, pump it up to 16psi and let it drop on its own. Do this about a dozen times then try and start the car. If it wont turn over from being hydro-locked you know you have a bad headgasket
Old 09-20-2014, 08:18 PM   #142 (permalink)
Have you pulled the spark plugs? I have heard sometimes you have antifreeze dripping off of those, which is a bad sign.
ScottyKilmer.com recommended Real Steel for head gasket leaks. I may have lost all respect for him right there, the Hugh Jackman movie might be better for your car than some weird product, but he pointed out that there were not any dissolved solids, so it should not clog anything. I also like Eric the Car Guy, but find Scotty to be slightly annoying. Here Eric shows parts after someone uses Stop Leak and it messed up everything:
Any "stop leak" type crap you pour in the radiator will plug up a lot of things you don't want to even think about replacing.
regards
mech
Baltothewolf (09-21-2014)
Old 09-20-2014, 08:42 PM   #143 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Old Mechanic View Post
Already posted I think it a head gasket. Cold it should hold pressure. Starting the engine with the tester installed and then letting pressure gauge max out is a terrible idea. You could blow a lot of things with that much pressure.
If it's loosing pressure cold, the you tell me where that pressure is going in a sealed system. I've already told you where I think it is going and that you will not be absolutely certain until you visually inspect the head gasket.
I can smell the coolant from a leaking head gaskt following the car on the highway, smells kind of sweet.
regards
mech
Alright I have one more question. Do you know which way the fans are supposed to be blowing air through the radiator? My dad thought of this and won't stop telling me to ask you. In my car, it's blowing air through the radiator (and the condenser fan blows the same way) out twords the front of the car. Like so.
Old 09-20-2014, 08:47 PM   #144 (permalink)
Thats backwards.
LOLOLOLOLOL
No wonder its overheating, the fans come on and effectively stop all air from flowing through the radiator. And when stopped, its blowing hot air from the engine over the radiator.
Thats a first for me, never seen this before.
Im not familiar with the insight, I know its a special car so maybe it was designed this way?
Old 09-20-2014, 08:49 PM   #145 (permalink)
Furry Furfag
Yea the guys over at insight forums just told me the same thing, it is wired backwards. How do I fix this? What wires do I have to change?
[Edit]: No this is not how it's designed, the fans are running backwards haha... Wow...
Old 09-20-2014, 08:59 PM   #146 (permalink)
There is probably a plug that is backwards. You can see more than we can. Go switch it around.
Old 09-20-2014, 09:05 PM   #147 (permalink)
Push fan in front of radiator pull fan behind radiator. The fans running backwards could actually be the problem, reverse the connections, if there are only two wires.
regards
mech
Old 09-20-2014, 09:07 PM   #148 (permalink)
Originally Posted by ksa8907 View Post
Thats backwards.
LOLOLOLOLOL
More genius "mechanics". I may have seen that once but can't remember.
I'll bet that is the problem.
regards
mech
Old 09-20-2014, 09:15 PM   #149 (permalink)
No fan was ever designed to create air flow in the opposite direction of the natural air flow when the car is moving. I think you actually fixed it when you get them to pull air into the engine compartment. Had I know that to begin with we could have kept this thread to a few posts.
regards
mech
Old 09-20-2014, 09:22 PM   #150 (permalink)
Furry Furfag
regards
mech
Yea I never considered it, it wasn't until my dad brought it up that I checked it.
