Old 02-22-2014, 06:55 AM   #6261 (permalink)
Thumbs up
Hi Flores, what type of controller are you using , I have been waiting for Adam's but now I'm sort of giving up.
Good luck for your tyre ripping power I'd love it.
Old 02-22-2014, 08:12 AM   #6262 (permalink)
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
You can up motor current by turning VR1 on control board. Schematics say that full counter-clockwise should give ~495A. In my experience full CCW gives something between 400-450A. I never saw my motor amps go higher than 400 using that setting. Then, fully clockwise should set motor amps hardware limit to 775A. I believe this should be closer to "burn rubber"-setting. Be careful. System is tried and proved at 500A. If you want to have that 775A (or whatever it will actually be) going into your motor for higher rpms you need to up your pack voltage (higher motor voltage).
Now somebody please correct me if this isn't true. I'm about to turn that VR1 a bit more CW when I open the controller case next time. I still have studded tires so I'm avoiding any wheelspins anyway.
EDIT: but if you are using 1000A controller my advice is useless. I thought you had 500A version there.
Old 02-22-2014, 08:32 AM   #6263 (permalink)
EV Connoisseur
Paul once build three beta 1000A controllers, and this is one of them.
The 1000A definitely gives more power than the 500A, but I expected more. Turning VR1 doesn't make a notable difference.
Can't the controller also be made more responsive by tuning the internal software parameters?
Old 02-22-2014, 12:20 PM   #6264 (permalink)
PaulH
MPaulHolmes's Avatar
Hello! VR1 just changes the trip point for the last line of defense, which is the hardware overcurrent trip point. The software is what really keeps the current at no more than 500 amps. Fully CCW means the hardware is probably limiting the current to around 450-495amp.
I think I still have the "1000amp" code. I could look for it and try to make a change and email you the .hex file, flores. It wouldn't have a bootloader though, so you'd have to have a programmer. I wonder if I set the current to less than 1000amp for testing purposes, with the vague idea that later once it was working, that we would up the current. That feels familiar. I'll take a look at the code this weekend.
At my job I've gotten a lot of practice over the last year with chassis mount IGBTs, home made desaturation detection circuits, copper sheets, and film capacitors. My house is being powered by an inverter and MPPT tracker that I designed for that company that all use film capacitors and chassis mount IGBTs. I've been planning on doing a chassis mount DC controller for quite a while, now that I know how super easy those types of IGBTs are to work with. I have 6 600v 600amp IGBTs that were new from Ebay. Does anyone want to live dangerously and try out a prototype? I'd donate the igbts. I'm just finishing a project, and need something new to work on.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
flores (02-25-2014), mora (02-23-2014)
Old 02-22-2014, 12:43 PM   #6265 (permalink)
PLUGnGO
jedsmd's Avatar
Originally Posted by MPaulHolmes View Post
.... I've been planning on doing a chassis mount DC controller for quite a while, now that I know how super easy those types of IGBTs are to work with. I have 6 600v 600amp IGBTs that were new from Ebay. Does anyone want to live dangerously and try out a prototype? I'd donate the igbts. I'm just finishing a project, and need something new to work on.
Paul
I was just about to order the power components for your 500 amp controller, with intent to operate it at about 600 to 650 amps.
If you want to provide the design for an igbt controller power section I would be happy to build and test it out.
I have a 3200lb pickup with 48 Lifepo4 cells (about 175 volts peak, 144 working). Right now I am using a 850 amp Kelly controller which seems to be about the right amp rating for my vehicle and driving style.
Jerald
Old 02-22-2014, 12:45 PM   #6266 (permalink)
jackbauer's Avatar
Paul! Your back Didn't I tell you years ago igbts were the way to go Your new job sounds fun.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
MPaulHolmes (02-22-2014)
Old 02-22-2014, 01:18 PM   #6267 (permalink)
EV Connoisseur
Paul,
That would explain why the VR1 does nothing.. I have a programmer, so I could program the atmel.. isn't the code also on the wiki for the 1000? thought i've seen it.
I would also happy to test anything out.. and blow things up.. I have the hardware.. street legal EV, Lipo's and warp 9.. bring it on !!
Old 02-22-2014, 01:32 PM   #6268 (permalink)
EV Connoisseur
This one: https://files.secureserver.net/1sHJFxDBK3ObI7
Searched for it but can't find any max amps reference that quick..
Old 02-22-2014, 01:37 PM   #6269 (permalink)
EV Connoisseur
Also.. it seems like the serialport is not working... so I cannot check any config now..
At ttl level the serial is working, hooked up a logic analyser for that, but cannot send command with that..
Old 02-22-2014, 05:06 PM   #6270 (permalink)
I would love to help you with this
My skill levels for the electronics and programming are a bit low (putting it mildly) but if you think I could help I would love to be involved
The Following User Says Thank You to duncan For This Useful Post:
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
