Old 11-13-2014, 04:43 PM   #6911 (permalink)
dave koller's Avatar
Just as an unwelcome distraction we have 20 inches of snow (over the last several days) and still coming down.....
Dave ...
Old 11-13-2014, 05:55 PM   #6912 (permalink)
PaulH
MPaulHolmes's Avatar
It was 81 here today. Haha. I wish it was snowing.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
dave koller (11-13-2014)
Old 11-13-2014, 11:55 PM   #6913 (permalink)
Hi Paul
1000 amps is great - I may have to limit my throttle a bit - see what it drives like but I think about 700 amps will light up the tires
Old 11-17-2014, 01:40 AM   #6914 (permalink)
Hi Paul
Found I had a dead cell - had to rebalance one string
Anyway the controller is in place - its a monster!
Just thought I would double check about the motor wire(s)
The old controller was motor negative
This one is motor positive???
Just thought I should double check before completing the wiring
Thanks
Old 11-17-2014, 09:14 AM   #6915 (permalink)
PaulH
Yes, so you connect B+ on the controller to battery pack +. And the 3 M+ cables to motor plus. And B- on the controller to battery pack minus AND to motor minus.
kits and boards
Old 11-17-2014, 07:10 PM   #6916 (permalink)
Maybe this is a bit off topic, and admittedly I am new here(first post...). But after a bunch of lurking and reading; I was thinking...this project is simply amazing(duh), and maybe it has been brought up before, but I have a couple ideas.
First, I am sure someone out there could write an Android app for this...it could be very handy if part two is possible; integration with the vehicles OBDII computer. It could be possible to use one of the wireless OBDII "interfaces" already on the market (elm327) to then get access to the controller from the Android Device. I am assuming(and possibly showing my ignorance) that the vehicle's stock ECM is kept in place...especially for cars with PATS or something similar that requires the ecm to run in addition to all the 12v electronics in modern cars.
Just a few random thoughts I had...back to page...whatever it was... I think reading the whole thread will be a great primer for my own knowledge and skill level.
Thanks again....
The Following 2 Users Say Thank You to camusmuse For This Useful Post:
jedsmd (11-17-2014), MPaulHolmes (11-18-2014)
Old 11-17-2014, 11:16 PM   #6917 (permalink)
Hi Paul
Controller installed - its a wopper!
It goes - but only just
It failed to drive up the slope from my shed
I was getting about 20 battery amps at full throttle
I would guess less than 200 motor amps
No bangs smoke or loud noises
I suppose I had better take it back out to connect it to the computer
ID:	16440   Click image for larger version
ID:	16441   Click image for larger version
ID:	16442   Click image for larger version
The Following User Says Thank You to duncan For This Useful Post:
thingstodo (11-18-2014)
Old 11-18-2014, 02:22 AM   #6918 (permalink)
Controller back out - on my desk with the PiCkit attached and a serial - USB on that connector
Old 11-18-2014, 03:51 PM   #6919 (permalink)
PaulH
What sort of throttle do you have? Is it 0ohm to 5kohm at max throttle? I'm sure it's just a software setting that's the problem. Sorry about that. I'll check the max battery amp setting, but it probably is something to do with the throttle settings. I think there are 3 different throttles for the controllers, but just one C file that I change when one of them needs an update.
kits and boards
Old 11-18-2014, 03:58 PM   #6920 (permalink)
Hi Paul
Had a brain storm - I thought - maybe I connected the battery +ve to the motor instead of the -ve!
Put the controller back in the car - exactly the same symptoms
So that's not the problem
Throttle
I am using a 0 -5Kohm pot - the same one as on the 500 amp controller
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
