Old 07-08-2020, 12:40 PM   #171 (permalink)
Ecomodding Apprentice
The side panel was a success, 1630 grams, probably 1690 with the supports to go on. Well below the 2kg target. Battery covers and brackets, not bolted have to put some draught strip so it's mostly airtight
ID:	28661   Click image for larger version
Old 07-08-2020, 12:45 PM   #172 (permalink)
90 day: 40.51 mpg (US)
What are you down to now?
Old 07-09-2020, 09:29 AM   #173 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
This is absolute insanity, I love it.
not sure about the structural integrity of thin plywood doors, but i can definitely take some tips for removing weight out of the back of mine so that i can carry more luggage
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
Old 07-09-2020, 12:49 PM   #174 (permalink)
Who knows, the support strips turned out to be 3g each so thats pretty good so 1651g plus glue, paint and filler. I don't really have a final vehicle weight or mpg goal just to reduce the parts I can. There will be alot under the bonnet I can do but thats all framed up right now. The wheels will have to wait until next year but will be easy, just to make one mould.
There are no plywood doors, that was part of a mould creating process and are non-structural panels. The front doors will be x axis 1000g carbon fiber and 1000g 1000d kevlar with kevlar impact bars. I estimate to be 13kg and I'm thinking of no window winders so maybe less
by x axis I mean the cross section laminate thickness
The Following 2 Users Say Thank You to Nathan jones For This Useful Post:
bobo333 (07-09-2020), TexasCotton (09-15-2020)
Old 07-09-2020, 12:51 PM   #175 (permalink)
That makes a lot more sense, i didnt think plywood was lighter than carbon fibre.
Whats the overall weight of the car these days?
Old 07-09-2020, 01:25 PM   #176 (permalink)
I would'n't know and to me it's immaterial. Making it as light and aerodynamic as possible is important but it depends on what you need from a motor vehicle. 680kg and .22 would be a fair estimate once it's finished but again many other factors effect the vehicles performance and contribution to net worth
back to subject... I did make some mini triangle profile supports for the flat floor but will make I beams, from the ones I did on the door were way stonger and on a flat surface will be easier
Mclaren are supposed to be making a family car 800kg but it won't have a range above 150. Unless the motor flux is from ceremaic neodymium, not sure if the Japanese managed to mass produce it yet
bobo333 (07-10-2020), TexasCotton (09-15-2020)
Old 07-20-2020, 12:22 AM   #177 (permalink)
Cutting out the wheel well. I never did like it. With the bracket underneath I don't use it's 3.9kg down. The quickly made replacement is 600g glass
ID:	28762   Click image for larger version
ID:	28763   Click image for larger version
ID:	28764   Click image for larger version
ID:	28765   Click image for larger version
The Following User Says Thank You to Nathan jones For This Useful Post:
Old 07-26-2020, 03:45 AM   #178 (permalink)
The boot section, not my neatest cf but nice and strong. Also I need to spray before november so the front nose section changes I've decided to scrap for this year
ID:	28812   Click image for larger version
ID:	28813   Click image for larger version
ID:	28814   Click image for larger version
Old 09-15-2020, 09:59 AM   #179 (permalink)
According to a calculator, with 110bhp and a 0-60 of 6.8, 750kg should be in the ball park
More sanding and sanding. Not this year but many parts will be kevlar so chose white to keep the heat off
ID:	29136   Click image for larger version
ID:	29137   Click image for larger version
ID:	29138   Click image for larger version
Old 09-15-2020, 10:10 AM   #180 (permalink)
Making some lighter brackets, 65% reduction. There are some alloy ones next year but only 30%
ID:	29140   Click image for larger version
ID:	29141   Click image for larger version
ID:	29142   Click image for larger version
