Old 09-11-2012, 04:43 PM   #481 (permalink)
How are you going to support the coroplast on the top (and bottom)?
I'm picturing an aluminum bar from below the deck lid to the rear plate, then (cheap vinyl?) air mattresses, then the coroplast.
Old 09-11-2012, 05:04 PM   #482 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Ooh ooh can I join?
I'm still working on it but planning some sort of supports or X on there. Depends how the rest goes. First comes a hoop around the rear end to hold the front end of the plast, then comes the main cross bracing with angle iron. Then some more bracing around the edges to define the radius. Last, I'll see what's left for supporting the top plast.
I can't buy anything more until Friday (pay day) as I don't have much money left.
Old 09-11-2012, 07:11 PM   #483 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
If the tail is done we have an opening for a new member!
Old 09-11-2012, 07:11 PM   #484 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
Originally Posted by Sven7 View Post
The car is 23% longer than stock but still shorter than Detroit's behemoths.
177" -stock 1G Probe
218" -Anal Probe (adds 40-3/4" or 103.5cm)
232" -2012 F-150 SWB crew cab
222" -2012 Chevy Suburban
202" -2012 Audi A8
189" -2012 Toyota Camry
216" -1990 Frankenjetta (Current incarnation)
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 09-12-2012, 10:06 PM   #485 (permalink)
Sven7's Avatar
Didn't get much done today on account of the rain. I've been thinking about the pressurizing-the-wake-with-exhaust-gas theories and wondering if it would actually work... 1% FE maybe? Not planning on doing it, at least not now. But I totally could.
Old 09-12-2012, 11:50 PM   #486 (permalink)
Exhaust in the wake... like base bleed on an artillery shell. ;-) Doesn't much affect the trajectory or velocity but does make the shell retain more kinetic energy.
Boattail bullets enjoy a similar effect on retained energy over ones with the same weight, diameter and nose shape.
Old 09-13-2012, 07:32 AM   #487 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Just make sure the rear of the car is sealed well so you don't fall asleep at the wheel.
-Terry
Old 09-13-2012, 11:11 AM   #488 (permalink)
In the thread underbody-flat-belly-pan-suboptimal-explanation-solutions-offered-23159-new-post.html, MTrenk has mentioned exhausting the exhaust 'above' the diffuser. I keep bugging him but he hasn't addressed it yet. It might work best to add energy to the air before the wake instead of just trying to fill it.
I'm thinking about the relative volumes of exhaust, engine cooling air and the wake itself.
Old 09-13-2012, 08:55 PM   #489 (permalink)
Sven7's Avatar
Like I said, not going to happen right now, but I might think about it for the future. Doesn't sound like anyone's actually tried it.
Almost done with the structure.
Since I couldn't build radii all the way to the rear plate, I wanted to maximize the curves early on. You can see it achieves up to a 6" radius on the bottom edges, but only one or two up top. Hopefully it will help pressure differences work themselves out at least a little.
Almost Done! by Tyler Linner, on Flickr
Old 09-13-2012, 09:05 PM   #490 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
Looks very good.
