Old 08-14-2013, 03:41 PM   #201 (permalink)
90 day: 51.82 mpg (US)
Deja vu!
(PS: you're getting your fancy paint job dirty.)
mechman600 (08-14-2013)
Old 08-14-2013, 03:45 PM   #202 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Deja vu!
Yeah, it's a like a Forkenswift rerun, 6 years later!
I know! It probably doesn't matter, considering it will be hidden underneath the front battery pack anyway....
Old 08-14-2013, 03:51 PM   #203 (permalink)
Don't you want to advance it a bit more since you're running a higher voltage than the motor was designed for?
Old 08-14-2013, 04:04 PM   #204 (permalink)
mechman600's Avatar
Do I? I really have no idea.
From what read on diyelectriccar.com, 12 degrees seems to be the max for EV motors like Warp 9s and stuff like that. More advance has the same effect as field weakening, so less torque and higher speed. Finding the best amount of advance for any situation is trial and error.
I was very surprised at how much advance my motor has. But for now I think I will go with what it is and then test. If the arcing is too much I will have to advance more.
The Following User Says Thank You to mechman600 For This Useful Post:
Daox (08-14-2013)
Old 08-14-2013, 11:14 PM   #205 (permalink)
puddleglum's Avatar
Rondo - '07 Kia Rondo EX
Last 3: 20.47 mpg (US)
Tinkertoy2 - '00 Toyota Echo base
Last 3: 46.03 mpg (US)
Looking really good.
Almost all my driving is done 1-5 miles at a time.
Best short trip: 2.4 l/100 km, 3.9 km
Old 08-15-2013, 01:19 PM   #206 (permalink)
mechman600's Avatar
I got the motor back together yesterday and powered it up. Now it spins the right direction, so that's a good thing! It also seems to spin a bit faster than before (going by the pitch of the sound it makes). I don't know if this is because the battery cart was low on charge the first time I powered the motor (we use it to jump start Peterbilts) or if my brush timing is a bit off. The speeds seem to be very close, so I will leave it for now. You can hear the difference in the before and after videos.
Before:
After rotation and brush timing change:
The second one is much louder because the motor is running with the brush end up, as opposed to down in the first video.
Old 08-18-2013, 02:18 AM   #207 (permalink)
mechman600's Avatar
Yesterday I removed the motor from the Electric Booger. It was like removing a starter from a Peterbilt. Took a grand total of 50 minutes, which included dismantling and removing the front battery pack.
I took the opportunity to inspect my coupler. There is no way to get at my coupler when the motor is installed, so I was going on faith that it was still good. Close inspection reveals no noticeable wear after 1200 miles.
Maybe a bit rusty, so I will definitely put some grease in there this time.
I scribed a line around the old sepex motor before removing it from the adapter plate. I then gave the adapter plate and drive end cap from the new motor to my machinist buddy to drill and mount. I don't trust myself with this one.
Today I messed around with something I should have done right from the beginning: grille blocks. Here they are, made from the same chunk of plexiglass that covers my rear battery pack:
Contrary to popular belief, these ones are not for aerodynamics (although they may help me beat my top speed record of 60 mph). Instead they are meant to keep the rain off the front batteries, whose connections get corroded up pretty fast.
Old 08-19-2013, 12:11 AM   #208 (permalink)
vacationtime247's Avatar
The Toylet - '87 Toyota Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 TMEC Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Ford Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 47.52 mpg (US)
Ass Tick - '01 Pontiac Pontiac Aztek GT 5 Door
Green Baby Poop Stain - '01 Pontiac Aztek Aztek Base Model
Black Track - '01 Pontiac Aztek GT
Always like the MX-3 design. Looks pretty aero. Wanted to do a RF diesel conversion in one of these. Unfortunately though, after my recent move, it left me without garage space : /
VT247
Old 08-19-2013, 01:08 PM   #209 (permalink)
Same here!
Old 08-22-2013, 05:16 AM   #210 (permalink)
mechman600's Avatar
Tachometer Success!
Part of the plan here is to get the tachometer working. Although I don't REALLY need it, it would be cool to have. Currently the only gauge that works is my speedometer, which is lame.
Today I had a breakthrough. My friend Matt (the machinist) gave me a proximity sensor, which is basically a switch that turns on when metal is nearby.
My tachometer was originally fed a signal from the negative side of the ignition coil (which is the norm). I wired the proximity sensor this way to achieve a similar signal:
Since this was a four cylinder, with four engine position teeth in the distributor turning at half engine speed, I planned to put two pickup teeth on my drive coupler. Here is my wild setup to test it out:
A cordless drill with a hole cutting bit with two cutouts. In theory, my tach should accurately tell me the speed of my drill. So with a fully charged battery in the drill I let 'er rip. The drill says 0-1300 RPM on it, and my tach showed 1200 RPM.
CLOSE ENOUGH!
